Laptop battery degrading or charger issue
Status
Not open for further replies.
6,403 (1.11/day)
Midlands,UK
System Name Ultraman
Case Alienware X16
My laptop doesnt need the battery and power supply to hit its 175w max rating, my laptop has a 4080 laptop version. What the power supply rated at?
330w charger/power supply
Ok just attempt to do a battery calibration per instructions from dell/video on your particular mobile and see if that resolves it
Already performed one as mentioned earlier. :)
We can close this thread as i've got my answer.
187 (0.17/day)
While all this talk of battery and electronics is great,
My apologies if we seem to have usurped your original question, but that's the nature of forums. The moderators will keep us in check if we stray too far away from the subject.
explain why in a mature manner like Harlow?
Cheers. I try to be fair. I've fallen into the trap of imprecise language on many occasions and had my "comeuppance".:)
Anyway, to add and illustrate, if you take a single, standard AA battery, that is indeed a "battery". A (as in one) 1.5V battery.
I'm old school (and people call me pedantic) for using terminology learned when studing for a degree in electrical engineering and electronics. I was taught that a cell is a single unit and a battery is a group of cells.
https://circuitglobe.com/difference-between-cell-and-battery.html
However, many (if not most) definitions on the internet define a battery as both single and a multiple unit, which is not what I was taught. When talking with friends and family, I use the term battery loosely and speak of AA batteries and watch batteries. If I were to call them cells, I'd get puzzled stares or objects thrown at me. But when I'm discussing power systems with other engineers, I use the term cell to describe a single unit. Hence, in engineering parlace, I'd describe a PP3 and PP9 as 9V batteries, but AA and AAA as 1.5V cells. It's being needlessly nit picking, but we all have our foibles.
while the battery may be designed for 19V
Sorry, but again I think this should read "while the laptop may be designed for 19V", substituting 'laptop' for 'battery' in your sentence. Saying "the battery may be designed for 19V" makes it appear the battery is built up of cells to give a terminal voltage of 19V. As already described above, laptops incorporate 'buck converters' to generate all the various different voltage rails needed inside, including the charger supply. The backlight behind the display in the lid might require a 'boost converter' to generate a high voltage for the backlight. In some cases this is over 100V and capable of giving the unwary a shock. Thus you will have several voltage rails below 19V and possibly one above 19V, all generated from a single 19V input.
I pretty sure you know a laptop battery can have a significantly different terminal voltage to that of the power brick, but not all readers may be able to infer this subtle nuance, when talking about "19V". I thought it worth mentioning to save disappointment and confusion, if anyone goes out looking for a "19V laptop battery" on eBay or Amazon .
If your laptop came with a 100W supply, I would be very leery, and advise against the use of a 65W supply. 35% less capacity is a lot. Running just the laptop "may" be okay, but I would make sure the battery has been removed first. If lucky, at worse the laptop would just crash and recover fully upon booting with a suitable supply. But if unlucky a crash could result in file corruption, or perhaps worse. I would also pay close attention to the temperature of the power block to make sure it has lots of ventilation to avoid it getting too hot.
OK. I've run a few tests this morning on my Lenovo laptop with a USB-C meter connected in series with the "wrong" 65W USB-C power brick from the Huawai laptop.
The laptop is idling (no big programs running) and the USC-C meter shows 19.22V (nominal 20V USB-C under load) at 3.05A and 59W in. Note this is 6W less than the nominal 65W rating of the Huawei PSU. Passmark's batmon program shows a varying charge rate between 10W and 48W, depending on CPU activity. When the CPU demands more power, the restrictive output from the 65W supply means less power is routed to the battery charger. Hence the charging rate goes up and down. Not perfect. It will take longer to charge the battery, but the laptop still works.
Switching over to the correct 100W USB-C power brick supplied by Lenovo gives 19.90V on the USB-C meter (much closer to the nominal 20V USB-C specified output), at 3.3A and 65W in. Passmark batmon shows the battery is now charging at a constant 53W. The additional 35% headroom from 65W up to 100W allows both the CPU and the battery charger to work at optimal levels, as opposed to variable charging levels when using the restrictive 65W supply.
As a final test, with the 100W USB-C PSU connected, I started the Aida64 stress test. The USB-C meter shows 19.72V , 4.70A at 93W. Interestingly, batmon shows the battery charge rate has dropped from 53W to 5W. A red warning showed up in Aida64 saying the CPU was overheating so I ended the stress test after 60 seconds. Obviously the 100W power brick cannot supply the CPU running flat out and charge the battery. Conclusion. The design engineers have done their job. Power is diverted from charging the battery and routed to the CPU when necessary, with both the 65W and the 100W chargers.
I don't envisage any laptop crashes when running from a 65W brick, especially when with lightweight tasks and no silly benchmark stress tests. Unlike a desktop system starved of power by an inadequate ATX PSU, a laptop can usually fall back on the battery when the mains brick fails to provide enough power. When the battery gets low, Windows (etc) normally executes a shut down to avoid a crash. N.B. As with many modern laptops, my laptop's battery is buried inside and cannot be unplugged easily, unlike some older laptops.
In hope this reassures you I'm not totally mad running my laptop on an "under-rated" power brick. Engineers like myself are renowned for experimenting. It's part of our job. That's why I tested specific equipment at ambient temperatures down to -51°C (-60°F) and up to +60°C (+140°F), performed shock & vibration checks, EMC emissions and immunity + electrical safety compliance, etc. As with many complex systems, both electrical and mechanical, there's a (designed in) margin between safe operating levels and a smoking ruin. I apply this knowledge and work experience to computing. Sometimes I get it wrong. Most times it's OK.
Each battery cell is usually charged individually up to around 4.2v, not in series as a lump sum.
Interesting. Thanks for the clarification.
In the past, I remember finding 18650 cells in laptop batteries with unequal terminal voltages. Some cells were "normal", others were "low". Some even displayed a small reverse voltage.
At the time, I assumed batteries were charged as a single entity and not on an individual (per cell) basis. However, given the multiple contacts on many removeable laptop battery packs, I suspect even 15 to 20 years ago, they were charging each cell separately.
13,349 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Dell has a problem with batteries. Long time ago the batteries were rock solid and covered by warranty. Several years back they hit some sort of problem when a lot of batteries failed.
It was not just Dell. There was a HUGE problem with laptop batteries in general causing fires and/or spewing off toxic fumes. This was particularly true with cheap batteries made in China and other unregulated parts of the world. It resulted in many injuries, emergency aircraft landings, new transport regulations, safety standards and more.
That is exactly how I was taught for my degrees as well. But I was also taught a battery can be made with a single cell. And that is exactly what I meant by technical differences that are often confused.
You can have a single cell battery. I gave an example above. If your device uses a single AA or AAA battery, that is a "single cell battery". Most motherboards use a single CR2032 CMOS "battery". Yet that is a one cell battery too.
There are even separate schematic diagram symbols for "single-cell battery" and "multi-cell battery" as illustrated in this Engineer Fix article.
I note even in your Circuit Globe link above, it has an illustration of a "single cell" that is clearly labeled with the word, "battery"!
In this BatteryGuy.com KB article, it says,
A battery is made up of one or more cells.
In this LibreTexts Chemistry, 8.3: Electrochemistry- Cells and Batteries article, it say,
A battery is an electrochemical cell or series of cells
And that is exactly what I meant to say.
Ummm, no. That is not correct. At least not as a blanket statement for all laptop batteries, or my experience as a long time tech.
That is why. Different voltage rails? Not in my experience. One rail, one output voltage.
I have 3 laptops here right now. My MSI, my old Toshiba, and an ASUS. I just got out my trusty multimeter there is only one output voltage for each. And that makes total sense. Why divide (thus limit) the available battery power to the laptop itself? It makes more sense to ensure all the available power is provided to the laptop. Then the laptop's intelligent divider and regulator circuits can distribute the various voltages to the display screen, RAM, CPU, etc. as needed.
I personally have never seen a laptop battery that provides different voltage outputs. That would greatly increase complexity and thus cost.
I note this IBM/Lenovo/Samsung battery pinout illustrates the typical battery connector. There is only one voltage out (VCC). The other pins are for ground and various sensors.
qxp
50 (0.86/day)
So battery has a meaning of "array" and for electrical batteries you have an array of electrical cells. A similar usage is "Voltaic pile" - i.e. a pile of cells. Another related usage is "artillery battery" - several cannon and/or howitzer acting together. You can try to discuss whether you can have a battery, array or pile of one element. I would go as far as to say you can have an array of length 0. So a battery or array is a structural unit of similar elements, while when you use "electrochemical cell" you really mean a single pair of electrodes and electrolyte.
42,657 (6.68/day)
You can report it to a mod to do so
187 (0.17/day)
Good afternoon (the time here as I write).
To illustrate my point about " all the various different voltage rails needed inside, including the charger supply", check out this image. By the way, I was talking about the 'innards' of a laptop, not what's inside a battery. It's certainly not the most up-to-date board, but it clearly shows areas on the pcb associated with the +5V, +3.3V, Vcore, +1.8V, +1.5V and +1.2V supplies. That's 6 supply rails by my count and doesn't appears to include the battery charger.
https://diagramio.com/laptop-motherboard-diagram
Sorry, you may have to visit the web site above because it doesn't seem to allow linking an image.
In a desktop PC with an ATX PSU, you can expect to find +12V (used to power the CPU and PCIe GPU), +5V, +3.3V and maybe a couple of (virtually obsolete) negative rails, -5V and -12V, used in the past for COM port UARTs and ISA bus slots.
A brief scan of the internet shows laptop circuits with +5V for general logic, USB and possibly disk drives especially SATA. Next we have the +3.3V supply for other logic. The CPU will probably be driven from another lower voltage (variable) Vcore supply rail, e.g. in the nominal range 0.8V to 2V(ish) depending on CPU loading at any instant in time and its generation. Memory will require a separate low voltage rail. N.B. DDR5 has a VRM on each DIMM. The battery charger circuit may require yet another voltage rail.
This why I said there are several different voltage rails to be found inside laptops, all fed from a single generic "19V DC" input or a single USC-C DC input on modern laptops.
The "19V" (or USB-C) supply is fed to a number of DC-to-DC converters, with output voltages to suit the various parts inside.
Here is a discussion about the main +5V and +3.3V supplies found in some laptops:
https://tech-champion.com/hardware/understanding-3-3v-and-5v-circuits-in-laptop-motherboards/
Next we have some videos describing the +5V and +3.3V rails.
Finally a quirklily titled video about Battery Changer [sic] circuit design. The reviewer correctly identifies it as a Charger, but the OEM circuit diagram mis-spells it as Changer.
All interesting stuff (to some people).:)
Enjoy.
  • Like
Reactions: qxp
13,349 (1.98/day)
Nebraska, USA
Mouse Logitech M190
:( :confused: :(
Okay but, so?? No one in this thread, and definitely not me, is disputing your point. This thread is NOT about what's inside the laptop. In fact, I even noted multiple times that different voltages are used by the computer itself where there are voltage dividers and voltage distribution circuits for the various different voltages. For example, in Post #21, I said (my bold underline added now),
the RAM, drives, CPUs, GPUs, fans, USB ports, etc. in laptops operate with the same voltages as those used in PCs. So within the laptop, the voltages are split and divided into standard voltages, typically +5 and +12, and then again to lower voltages.
And again in post #28, I said,
So I'm sorry but I don't understand who you are debating, what point you are trying to make or dispute, or why. :confused:
This thread is about the battery and its charger. Not what happens to the battery's single output voltage after it enters the laptop.
I think its time to move on. Have a good day.
qxp
50 (0.86/day)
What Harlow is saying is that the 19V DC voltage does not connect directly to the battery. If you look at his image there is an area marked "Battery charger" that also includes input DC jack. There is an integrated circuit in that area marked ISL9519 which is made by Renesas.
If you lookup the page for that IC it has a schematic showing how to use it:
The schematic shows that 19V is is connected to the IC through a couple of mosfets and the system bus and the battery are not connected directly either. This makes sense - you would want the system bus to be at more or less fixed voltage while the battery voltage will drop as it discharges.
The other parts of the system - like the CPU and memory are fed from the system bus through DC-DC converters. For example the "VRM module" is a DC-DC converter from electrical engineers perspective.
The input DC voltage is higher than the battery for two reasons. First, if the DC charger voltage was lower than the battery you would need a boost converter somewhere to produce higher voltage for full charge, making the circuit complicated.
The second reason is that it is easier to transmit more power with higher voltage, as power is voltage times current. If your DC power brick produced 5V then to supply 65W to the laptop the wires would have to carry 13 amps of current making them very thick. For 19V you only get about 3.5 amps and get away with much thinner wires. This is also the reason why USB-C has the newer modes where instead of providing older USB 5V it provides much higher voltage.
13,349 (1.98/day)
Nebraska, USA
Mouse Logitech M190
Gee whiz. :(
Do you read what he said? He did not say that.
He said,
That was not in dispute. It seems everyone is missing the point here. The point is, laptop batteries output just 1 voltage. And the power supplies/chargers used to charge laptop batteries output just 1 voltage. That's it. Time to move on.
775 (0.13/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
This must be a joke.
The battery output voltage changes up and down depending on state of charge. And the battery charger output voltage also varies depending on load and is allowed to vary.
It's hard to move on from such differences of opinion.
  • Like
Reactions: qxp
qxp
50 (0.86/day)
Let me try to bridge the two sides - usually the laptop batteries have just one output which produces some voltage at any particular time. This voltage depends on the discharge current and how much charge is left in the battery. In fact, this is used to report the percentage charge left.
In all the laptops I have ever seen the laptop power supply is never used to charge the battery directly. Rather the laptop power supply powers the laptop and it is the laptop circuitry (such as ISL9519) that decides whether to charge the battery or drain it. In fact, I have a Dell laptop that is perfectly capable of draining the battery while the power supply is connected when the GPU is on and uses a lot of current. The same Dell has two power inputs - one is the usual Dell jack, and the one is the USB-C connector. As far as I know they have separate circuitry on each port because USB-C requires negotiation of voltage and the power supply has just one voltage output.
13,349 (1.98/day)
Nebraska, USA
Mouse Logitech M190
OMG! Absolute total nonsense! The voltage remains constant. The current is what varies as any 7th grader can quickly verify with his or her $10 el cheapo supreme voltmeter.
@qsp - you might want to do just a tiny bit of research before you decide who you hitch your wagon to.
Do you seriously believe the alternator in your car is varying its output voltage depending on the charge of your car's 12V battery? What about the charge voltage on your phone? A laptop battery is no difference.
Any nincompoop can easily see a 19V battery will NEVER fully charge if the charger's voltage drops below 19VDC. Come on people! Wake up before posting such hogwash.
775 (0.13/day)
Pacific Coast
Mouse EVGA TORQ X10
I think you are living in a world of theory but have forgotten to consider something.
The battery voltage absolutely changes with state of charge. And, the "charger" (power brick) does not charge the battery directly at all. It is only a source of power. Anything between 18 and 22 volts will probably work just fine. Often even 24 volts, though pushing your luck. The real charger is a circuit inside the laptop which charges each cell individually to much less than 19 volts.
Your car uses a lead acid battery which doesn't have individual connections to each cell. This is much different than a car.
Yes, your car's alternator output voltage does change with load, and engine RPM, and heat.
Status
