Laptop cpu upgrade from i7-8750h to i9-9980hk
13 (0.01/day)
Hi i have an Aorus 15 X9 with a i7-8750H as CPU and Intel HM370 as Chipset. Yeah, i know , its soldered, its's not an easy game. I don't want to do this by my hands, i want to buy or contract a service from a specialized technical service to do this. But code problems appears in the way... i need to put cpuid 906ed microcode in the bios, how can i do that and unlock the multipliers of the bios? according to platomav's MC Extractor it is the same platform. i used/looked aorus 15 x9 bios and aorus 15 xa bios, both computers are very similar one is the upgrade from the other. The i7-9750h its the diference between them. Someone can give me a hand to not brick my computer in the bios upgrade?
thanks
Frick
Fishfaced Nincompoop
19,813 (2.86/day)
north
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Can you make the text black instead of light grey? Hard to read.
13 (0.01/day)
thanks
dorsetknob
9,106 (1.25/day)
Cost of doing what you want outweighs the value of your laptop
Your need a professional reball and replacment of the CPU as its BGA ( That will be expensive)
your better off selling current laptop and investing in a new laptop ( and your probably save money ).
13 (0.01/day)
i asked for the service and is 50 dolars for reballing, but i need more than reballing?
347 (0.13/day)
Yeah, you'd probably need a 9980hk. Where are you going to get one of these? How much will it cost?
is XA motherboard identical to X9? It looks like that.
Dumb-flashing with the XA bios might do the trick, and in such case that bios should run your current cpu just fine. Anyway, get in contact with someone who will help you in case of bad flash.
Last but not least - do you really need this cpu upgrade?
13 (0.01/day)
here
thats what im investigating, thats why i need help, i have some pictures of cpuz can you help me with that?
Look at this about the double of performance.
thanks for your answer
347 (0.13/day)
So you're going to keep on running cinebench all day? That's a weird use case.
Are you really fine with potentially bricking this laptop? Cause that's one of possible outcomes of stuff you're planning to do.
If you don't have proper tools to recover from a bad flash, don't do it. Sometimes using a clip with an external programmer is ok. Sometimes the chip needs desoldering.
2,259 (1.00/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
sell your lappy and get the one you want, dont mess about reballing another cpu and messing with bios code your setting yourself up to be dissapointed bro it will cost you morethan its worth honist.
dorsetknob
9,106 (1.25/day)
$130 for cpu +$50 reball then you have to sort out bios and risk bricking motherboard
I would think long and hard about this as you could end up with $180 out of pocket and a bricked laptop
+ very much doubt if you could offset some of the cost by selling old deballed cpu (who the wuck would buy it).
Its kind of hard giving you a golden shower.................but some one's got to step up to the WC
296 (0.06/day)
System Name Gaming PC/ EDU PC/ HFS PC
Processor Intel i9-9900KF/ Dual Ryzen 7 2700X
Motherboard Asrock Z390 Taichi Ultimate/ Dual Asrock X370 Proffesional Gaming
Cooling Noctua NH-C14S/ Arctic Xtreme Freezer/ Ryzen Wraith Prysm RGB
Memory 64GB Corsair Vengeance PRO RGB 3200/ 32GB Corsair Dominator 3000/ 16GB Corsair Vengeance Pro 3200
Video Card(s) EVGA RTX 3080 FTW3 Ultra / MSI RTX 2080Ti Ventus / EVGA GTX 1060 SC Gaming
Storage Dual 970 EVO Plus 1TB + 6Tb 860 EVO/ 960 EVO 500GB + 18Tb R0/ 840EVO 250Gb + 16Tb R0
Display(s) Samsung 32" U32R590 Curved 3480x2160 / Samsung 32" LC32H711 Curved 2560x1440 Freesync
Case Cooler Master Stacker 830 NV Edition/ Dual Cooler Master 690 Advance II
Audio Device(s) Creative X-Fi Surround 5.1 SBX/ Creative X-Fi Titanium Pci-E/ On-board Realtek
Power Supply Triple Corsair Platinum HX850i
Mouse Logitech G7 WL / Logitech G903 Lightspeed / MS BT 8000
Keyboard Dual Logitech G19s
Software Win10 Pro
it cant be a double perfomance difference between 6c/12t cpu and a 8c/16t one.... Differences are not noticable so much and since it is a mobile cpu, which is far more crippled than a desktop alternative, i really don't know what is for this gimmick....
