Laptop shuts off when power mode is set to "Best Performance"
Markoo7
7 (0.03/day)
Hi there,
This problem bothers me and i can't figure it out, i have an acer predator 17 laptop i7-6700hq with gtx 970m.
What i've had to do is limit the cpu to 90% maximum processor state and use better performance power mode,
just so it does not shut off. I don't have a battery that could be a problem, temps never hit above 60c.
Is there something that i could do to fix this problem?
I would start by buying and installing a battery.
Isn't this the second time this discussion came up?
Edit: I guess you are a new user? I thought there was a Marko (or something similar) who had a very similar thread a month or two ago.
I'm not familiar with that specific laptop, but with certain laptop and power-brick combos, a laptop can sometimes use more power than it's power brick can actually supply. When that happens, the battery would typically fill the gap. If this happens while you don't have a battery, then your laptop will shut off.
I work with a lot of Dell laptops and I see this frequently. Most Dell laptops use a universal power plug. Sometimes a laptop might come with a 240w primary power brick, and a secondary smaller "travel" power brick that is in the 65w-180w range. The smaller brick is convenient for traveling but will cause the laptop to dip into the battery sometimes even while plugged in. I also see this when people are using their USB-C docking station to charge/use their laptop, since it won't always deliver as much power over USB-C as it gets when a high-wattage power-brick is directly attached.
So I would either get a new battery, or see if you can find a compatible power brick with higher wattage (same connector, same volts, more amps).
I was thinking temps or too much power demand from parts myself.
I don't know, couldn't find anything on this topic. Yeah, i'm new.
I bought a new power brick 240w, I think the old one was 180w.
How old is that laptop? I’m guessing it’s at least 8 or 9 years old now. I would sell it and add couple hundred dollars for an entry gaming laptop and that alone would probably run circles around your current laptop in terms of gaming performance.. just what I would do before throwing anymore money at it…
That is the plan, it's 9 years old. Currently I'm saving up for a car so gaming pc is on a waiting list (I don't game that much that's why I'm trying to fix this laptop).
I'll get a battery, it's like 70€ and will inform of the results.
Hi there,
that's an old laptop, have you ever clean it? Just because you see 60c on some component doesn't mean it tells the all story.
60c refers to what?
60c refers to what?
It was cleaned last week. 60c on gpu, cpu has lower temps, around 55c (whilst playing something). Now it's idling; Cpu 33c, System 39c, Gpu 37c (fan on low)
What percentage is the laptop faster set to "Performance" instead of "Balanced"?
Maybe motherboard power delivery modules can't handle extra stress.
I don't know the percentages, but right now cpu doesn't turbo and it's clock speed is 2.3Ghz (base is 2.6Ghz).
If that does not fix the problem, you might have a fault in the power distribution circuits of that motherboard and at that rate you might as well part it out
Maybe VRM getting too hot although if you have Bi-Directional PROCHOT enabled it should throttle.
The max all core for that processor should be at 3.1ghz, but processor cant handle it. I dont remember single core max speed.
70 EUR for a battery for OLD laptop? Insane.:oops: Just use it "as is" "for final lap" and forget about spending $$$ on it.
i think it's still overheating somewhere:rolleyes: 6700hq is hot asf btw...
Laptops are known to draw from both power brick and battery under high load. This is likely your problem as you have no battery.
Don't spend any money on the laptop.
I replace batteries in older Laptops all the time, and usually spend less than $30. I see a ton of batteries on eBay for the "acer predator 17" that cost $25. That's basically the cost of lunch these days. They might be cheaper off-brand batteries, but it's usually not a big deal when you're just trying to extend the life of an old Laptop for a bit longer. Maybe it's more expensive to buy these batteries in the EU compared to the US, I don't know.
Lunch is $25 where?
that's the point, $30 is okayish but 70 eur or usd is not worth even for "gaming" laptop which is dynosaur old. That 6700HQ is TRASH these days, i've had recently asus tuf f15 with i5-10300H with same core config 4/8 and as we all know it's same 14nm heating monster. now I have another tuf f15 but with i7-11800H which is 8/16 and 10nm yes it's not "cool" also but it's performance even with HT off (for heat sake, cooling in asus tuf f15 is flaw lol) is DAY AND NIGHT compared to my ex i5-10300H.
