- Apr 9, 2013
- 368 (0.08/day)
- Chippenham, UK
System Name | Hulk |
Processor | 7800X3D |
Motherboard | Asus ROG Strix X670E-F Gaming Wi-Fi |
Cooling | Custom water |
Memory | 32GB 3600 CL18 |
Video Card(s) | 4090 |
Display(s) | LG 42C2 + Gigabyte Aorus FI32U 32" 4k 120Hz IPS |
Case | Corsair 750D |
Power Supply | beQuiet Dark Power Pro 1200W |
Mouse | SteelSeries Rival 700 |
Keyboard | Logitech G815 GL-Tactile |
VR HMD | Quest 2 |
Sorry yes, secondhand enclosure + whatever GPU you want, but obviously secondhand is the best value.I assume that you mean second hand regular GPU, if you have an eGPU enclosure?
The going rate for a TB3 eGPU enclosure on eBay in the UK is somewhere in the £130-150 range. That comes with the PSU & cable you need, so just add whatever GPU you want. Cheapo new eGPU enclosures can be had for similar money, but they'll be uglier & you'll need your own PSU & probably cable.I know it is PC and it covers all levels of society but once you apply common sense to the EGPU landscape it is a turn off. The Enclosure may cost more than the GPU. Then the Cable can cost 3 times as much as a regular DP cable and the kicker is that these handhelds are rising in popularity because of the performance of APUs.
Where I live those enclosures are expensive. While I could see that scenario if you are using a handheld as your main desktop though as you are already thinking of value.
If you assume you're going to have a handheld anyway, then please explain how buying an entire desktop PC is cheaper than a ~£150 eGPU dock?Buying a desktop PC would be the most cost effective way to go, just my preference as well but I can understand if someone doesn't have the room or travels often and doesn't want a desktop.
Although eGPU enclosures are expensive even second hand, performance is also lost going through an eGPU.
Oh forgot to touch on the performance loss argument - yes, you do lose performance via TB3/USB4 compared to in a decent desktop, so you could arguably say a desktop with a tier down GPU is more equivalent.
