Lenovo M93P Tiny Fan
wildman5354
2 (0.00/day)
please help. i have a Lenovo M93P Tiny and would like to make the fan run FULL speed all the time (an option to control it manually would be nice, but not a deal breaker).
the problem is that when i turn it on, the fan is FULL speed (i can hear it-NOT a problem) and this continues for about 5 minutes. the temps are 90~100f. great. but then it slows down considerably (no more noise, VERY little air exiting case) and the temps climb to 165~175f - this is not acceptable. it will stay at this temp for 5~20 minutes, then the fan will once again go full speed and the temps will drop to 135~140f. than the fan will once again drop to nothing and the temps will climb again. this is stupid bullsh%t behavior. i have enclosed pictures of the fan. maybe there is an inline controller or something (potentiometer?) that i can splice in to the circuit?
thanks for any help / suggestions
4,043 (0.92/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
Check your BIOS for a fan control setting. Dell and HP have options built into their PCs for this purpose.
If there is not one there, you could splice power in from a 12v source, but then you will get an error message from the PC and this may also cause other poor behavior.
there may be fan control software that would work, but they have a poor track record with OEM PCs.
wildman5354
2 (0.00/day)
BIOS set to "Better Thermal Performance", the only other option is "Better Acoustic Performance".
no, you don't splice in 12v - you cut the blue wire to make it run 100%.
no, none of the fan control software programs work.
i need someone who knows about PWM fans to help on this.
thanks
Ahhzz
Super Moderator
9,035 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
Here's someone who did a mod on this case because of temperatures. might give it a read, but I offer no warranty one their project :D
https://www.reddit.com/r/pcmods/comments/n729c3
5,223 (3.74/day)
Colorado, U.S.A.
Software Windows 11 Home
100°F is around body temperature, a bit low to aim for.
AsRock
TPU addict
19,128 (2.98/day)
UK\USA
thanks
Did you try a application called Fan Control ?.
EDIT: Always the option for a laptop cooler. Just make sure the fans are in about the right places and blowing the right direction.
4 (0.01/day)
Traverse City, Michigan(MI)
System Name Windows 10
Processor AMD A10
Motherboard MSI
Cooling RealCool
Memory 32 gb
Video Card(s) 3050 GT
Storage 500 gb SSD
Display(s) ViewSonic 24'
Case Simple case
Audio Device(s) Microlab Speakers
Power Supply 500 W
Mouse Bloody A10
Keyboard Chicony
VR HMD No
Software Other
It seems like your Lenovo M93P Tiny is experiencing temperature fluctuations, causing the fan to speed up and slow down. You might want to check for any dust buildup, ensure proper ventilation, or consider adjusting power settings in the BIOS to maintain a more consistent temperature.
silentbogo
5,588 (1.37/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 64GB DDR4-3600(4x16)
Storage ADATA Legend 2TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
I had a bunch of M93p's going through my hands over the past few years, and I can tell you right now that these temps are quite normal.
Another thing to note, is that fans tend to go bad over time(big surprise). Just get a replacement. They are still available.
I had two noisy machines at work. With new fans they are nearly inaudible even at full load. Last one also got upgraded to i7-4770T(which has a 45W TDP comparing to the old 4590T with only 35W TDP). Temps are still good, but I run it in "better thermal performance".
