LG 27GN950 brightness flickering
4,509 (1.39/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Case Fractal Design G
Audio Device(s) Realtec 5.1
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Hi Everybody,
I got a new monitor some time ago but I've noticed some strange things happening. The brightness is flickering sometimes in games or when I'm doing nothing. Adjusting the brightness sometimes helps but not always.
I've read that the problem may concern the VRR and the range the monitor operates at 144Hz. I wonder if anyone has that monitor and noticed same thing. (I'm still trying to figure out the optimal settings) Maybe somebody with a high refresh rate monitor has noticed same thing and been wondering if there's a fix for it or any way to mitigate it. It's not like it changes the game experience or anything but it is annoying.
Thanks for sharing.
42 (0.03/day)
System Name Self-built
Processor AMD R7 5800X3D
Motherboard ASUS Prime B550 Plus
Cooling Scythe FUMA 2 + various case fans
Memory 16GB: Corsair CMK16GX4M2D3600C18 at 3800C16
Video Card(s) Gigabyte Eagle RTX3070
Storage 2x WD Black m.2 nvme 1TB, WD HDD 6TB, Crucial 750MX300,
Display(s) LG 27GN950
Case DeepCool E-Shield
Audio Device(s) Int: RealTek ALC892, NVidia GA104 HD Ext: LG 27GN950, Behringer DEQ2496, DCX2496, A500. etc
Power Supply Seasonic Core GM-650SRM
Software Linux Mint + Windows11 pro
Benchmark Scores Not worthy of attention
I haven't noticed any flickering, at any frequency.
There's a LG bios update that pushes the monitor to 160Hz. It takes a dreadfully long time to update (about 30 minutes!).
3,100 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB WD SN850X
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
very slight brightness flicker is normal with freesync/G-Sync Panels.
it mostly happens at low framerates, very slow movement of a basically static image or loading screens.
some are worse than others. i have a 850 (1440p version) and it happens but it is very subtle (don't know if that's even a word :D )
4,509 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
same here. It is very subtle and I basically can't see it. I need to take a closer look and really stare at the screen to notice it. I sometimes see it when I'm in the desktop. It's nothing that changes the games experience I just wanted to know if it's just me or others have that us well.
I started playing Horizon Zero Dawn and I've not noticed any brightness flickering. At least yet.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Hi Everybody,
Thanks for sharing.
I see that on my 32" monitors when VRR/freesync is enabled, i found no fix without turning off VRR/freesync
11,094 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
It usually happens when you fall below 50 Fps and then above it - when gsync engages/disengages there is a sudden fast dip in brightness that looks like flicker, so if you're sitting at that magic number (whatever it is for that particular panel) it will flicker. Same for the higher end as well - if you're going past about it will flicker - also in loading screens.
4,509 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I need to check that one out when I get home but what's the point for switching off the VRR/freeSync? Although I will give it a shot.
I think I have the VRR off at the moment. I need to double check.
I don't drop below 50FPS in gamnes. It mostly happens on desktop. When I switch to 60hz problem is gone.
Mussels
58,412 (7.78/day)
Oystralia
with a system like mine my FPS doesnt dip very often, so i get a smoother experience without it - i assume its a side effect of freesync on nvidia, but could be that i just have midrange monitors
11,094 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Do you have a dual monitor setup?
Mussels
58,412 (7.78/day)
Oystralia
yes, but 99% of the time monitor 2 is unplugged (its damaged, i use it when i'm streaming only)
4,509 (1.39/day)
Currently Norway
System Name Bro2
Mouse Logitech G402
I've tried some stuff with the monitor. I noticed that the flickering happens only with 'game 1' mode set up in the monitor settings. It has a lower brightness and higher contrast ratios. I've manually adjusted the settings (fitting my expectations) and it went away. Could that have been the problem? Brightness and contrast ratios?
