Raevenlord
- Aug 12, 2016
- 3,755 (1.28/day)
- Portugal
System Name | The Ryzening |
Processor | AMD Ryzen 9 5900X |
Motherboard | MSI X570 MAG TOMAHAWK |
Cooling | Lian Li Galahad 360mm AIO |
Memory | 32 GB G.Skill Trident Z F4-3733 (4x 8 GB) |
Video Card(s) | Gigabyte RTX 3070 Ti |
Storage | Boot: Transcend MTE220S 2TB, Kintson A2000 1TB, Seagate Firewolf Pro 14 TB |
Display(s) | Acer Nitro VG270UP (1440p 144 Hz IPS) |
Case | Lian Li O11DX Dynamic White |
Audio Device(s) | iFi Audio Zen DAC |
Power Supply | Seasonic Focus+ 750 W |
Mouse | Cooler Master Masterkeys Lite L |
Keyboard | Cooler Master Masterkeys Lite L |
Software | Windows 10 x64 |
LG has announced another bang-for-buck entry in their monitor line-up, which is usually one of the best in the specs-pricing department. For the modest amount of $349, the 32QK500-W is a 31,5" affair with a QHD (2560*1440) resolution, which supports AMD's FreeSync technology for synchronized refresh rates and greater fluidity in gaming. There's an 8-bit + FRC IPS panel, with a minimum 250 cd/m² brightness (300 typical), which isn't much, but should be enough to be used in a not-too-bright room.
Of course, some of the panel's specifications do point towards the cost-cutting that needed to be done in order to get it to this price-point; the brightness isn't anything to go by (not even close), the FreeSync support tops out at a maximum of 75 Hz, and the 8 ms response time is enough for casual gaming, but not for cutthroat competitive gaming. Some LG technologies such as Black Stabilizer, Crosshairs, and Reading Mode are available. Output connectors stand at 2x HDMI, 1x DisplayPort, and 1x MiniDP, with an additional headphone jack. The monitor is VESA wall-mountable.
![](https://www.techpowerup.com/img/vKYawJeoGBfyl5t9_thm.jpg)
![](https://www.techpowerup.com/img/SFAAw9TqZs98LRoX_thm.jpg)
![](https://www.techpowerup.com/img/Keki7vAxSaTRY3Be_thm.jpg)
![](https://www.techpowerup.com/img/18aD8RTYP3SWu2Y0_thm.jpg)
![](https://www.techpowerup.com/img/TnaGNzDcCZAnOT0y_thm.jpg)
