LG Reveals Full Specifications and Pricing for the 4K UltraGear 32GS95UE-B OLED Monitor
369 (0.18/day)
I do. But that's sort of built-in when talkin OLED, so what can you do? Ask for 60Hz models?
I get this is early adopter stuff but maybe asking for +$1K monitors to have the full fledged spec like others do.
bug
13,992 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
I've already said that. I just added that in this particular case, lack of DP2.1 is almost a non-issue. And again, this is going for $1.5k+ (tax included), so I'd prefer everything and the kitchen sink at this price point.
67 (0.08/day)
bug
13,992 (3.95/day)
You need to look at the table just below the one you linked to, where they list transmission mode limits using DSC or chroma subsampling or both. Hence, while using DSC, you don’t need chroma subsampling to go to or beyond 4k120 using DP 1.4 (HBR3) until you hit 5k 240 hz.
Now we're just going in circles: https://en.m.wikipedia.org/wiki/Display_Stream_Compression#Effect
Although DSC is mathematically lossy, it meets the ISO/IEC 29170 standard for "visually lossless" compression
It cannot be done without lossy compression, even if the compression is imperceptible to the naked eye.
Again, this why I say lack of DP1.4 is mostly nitpicking. But for the asking price, you're allowed to nitpick.
1,993 (0.48/day)
You could not have stuffed a GSync Ultimate module there for the price?
Still people glamoring for this outdated, expensive and active cooled FPGA in 2024?
There are very few advantages for this module these days, but numerous downsides.
It depends on what you mean by "better". QD-OLED uses blue light and blue is the LED that dies faster than other variants.
I say the proof is in the pudding, so let them release first and talk about them a few years down the road.
Rtings has tested QD-OLED and thus far it has not died faster than WOLED.
The main problem with QD-OLED are the raised blacks when any amount of light hits the screen. It's made even worse by the fact that most QD-OLED panels use glossy coating. So unless you only use it at night or have perfectly controlled studio lighting behind the monitor then it has several issues with gray blacks and reflections.
There's no GPU in the market which supports that.
AMD 7000 series RDNA3 supports DP 2.0 UHBR 13,5 @ 54Gbps and their RDNA3 based Pro cards support full DP 2.0 UHBR 20 @ 80Gbps.
DP 2.1a permits longer cable lengths at those speeds in the future.
1,592 (0.65/day)
London, UK
Get used to it because past 4K 240 the bandwidth required for uncompressed stream exceeds that provided by DP 2.1 spec.
up to 4k 300hz 10 bit color will be fine, that is 74g.
67 (0.08/day)
No circles here. I didn’t say anything about lossey or lossless. You said dsc uses chroma subsampling, we said (and proved) it does not. Simple. I just don’t want misinformation to start spreading, that’s all.
  • Like
Reactions: bug
bug
13,992 (3.95/day)
Ah ok. Yes, DSC != chroma subsampling. Still lossy, but different. If I stated otherwise, I was wrong.
2,731 (6.34/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
As I said, it’s all cool. No one said here that DSC is lossless either, just VISUALLY lossless which, at the end of the day, is all that matters really. It’s significantly better than subsampling since it avoids the text issues you mentioned earlier. It’s unavoidable since the panel technology seems to overtake the port bandwidth nowadays at every turn. Nevermind the fact that VESA themselves didn’t help matters by creating several tiers of DP 2.1 which all have different performance.
  • Like
Reactions: bug
434 (0.15/day)
Processor Ryzen 5700X
Motherboard Gigabyte B550 Arous Elite V2
Cooling Thermalright PA120
Memory Kingston FURY Renegade 3600Mhz @ 3733 tight timings
Video Card(s) Sapphire Pulse RX 6800
Storage 36TB
Display(s) Samsung QN90A
Case be quiet! Dark Base Pro 900
Audio Device(s) Khadas Tone Pro 2, HD660s, KSC75, JBL 305 MK1
Power Supply Coolermaster V850 Gold V2
Mouse Roccat Burst Pro
Keyboard Dogshit with Otemu Brown
Software W10 LTSC 2021
jesus christ thats overpriced
21,661 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
It's not really BS, DP1.4 has enough bandwidth to do almost anything this monitor can do.
With DSC. It's nearly lossless yes, but not entirely, and is especially more noticable at 4k@240hz for example.
If you want to believe in it, do not include me, DSC is lossy just like MP3.
I've used DSC and I honestly can't see the difference even with a magnifying glass until you really push it to it's limits.
2,731 (6.34/day)
There is no consumer GPU on the market that can run it at 4K240Hz without DSC and I have no idea if the monitor manufacturers are in the loop on what the next gen cards from NV and AMD will implement, so, assuming they are not, I guess it makes no sense for them to go for a full UHBR20 port and cables which are an added cost.
1,258 (0.22/day)
CO
System Name 4k
Processor AMD 5800x3D
Motherboard MSI MAG b550m Mortar Wifi
Cooling ARCTIC Liquid Freezer II 240
Memory 4x8Gb Crucial Ballistix 3600 CL16 bl8g36c16u4b.m8fe1
Video Card(s) Nvidia Reference 3080Ti
Storage ADATA XPG SX8200 Pro 1TB
Display(s) LG 48" C1
Case CORSAIR Carbide AIR 240 Micro-ATX
Power Supply EVGA SuperNOVA 650W
Software Microsoft Windows10 Pro x64
yeah whenever I do do OLED it will be WOLED
Why is this? If you went OLED with this year gen of monitors the QD-OLEDs right now have 3 year burn in warranties compared to this 2year of the WOLED. The QD-OLEDs are cheaper and have more features as well. I really don't believe there's much of a difference between the two technologies right now and even less in the feature.
21,661 (3.40/day)
Olympia, WA
System Name Pioneer
Can't the Radeon 7xxx series do that?
There is. You lose the perfect blacks.
2,731 (6.34/day)
67 (0.08/day)
I too will go woled for my next oled monitor. The raised blacks with modest ambient light on qd-oled’s are a deal breaker to me. Sure the color gamut/volume on qd-oled is higher than woled but in my experience (using qd-led with some of the highest color volumes / gamuts on any consumer display) I just don’t see the difference.
The matte vs glossy debate is another story but to be honest I don’t notice much difference between my glossy oled tv and my ultra matte oled monitor while gaming so to me that is a non issue.
Price wise, LG often releases their monitors at a steep price and heavily discounts them weeks to months later. I can all but guarantee the price will be similar between the two technologies by fall.
21,661 (3.40/day)
Olympia, WA
System Name Pioneer
Only the Pro models. The consumer cards are limited to UHBR13.5.
Oh, I though UHBR13.5 could do 4k@240. Guess I was wrong there.
2,731 (6.34/day)
@R-T-B
Yeah, it's a bit of a mess on VESAs part.
Required data rates assume 10-bit colour depth and 4:4:4 chroma and are based on common timing format (CVT-R2) (source: tftcentral)
bug
13,992 (3.95/day)
Still, we're talking ridiculous territory here. There are no movies shot in 4k@240fps. You could render the desktop at 240fps, but... really... That leaves just games where, even if you could push 240fps, nobody would notice the DSC anyway.
I'm not even sure most pros will bother squinting at those details, seeing how most streaming services compress the crap out their work anyway.
That said, the argument that "no card can drive it (today)" is kinda moot. My monitors survive several generations of video cards. Always.
23,091 (6.09/day)
Rtings already confirmed QdOled wears faster and in doing so also has color deviation.
1,993 (0.48/day)
Care to link this article/video?
Because from what i saw they made a mistake testing the first gen 16:9 QD-OLED monitor by not running fullscreen content there.
Thus the sides that were black exhibited no wear but the center was driven harder.
MxPhenom 216
ASIC Engineer
13,056 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
I think those are next year, at least for high refresh rates.
Fingers crossed. 32 is too big for PC gaming monitor for me, and 27 is a bit much for 4k.
2,731 (6.34/day)
Oh, you want EXACTLY 28? Because the panels that will possibly come out next year that were mentioned are unlikely to be 28 inches. The favored format for that size for both LG and Samsung has been 27 inches, around 26.5 to be exact, if we judge by the 1440p models. Probably a tooling thing. What I am saying is to not be too hopeful for 28 inches.
1,258 (0.22/day)
CO
System Name 4k
I see, I haven't used a QD-OLED so i don't know if not having the polarizer makes that much of a difference during the day or under direct light. I personally use a 48" LG C1 and when this one dies i will probably go down to 42" if they are up to 240hz by then.
