- Nov 23, 2010
- 320 (0.06/day)
Finally a flat option!
But why?
Processor | Ryzen 9800X3D |
Motherboard | ASRock X670E Taichi |
Cooling | Noctua NH-D15 Chromax |
Memory | 64GB DDR5 6000 CL26 |
Video Card(s) | MSI RTX 4090 Trio |
Storage | P5800X 1.6TB 4x 15.36TB Micron 9300 Pro 4x WD Black 8TB M.2 |
Display(s) | Acer Predator XB3 27" 240 Hz |
Case | Thermaltake Core X9 |
Audio Device(s) | JDS Element IV, DCA Aeon II |
Power Supply | Seasonic Prime Titanium 850w |
Mouse | PMM P-305 |
Keyboard | Wooting HE60 |
VR HMD | Valve Index |
Software | Win 10 |
It's probably for running FPS shooters at a high refresh rate.
Odds on, 480Hz + OLED's insane response times (less than a ms), leads to virtually zero ghosting, and so it probably beats every TN out there on the market.
Anyway, I just hope they are using proper integer scaling for 1080p, and that it doesn't introduce a response time delay.
Processor | 5900x |
Motherboard | Crosshair 8 Impact |
Cooling | Air |
Memory | Hynix C-Die 3200MHz @CL14 |
Video Card(s) | 3080 FTW3 Ultra |
Storage | Lots |
Display(s) | Many |
Case | Something that protects my innards |
Power Supply | Seasonic 850FX gen2 |
System Name | D.L.S.S. (Die Lekker Spoed Situasie) |
Processor | i5-12400F |
Motherboard | Gigabyte B760M DS3H |
Cooling | Laminar RM1 |
Memory | 32 GB DDR4-3200 |
Video Card(s) | RX 6700 XT (vandalised) |
Storage | Yes. |
Display(s) | MSi G2712 |
Case | Matrexx 55 (slightly vandalised) |
Audio Device(s) | Yes. |
Power Supply | Thermaltake 1000 W |
Mouse | Don't disturb, cheese eating in progress... |
Keyboard | Makes some noise. Probably onto something. |
VR HMD | I live in real reality and don't need a virtual one. |
Software | Windows 11 / 10 / 8 |
Benchmark Scores | My PC can run Crysis. Do I really need more than that? |
Zactly why I still don't own an ultrawide myself. 1440p is just a total why. 1080p content (movies, tellie, some older games that don't work properly at resolutions higher than 1080p etc) looks ugly on 1440p displays, and 2160p is devoided of such an issue if integer scaling is up'n'running and configured the right way. 60 Hz ain't much of an issue but when the only quote-unquote perfect 5120x2160 display comes with 200% tax in your country on top of being non-ideal colour-wise it becomes a questionable purchase at best.I just want 21:9 Ultrawides with 5120x2160 resolution, and here's the most important part, at 120hz or greater, preferably a 40" would be nice. With all these crazy resolutions and refresh rates they're doing these days, I would have thought 21:9 Ultrawide monitors would have made the jump to a 2160p vertical pixel count by now. I see them releasing 45" 3440×1440 which is way too large a display for 1440p, but not 5120x2160....am I the only one eagerly anticipating 21:9 ultrawides making the upgrade to 2160p? The closest is LG's 5120x2160 34" 34BK95U which came out several years ago and which I owned for a while, but it was only 60hz and this was its major shortcoming, but like I said this came out several years ago so I would have thought several improved iterations would have been released by now...sorry for the rant.
System Name | The Workhorse |
Processor | AMD Ryzen R9 5900X |
Motherboard | Gigabyte Aorus B550 Pro |
Cooling | CPU - Noctua NH-D15S Case - 3 Noctua NF-A14 PWM at the bottom, 2 Fractal Design 180mm at the front |
Memory | GSkill Trident Z 3200CL14 |
Video Card(s) | NVidia GTX 1070 MSI QuickSilver |
Storage | Adata SX8200Pro 1 TB |
Display(s) | LG 32GK850G |
Case | Fractal Design Torrent (Solid) |
Audio Device(s) | Sennheiser HD598, FiiO E-10K DAC/AMP, Samson Meteorite USB Microphone |
Power Supply | Corsair RMx850 (2018) |
Mouse | Zaopin Z1 Pro on a X-Raypad Equate Plus V2 |
Keyboard | Cooler Master QuickFire Rapid TKL (Cherry MX Black) |
Software | Windows 11 Pro (24H2) |
System Name | Dark Matter / Mørk Materie (In Norwegian) |
Processor | AMD Ryzen 7 7700 (CPU Core Ratio: 'AI Enhanced' & OC: 'Curve Optimizer' @ -40 & 'PBO2' @ +200 MHz) |
Motherboard | ASUS ROG Strix B650E-I Gaming WiFi (AMD Socket AM5) (Mini-ITX) |
Cooling | CPU: EK Waterblocks EK-Nucleus AIO CR240 Lux (D-RGB) & Thermal Grizzly AM5 Contact & Sealing Frame |
Memory | Corsair Vengeance RGB Black DDR5 6000 MHz (PC5-48000) 2x16GB (AMD EXPO) (CL36 tuned to CL30 @ 1.4v) |
Video Card(s) | ASUS TUF Gaming GeForce RTX 3060 Ti 8GB V2 OC Edition (Overclocked +190 MHz Core @ +800 Mhz Memory) |
Storage | 1x Samsung 990 Pro 2TB & 1x Samsung 990 Pro 4TB (Both PCIe 4.0 M.2 SSDs) |
Display(s) | Dell S3220DGF (1800R Curved, VA Panel & 165 Hz Refresh Rate) |
Case | Phanteks Evolv Shift XT D-RGB (Black) (Modular) |
Audio Device(s) | ASUS ROG SupremeFX (Realtek ALC4080 Codec & Savitech SV3H712 Amplifier) (On Motherboard) |
Power Supply | Corsair SF600 Platinum (600w) (Modular) (SFX) |
Mouse | Logitech MX Anywhere 3S (Graphite) |
Keyboard | Logitech MX Keys Mini (Nordic) (Grey) |
Software | Microsoft Windows 11 Home (64-bit) (Norwegian) |
Benchmark Scores | Cinebench R23: 20.130 (Multi Core) (Single Cycle Run). |
Welp, there goes those displays out of the window. An OLED display today has to have a glossy panel before the true color, contrast and brightness can come out of them.Elevating user immersion, these panoramic monitors also feature LG's Anti-Glare & Low Reflection Coating
Storage | Yes. |
I agree but I see one weird use-case: AMD GPU + AFMF + FSR 3 FG + 125 FPS base framerate = maxed out 480 Hz with noticeably inflated inputlag but in games where this actually works you never care about inputlag if your base framerate is over 40 FPS.The resolution switching is a bit weird. Not only 1080p on 32 inches is questionable, the actual audience for a 480 Hz display is strictly high level competitive FPS players (or those with aspirations/delusions of being one) and they also prefer smaller displays from what I gather. Just bizarre. But probably a good option as a 4K monitor, provided you need 240 Hz on those, which is also questionable, but still.
I mean… yeah, but in games where this would work you are also unlikely to care about having more than 120 FPS. There are massive diminishing returns after that point, after all. Sacrificing 4K sharpness to play, say, BG3 or God of War at interpolated 480 FPS just to get slightly more fluid picture (with, as noted, more input lag and potential artifacts) is such a niche use case that I struggle to imagine anyone reasonable actually going for it.I agree but I see one weird use-case: AMD GPU + AFMF + FSR 3 FG + 125 FPS base framerate = maxed out 480 Hz with noticeably inflated inputlag but in games where this actually works you never care about inputlag if your base framerate is over 40 FPS.
Why not if someone plays e-sports and high fps games?But why?
System Name | MacBook Pro 16" |
Processor | M1 Pro |
Memory | 16GB unified memory |
Storage | 1 TB |
Lol why who cares?No word on power consumption of any of these offerings.
competitive shooter gamesBut why?
Processor | Intel i5-12600k |
Motherboard | Asus H670 TUF |
Cooling | Arctic Freezer 34 |
Memory | 2x16GB DDR4 3600 G.Skill Ripjaws V |
Video Card(s) | EVGA GTX 1060 SC |
Storage | 500GB Samsung 970 EVO, 500GB Samsung 850 EVO, 1TB Crucial MX300 and 2TB Crucial MX500 |
Display(s) | Dell U3219Q + HP ZR24w |
Case | Raijintek Thetis |
Audio Device(s) | Audioquest Dragonfly Red :D |
Power Supply | Seasonic 620W M12 |
Mouse | Logitech G502 Proteus Core |
Keyboard | G.Skill KM780R |
Software | Arch Linux + Win10 |
I think the answer is even more straightforward: it may not have the bandwidth to push 4k at 480Hz so something's gotta give.competitive shooter games
System Name | - |
Processor | Ryzen 9 5900X |
Motherboard | MSI MEG X570 |
Cooling | Arctic Liquid Freezer II 280 (4x140 push-pull) |
Memory | 32GB Patriot Steel DDR4 3733 (8GBx4) |
Video Card(s) | MSI RTX 4080 X-trio. |
Storage | Sabrent Rocket-Plus-G 2TB, Crucial P1 1TB, WD 1TB sata. |
Display(s) | LG Ultragear 34G750 nano-IPS 34" utrawide |
Case | Define R6 |
Audio Device(s) | Xfi PCIe |
Power Supply | Fractal Design ION Gold 750W |
Mouse | Razer DeathAdder V2 Mini. |
Keyboard | Logitech K120 |
VR HMD | Er no, pointless. |
Software | Windows 10 22H2 |
Benchmark Scores | Timespy - 24522 | Crystalmark - 7100/6900 Seq. & 84/266 QD1 | |
System Name | Dark-Raptor |
Processor | 14900KS |
Motherboard | EVGA Z790 DARK K|NGP|N |
Cooling | Custom loop, direct-die, dual D5 Pumps, Dual 360 rads |
Memory | 48GB G.Skill TZ5R 8000 Liquid Cooled |
Video Card(s) | RTX 4090 ROG StriX O24G |
Storage | 990 Pro 4TB x2, 990 Pro 2TB, 870 EVO 2TB x5 |
Display(s) | Dual Samsung Odissey OLED G9 and LG 4K 55" CX GSync TV |
Case | CM C700P Black Edition modded |
Audio Device(s) | FiiO K11 + Sennheiser HD660S2, Yamaha/Indiana Line HT on 4K |
Power Supply | Corsair HX1600i |
Mouse | Corsair M65 RGB Ultra, Logitech MX Master 3 on TV |
Keyboard | Corsair K95 Platinum, Corsair K70 Mini Pro on TV |
VR HMD | Oculus Rift S |
Software | W11 Pro |
Benchmark Scores | https://hwbot.org/user/mr_boh/ |
I agree, it's really too low, it must be 5120x2160, or at least 3840x1600!The higher resolution 45" panel isn't ready yet? 1440p at 45" is too low DPI.
