[Case Gallery] Lian-Li A05B w/ G50 side panel
aggr1103
8 (0.00/day)
Processor Athlon 64x2 6000+
Motherboard Asus M2N-Sli Deluxe
Cooling Zalman 9500AM2
Memory 2gb Crucial Ballistix Tracer DDR2 800 4-4-4-12
Video Card(s) Connect3D Radeon x1900GT (Chaintech 8800GT on the way)
Storage Seagate 160gb 7200.9
Display(s) Sony Trinitron 21" CRT
Case Lian-li A05B with G50 side panel
Power Supply Xclio Greatpower 500w modular
Specs:
Athlon x2 6000+ @ stock, Zalman 9500AM2, Asus M2N-SLI Deluxe, 2gb Crucial Ballistix Tracer DDR2-800@4-4-4-12, Chaintech 8800gt, Xclio Greatpower 500w modular, Seagate 160gb 7200.9, DVD/RW
Mods:
G50 side panel with Lian-li II side exhaust fan, Thermaltake thunderblade 120mm green led intake,removed front panel wires, stealthed dvd-rom.
G15 keyboard, G5 mouse, Sennheiser HD-555 cans, Sony Trinitron 21" CRT.
234 (0.03/day)
Brasil - São Paulo - São Caetano do Sul
System Name NOS
Processor Core Extreme QX6850
Motherboard Maximus Formula
Cooling VANTEC STING RAY CPU Block, 3x120mm fan's with Radiator, Seltz 1200lt/h
Memory 4GB Crucial Ballistix 1066MHz 5-5-5-15
Video Card(s) PCI-express ATI Radeon HD2900XT 1GB DDR4 512bits
Storage 5 HD's 160GB SATAII Seagate ST3860815AS 7200.10
Display(s) LG 22'' model 22LS4R
Case 3Rsystem's R810 with mod's for watercooler system
Audio Device(s) Supreme FX II
Power Supply ULTRA X3 1000W modular PSU
Software WINXP PRO SP3 x86
Deleted member 24505
Nice,do remember that heatpipes dont work upside down.
aggr1103
8 (0.00/day)
Thanks guys. When I added it to the case gallery I didn't realize it showed up as a forum post...plus I got an IE error. I'm adding more pics now...with better cable management.
aggr1103
8 (0.00/day)
I've heard alot of confusing arguments about whether or not they work upside down. Some folks say they don't work upside down period due to thermodynamics. Others say that wicked heatpipes will work in any orientation. I'm not sure that asus wicks their heatpipes, but what I do know is that this comp has been rock solid since I built it back in July, with no heat issues on the board to speak of.
285 (0.04/day)
System Name Dark Aurora
Processor Intel e6600 @ 4.09ghz
Motherboard ASUS Maximus Formula x38
Cooling Custom Water Cooling on Cpu and Gpu
Memory 4gb Corsair DDR-2 800mhz/ 2gb Patriot DDR-2 1066mhz
Video Card(s) XFX 8800gt 512mb
Storage 160gb Maxtor, 250gb Western Digital, 320gb Maxtor
Display(s) Dell 22" LCD
Case Gigabyte Aurora 570 (Black)
Audio Device(s) Audigy SE
Power Supply PC Power and Cooling 750W
Software Dual boot Windows XP/Fedora 8
Benchmark Scores AM3 201,045 Super Pi 12.453s @ 4.09ghz
Your cases layout confuses the hell out of me...
Where exactly do you plug the power supply into the wall?
2,228 (0.36/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
different !!!!
clean setup but you could manage cables a bit better, although the psu might be in a non convinient position...
good hardware and case...
6/10 excellent!
my rig http://www.techpowerup.com/gallery/1155.html
kane77573
50 (0.01/day)
WTF is a G50 Side panel, I don't see any side panel?????????????????????????????
pbmaster
2,588 (0.38/day)
Savannah, GA
Processor AMD Phenom II 955
Motherboard Asus Crosshair III Formula
Cooling Cooler Master V8 CPU cooler, 120 mm and 200 mm exhaust, 3 x 120 mm intake
Memory 4 GB OCZ DDR3 1600
Video Card(s) Sapphire Radeon HD 4890
Storage Western Digital 500 GB Blacks in RAID 0/ Wesdtern Digital SE16 250 GB
Display(s) Acer 19" widescreen
Case Antec Nine Hundred
Audio Device(s) Supreme X-Fi
Power Supply Seasonic M12 SS-700HM
Software Windows Vista Home Premium x64 SP2
Benchmark Scores 3dMark 03-~62k 3dMark 05-~22k 3dMark 06-18268
Nice, same mobo, CPU, and CPU cooler as me. Just one thing, why do you have the CPU cooler pointed in that direction?
aggr1103
8 (0.00/day)
Wow. Thanks for all the kind comments guys.
I was kinda surprised when I joined the forums here that there weren't as many folks into this case. One of the longest forum threads at hardforums is based around this case, and it was because of that thread and the uniqueness of the case layout that I decided to buy it for my current build.
To answer a few questions about it:
1. This is probably the smallest case in the world that will accept a full atx motherboard along with a large heatsink. That was one of the reasons I chose it. Folks have been successful at putting ultra-120's on their cpu's with no problems. In order to allow room for large heatsinks, lian li had to move the power supply to the front of the case. A proprietary power cord actually runs from the back of the case to the front and then plugs into your psu's power socket and is hidden behind the front bezel. A normal power cord is then plugged into the back and into the wall.
2. Along with the power supply being reversed in the case, the airflow of this case is reversed as well. Cool air is pulled into the case from the back and exhuasted out the front by a 120mm fan hidden behind the hard drive bay. There are air holes along both sides of the front bezel that allow for the air to exhuast. So, that's why my heatsink looks backwards.
3. The only downside to this case is that there's a pocket of hot air that develops at the top above the video card. Its not a terrible problem for me as I chose not to overclock this system, but I do like to keep everything nice and cool. Lian li makes a similar case to the A05 called the G50 which has a side panel with two sets of vents. I purchased the side panel from performance-pcs along with the lian li plus II fan bracket. The bracket sits above my pci slots and exhuasts air from the top.
Since the case is entirely made of aluminum and the size of most micro atx cases its super small and super lightweight and easy to carry to lan parties. I get tired enough lugging my 21" behemouth monitor to and fro as it is.
I'm really frustrated the more I look at my wire management. My 8800gt will be here Thursday so when I install it I will take more pictures of all sides of the case, as well as pics of it with the side panel on. Oh, and I'll tidy up the wires a bit.
aggr1103
8 (0.00/day)
Update:
Added new pics. Worked on my cable management a bit. There's not much you can do with such a limited amount of space. Also, took a pic of the front minus the bezel to show everyone how the psu is hooked up at the front. I also took a side pic of the lian li plus II fan keeping my new 8800gt cool :). Then, for everyone to see, a pic of the case with the g50 side panel.
InnocentCriminal
Resident Grammar Amender
6,477 (0.89/day)
System Name BeeR 6
Cooling Corsair H100i
Case Fractal Design Arc Mini
Power Supply Corsair HX750W
:O
How have I not noticed this before. I freakin' love this case! I recently bought it in black and I'm extremely happy with it's simplistic, yet sublime aesthetics. I'm currently sourcing parts so that I can move my current set up into it and finally use my WC kit that's been lying dormant for over 2 years.
I really need to do what you've done here and get the G50 side panel. Where did you purchase yours from? - Hopefully you'll reply. :)
