Low 4090 performance in a prebuilt, how to improve?
26 (0.07/day)
California
System Name Corsair Vengeance i7400 Prebuilt
Processor Intel i9-13900K
Motherboard MSI Z690-A WiFi DDR5
Cooling Corsair 240mm AIO, 3 front fans, 1 rear fan
Memory 64GB Corsair DDR5-5600
Video Card(s) ASUS 4090 TUF
Storage 2TB SSD
Display(s) BenQ 4K 32", BenQ 4K 27", Dell 4K 43", Dell 1920x1200 24"
Case Corsair 4000D
Power Supply Corsair 1000W 80 Plus Gold
I bought a prebuilt PC that has MSI Z690-A WiFi DDR5, i9-13900K, 4090, 64GB RAM, and 1000 Watts PSU. I ran it through Cinebench 2024 and the 4090 has a score around 30,500. The average score for 4090 should be around 34,500. I have updated all the drivers and OS. After a couple months of tuning, the GPU score is still around 31,500. I have tried GeForce Experience auto tuning and ASUS GPU Tweak III.
Any suggestions on how I can further improve it? Thanks.
freeagent
8,212 (3.72/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Get rid of all the bloatware, all of the RGB stuff, all the antivirus and other junk that they pack into it. Better yet, wipe the whole drive or use your own and install your own copy of windows.
And use the newest driver :laugh:
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
I have reinstalled Windows 11 Pro OS, updated BIOS, removed all bloatware I don't use, only Windows Defender on this PC, updated all drivers, and disabled RGB already.
freeagent
8,212 (3.72/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
I don't know much about GPUs, but that could be the difference between a 450w card and a 600w card?
18,585 (2.72/day)
System Name AlderLake
Try running 3D Mark Firestrike and compare the scores against others with the same GPU/CPU.
310 (0.75/day)
Processor AMD Ryzen 7900X
Motherboard MSI MPG X670E Carbon WiFi
Cooling Custom Loop (Watercool/HWLabs)
Memory G.Skill Trident Z5 DDR5-6000 64GB (F5-6000J3040G32GX2-TZ5K)
Video Card(s) Gainward RTX 4090 Phantom GS
Storage 7 x M.2, 4 x SSD, 2 x HDD.
Display(s) Alienware AW3423DW
Case Corsair 7000D Airflow
Audio Device(s) Logitech Z207, Shanling UA1 Plus
Power Supply Corsair HX1200
Mouse Logitech MX Master
Keyboard Logitech k360
Benchmark Scores None, but I think they'd be fairly decent.
What's the GPU temp like? Could it be throttling?
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
While running the GPU benchmark with Cinebench 2024, GPU temp's highs are in mid 50s C.
This is an ASUS TUF 4090. While using GeForce Experience to perform auto tune, GPU's max power consumption exceeded 600w.
1,229 (1.67/day)
System Name Windows
Processor 7950X3D
Cooling Arctic LF III 420
Memory 64GB 6000 CL30
Video Card(s) RTX 4090
Display(s) MSI MAG401QR
Case Asus ProArt PA602
Audio Device(s) Two Turntables and a Microphone
Power Supply Vertex GX-1000
Software Win 11
There's something else going on with the OPs performance (that I have no idea what it could be), but I have a 450w card that I run at 70% (so 315w-ish) and I get well over 35k on CB2024.
6,712 (3.03/day)
California
System Name His & Hers
Storage lots of SSD.
Same, 340w here and score 37000 ish.
Maybe the auto overclock is hurting performance try stock?
Definitely try running 3dmark timespy/firestrike
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
I ran the basic version of Time Spy. The score is shown below.
The Cinebench 2024's 30000 ish score is from using stock 4090 setting.
6,204 (4.52/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Since it's a prebuilt, check if your PC has the RAM installed in the correct slots. If it has only one memory stick, buy a 32, 48 or 64 GB kit and install them on slots A2 and B2. Double check if your memory is not running at JEDEC 4800 and instead at a more reasonable level (your low-end Pro tier Z690 will be a problem here, even my high-end MEG tier one is, but you should get at least DDR5-6000 out of it), your graphics card's temperature and the general cooling on your system. See if the card is connected through a native 16-pin (12VHPWR/12V-2x6 cable) or if it's using the quad 8-pin PCIe to 16-pin converter that comes with your GPU. If the latter, ensure that all four cables are connected securely and tightly onto the converter. If your card is running off a 3x 8-pin adapter, it will be restricted to 450 watts (which is not fully adequate for RTX 4090 - such adapters are intended for the 4080).
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
Fire Strike Score:
How do my Time Spy and Fire Strike scores look?
1,279 (2.10/day)
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Storage 512+512+1+2+2+2+2+6+500+256+4+4+4
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
I ran Cinebench 2024 again just now. The score is even lower than 30000. The Windows is set at "Ultimate" performance.
1,229 (1.67/day)
System Name Windows
Processor 7950X3D
Software Win 11
Your Timespy score shows that the Intel GPU is active. I've seen lower scores when it's enabled.
I'd suggest going into the BIOS and disabling the Intel Graphics to see if your scores in both 3DMark and CM2024 improve.
It might not make a difference, but it's worth a shot maybe.
Switch to Advanced Mode (F7) after getting into the BIOS (spam DEL key while booting), choose 'Settings, Advanced, Integrated Graphics Configuration, and then set IDG Muti-Monitor to Disabled. Then choose the X in the upper right corner and choose 'save settings and exit'
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
Thanks. I tried that and Cinebench 2024 is still below 30000.
Fire Strike Score with iGPU turned off.
Any other suggestions? Thanks.
Toothless
Tech, Games, and TPU!
9,532 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Display(s) Acer Nitro XZ342CK Pbmiiphx + 2x AOC 2425W
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Can we get a picture of the rig in question? Maybe a power connector is loose or airflow or something.
10,563 (1.71/day)
Austin Texas
System Name Planet Espresso
Processor 13700KF @ 5.4GHZ UV - 220W cap
Motherboard MSI 690-I PRO
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Mouse Xlite V2
Keyboard 65% HE Keyboard
Is rebar enabled?
Can you post a GPU-Z when the card is running Cinebench?
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
It is a Corsair Vengeance i7400 with their Corsair 4000D Airflow case. Its airflow should be pretty good. I'll check the connector later.
VENGEANCE i7400 Gaming PC, i9-13900K, RTX 4090, 2TB M.2, 64GB DDR5-5600 (corsair.com)
4000D AIRFLOW Tempered Glass Mid-Tower ATX Case — Black (corsair.com)
Is rebar enabled?
Rebar is enabled.. 5 minutes into Cinebench 2024:
3,165 (0.54/day)
System Name White Theme
Processor Intel 12700K CPU
Motherboard ASUS STRIX Z690-A D4
Cooling Lian Li Galahad Uni w/ AL120 Fans
Memory 32GB DDR4-3200 Corsair Vengeance
Video Card(s) Gigabyte Aero 4080 Super 16GB
Storage 2TB Samsung 980 Pro PCIE 4.0
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Lian Li O11 Dynamic EVO White
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair HX 1000 Platinum
Have you tried turning on XMP Profile 1 in the BIOS? Just brain stormin
807 (1.41/day)
System Name BarnacleMan
Processor 14700KF
Motherboard Gigabyte B760 Aorus Elite Ax DDR5
Cooling ARCTIC Liquid Freezer II 240 + P12 Max Fans
Memory 32GB Kingston Fury Beast
Video Card(s) Asus Tuf 4090 24GB
Storage 4TB sn850x, 2TB sn850x, 2TB Netac Nv7000 + 2TB p5 plus, 4TB MX500 * 2 = 18TB. Plus dvd burner.
Display(s) Dell 23.5" 1440P IPS panel
Case Lian Li LANCOOL II MESH Performance Mid-Tower
Audio Device(s) Logitech Z623
Power Supply Gigabyte 850w
Are we sure its running on 16 pcie lanes?
Solaris17
Super Dainty Moderator
26,638 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
I’m mobile but if it’s prebuilt watch the CPU temps and clock rate corresponding to said temps.
Also comparing overall score is a joke. Look at the cpu and GPU scores independently they will both be down if one of the devices isn’t pulling its weight but the one causing issues should be lower still.
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
I don't know enough about this area. I went to BIOS menu and did a screenshot. Please see attached file and let me know how I should proceed.
How do I check? Thanks.
807 (1.41/day)
Processor 14700KF
Should be here in gpu_z, you might have to press that little question mark button to get an accurate reading.
26 (0.07/day)
California
Storage 2TB SSD
Case Corsair 4000D
Yes, it is x16.
Cinebench 2024's GPU test focuses only on GPU. The CPU utilization and temp were both low while doing the GPU benchmark.
