MAINGEAR Announces EPIC 180 Liquid CPU Cooler System
ChrisMorley
16 (0.00/day)
i prefer thicker rads because in reality they can dissipate far more heat, then a thin rad and depending on the component take longer to saturate with heat. also im running 2x Delta 115cfm 3300rpm fans on a TT FRIO, noise isnt a problem lol enthusiast 1st practicality 2nd
still would rather see a 200mm rad since alot of cases are pushing larger fans or maybe an adaptor kit for the 180 rad to use 200mm fans :toast: eitherway dosent help me im not buying a full rig to get a all in one water kit that mildly interests me, also i want hard #s and comparisions when it you say beats a 240mm rad. example put it up agains the Antec Kuhler 920 or XSPC Rasa 240 kit. You'll have to pardon the fact i dont believe it unless i see it reviewed, and since its maingear exclusive i wont get to see a review of said 180mm all in one kit. kinda sad. i like numbers.
Well, I just gave you hard numbers, if you don't want to believe them, not my problem. ;)
crazyeyesreaper
Not a Moderator
9,835 (1.68/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
i want temps overclocked temps vs other coolers and water kits. etc if i cant see the actual cooling performance why should i be interested in your product, thats like someone trying to sell me a square saying its a wheel but wont let me try and roll it lol
crazyeyesreaper
Not a Moderator
9,835 (1.68/day)
Keyboard Mionix
i7 920 stock vs 3.6ghz vs 4ghz speeds with temp testing thats more valuable then Thermal resistance ive seen many coolers with good thermal resistance fail to beat out cheaper and supposedly shittier coolers, so not impressed by Thermal Resistance numbers.
ChrisMorley
16 (0.00/day)
Well I guess there's no satisfying some people then! :)
crazyeyesreaper
Not a Moderator
9,835 (1.68/day)
Keyboard Mionix
of course not if i was satisfied with pc hardware i wouldnt upgrade now would I ;)
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
It's not unreasonable to prefer real world numbers to performance estimates. Hows the base shape? How much mounting pressure? Will there be a performance hit with adapters? As I can't think of many cases with 180mm fan support, one of the main reasons I'd rather have a thicker rad if it improves performance. At least it would fit, but who would even want the 120mm version after having that 20% increased performance for less noise bit dangled in front of them? Your target is enthusiasts after all. Hopefully you'll have significant price differences between them to make people feel better about having the weakest model.
5,653 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
from what I've seen Maingear tend to use alot of SilverStone cases FT01 and RV02 both of which come with 180mm fans hence why they wanted an 180mm rad because it just fits no adapter or frigging round
Mussels
Freshwater Moderator
58,412 (7.79/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
i bet that makes silverstone users happy. now i just need me a 140mm version to make my coolermaster case happy...
4,016 (0.66/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
I still need a 250mm one to make my case happy >.>
edit: As far as using this with a 200mm fan, I don't see how that would be too difficult with some minor modding. I bet you could do it with nothing more than a few zip-ties.
