Mobility Radeon HD 4870 X2 Days Away From Clinching Top Spot
wolf
Better Than Native
8,429 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
7,228 (1.07/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
Are there any technical specifications for this? How does the mobility version compare with the desktop version?
If this is an ultra low voltage device then how about some enterprising company sticks two of these in crossfire on a PCIe16 board with passive (or at least, silent active) cooling. :pimp:
PCpraiser100
1,062 (0.18/day)
System Name REBEL R1
Processor Core i7 920
Motherboard ASUS P6T
Cooling Stock
Memory 6GB OCZ GOLD TC LV Kit 1866MHz@1.65V 9-9-9-24
Video Card(s) Two Sapphire HD 5770 Vapor-X Xfire'd and OC'd (920/1330)
Storage Seagate 7200.11 500GB 32MB
Case Antec Three Hundred
Audio Device(s) ASUS Xonar D1 PCI Sound Card
Power Supply OCZ StealthXStream 500W
Benchmark Scores 16585 Performance Score on 3DMark Vantage
Next thing is that Alienware will practise using Nuclear Reactors as laptop batteres!!! :D
cdawall
where the hell are my stars
27,683 (4.09/day)
Houston
System Name Moving into the mobile space
Processor 7940HS
Motherboard HP trash
Cooling HP trash
Memory 2x8GB
Video Card(s) 4070 mobile
Storage 512GB+2TB NVME
Display(s) some 165hz thing that isn't as nice as it sounded
lol can you imagine the size of the power brick for this thing
298 (0.05/day)
Japan
System Name Main
Processor e7200 Wolfdale 2.5Ghz OC @ 3.0
Motherboard BioStar TP43D2-A7 ATX Board
Cooling ARCTIC COOLING Freezer 7 Pro 92mm
Memory 4G's G.Skill PC 6400 800 Mhz
Video Card(s) ATI Sapphire HD 4870 10.6 drivers
Storage WD 80GB/WD 160GB SATA 3.0 Drive / WD 1TB
Case COOLER MASTER Centurion
Power Supply Japanese Brand 550w
Software Windows 7 64 Ultimate
Benchmark Scores 3DMark06 10712- Old score 3DMark06 10955- New Comp
This comic strip came to mind. Replace Mac Air Book with this one.
Hot Laptop
DrPepper
The Doctor is in the house
7,482 (1.20/day)
Scotland (It rains alot)
System Name Rusky
Processor Intel Core i7 D0 3.8Ghz
Motherboard Asus P6T
Cooling Thermaltake Dark Knight
Memory 12GB Patriot Viper's 1866mhz 9-9-9-24
Video Card(s) GTX470 1280MB
Storage OCZ Summit 60GB + Samsung 1TB + Samsung 2TB
Display(s) Sharp Aquos L32X20E 1920 x 1080
Case Silverstone Raven RV01
Power Supply Corsair 650 Watt
Software Windows 7 x64
Benchmark Scores 3DMark06 - 18064 http://img.techpowerup.org/090720/Capture002.jpg
I want this NOW !!!
OnBoard
3,033 (0.45/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
8,523 (1.36/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
I want this NOW !!!
I want one too. Too bad I dont have $2500 to drop on a new gaming setup. :cry:
I just want to see a retailer/reseller that has it available.
3,185 (0.54/day)
System Name White Custom Loop Fractal North XL
Processor Intel Ultra 7 265K
Motherboard ASUS STRIX Z890-A GAMING WIFI
Cooling AlphaCool Core 1 White CPU Block - 2x Heatkiller 360-L - Alphacool Core 120mm Resevoir
Memory 48GB 7200Mhz Corsair Dominator DDR5
Video Card(s) Pending
Storage 4TB WD Black NVME Gen 4
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Fractal North XL Chalk White Mesh
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair RM1200x Shift White
I'm more interested to see how the laptop is going to survive! Its like putting a v16 engine on a bicycle rofllll.
Hopefully their battery life and heat workarounds make us go wow too :)
DrPepper
7,482 (1.20/day)
System Name Rusky
Me neither and it better be available in the uk :p
3,779 (0.64/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
it kick ass my current setup which is 89999 time bigger :eek:
2,143 (0.37/day)
System Name THE MAD BEAST!!!
Processor Tinfoil rapper with some coathangers
Motherboard Graham cracker with with frosting
Cooling A shovel full of snow
Memory Grey matter out of a corpse
Video Card(s) Cat eyes
Storage A whales brain
Display(s) Cyclops eyeball
Case Inside a yetis hollowed out corpse
Audio Device(s) howling banchee
Power Supply 32 hamster on a massive wheel
Software WHo needs software when you have a box of kittens
Benchmark Scores IS gatrillions a number?
it probably uses a 12 cell battery which would probably power a system like that for about 3-5 hrs depending on what you were doing
7,185 (1.15/day)
Adelaide Australia
System Name Becca 2
Processor AMD A10 4600m quad core @ 2.3 ghz
Motherboard dunno
Cooling Logitech alto connect
Memory 16 Gig ddr3 1600mhz
Video Card(s) Ati HD 7660G + & 7470M
Storage 1 TB
Audio Device(s) onboard crap
Software Windows 7 Home Premium 64 bit with sp1
And to think mine does if your lucky 3k in 06 that is amazing ofcourse overheating would be a killer but still mightily impressive for a lappy.
frankie827
541 (0.08/day)
connecticut
System Name Gaming PC
Processor Core 2 Quad Q6600 B3@3.3ghz @ 1.376V | VID: 1.313V
Motherboard Evga Nvidia Nforce 680i LT SLI
Cooling 7x 12cm case fans+Xigmatek HDT-s1283 Dark Knight
Memory 4gb DDR2-800 Corsair XMS2
Video Card(s) 896mb Evga GeForce GTX 260 Core 216 (720/1515/1135)
Storage 2x 160gb Seagate Baraccudas + 1x 640gb Western Digital Caviar Green + 1x 1tb Samsung F1
Display(s) Sceptre 20.1" 1080P Widescreen
Case NZXT Zero
Audio Device(s) Creative Soundblaster Audigy SE+Creative Fatal1ty Headset/Logitech X-530 5.1 Surround
Power Supply Silverstone Zeus 750watt
Software Vista Home Premium 32-Bit
Benchmark Scores 15883 on 3dmark06 w/ windows 7 beta @ 3.3ghz 13188 on 3dmark vantage w/ windows 7 beta @ 3.2ghz
asdglkjasd;ljgk
it's better than my desktop :(
7,185 (1.15/day)
Adelaide Australia
System Name Becca 2
Motherboard dunno
Storage 1 TB
Its better than most ppls desktops here. :p
Couple that with nehalem mobile processor that intel will release later in the year and it will be king insane. :twitch:
frankie827
541 (0.08/day)
connecticut
Case NZXT Zero
please excuse me while i go cry in the corner.
i thought it would be much longer before i saw a laptop that was better than a desktop :eek:
47,449 (7.50/day)
over 99% of us wont buy mobility gear anyway, so meh, unimpressed.
as for ATi "snatching" the crown back off nvidia, hardly. :laugh:
Guess what, 99% of us don't buy the HD 4870 X2s and the GTX 295s either, so keep your impressions to cheaper cards, going by that logic. Yes, ATI snatches the performance crown. Pit two desktop 8800GTs in x8 x8 SLI against a HD 4870 X2, using a Yorkfield @ 4 GHz, and you will have an identical test-bed to prove the performance difference.
Two of those boards you see (1st pic) installed on a system with X38 chipset (providing x16 links to each board). There is no lane-arbiter (like the PLX chip on the desktop card). Each board holds a RV770 GPU with 512M/1G of GDDR5 memory. Speeds are 600/900 MHz (core/mem). With this it ends up as the fastest solution. I'm not 100% sure of these specs, so I didn't mention it in the news.
43,393 (6.75/day)
just to put this out there, the Mobility parts i believe are put thru more stringent testing due to chassis constraints and coolin apparatus, and they are usually built upon the latest process, because for one my Inspiron XPS Machine had a 9800 256 and that was built using the R420 Core.
8,523 (1.36/day)
Kansas City
Processor 9800x3D
Software Win 10 64x
The thing's gonna weigh 50 lbs and 40 of it will be the heatsink :p
43,393 (6.75/day)
not much different than the SLI cards for Laptops.
6,959 (1.04/day)
Australia, Sydney
Wonder why they've never thought of a desktop system only utilising laptop parts?... its cheaper and smaller...
43,393 (6.75/day)
proprietary, they also have to account for power differences etc, atleast today, now back in the day with SKT A that was possible.
5,966 (0.94/day)
New York
Processor AMD Ryzen 9 5950x, Ryzen 9 5980HX
Motherboard MSI X570 Tomahawk
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 32Gb Crucial 3600 Ballistix
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Phanteks P500A
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus
Unlike most of nvidia's mobile cards which are cut down, ATI almost never releases mobile GPU's that aren't the same as the desktop versions so I am guessing spec wise its the same as the desktop version but has a lower clocks and voltage on the memory and gpu.
It might also use DDR3 instead of DDR5 also.
5,250 (0.86/day)
IRAQ-Baghdad
System Name MASTER
Cooling Corsair H100i
Video Card(s) 2X EVGA GTX680
Case CoolerMaster Chosmos II
Software Win7 64bit Ultimate
i gonna throw my desktop , OMG this is great gamer laptop ever
7,185 (1.15/day)
Adelaide Australia
System Name Becca 2
Motherboard dunno
Storage 1 TB
it will be heavy alright great for weightlifting. :D:p
