Mod and Max out Asus G750 laptop.
aQi
647 (0.19/day)
Hey folks,
its been a while. I had been going through alot and now i want to put myself together.
I want to pick where i left. I have Asus G750jm with a faulty graphics card. I am thinking of modding it and pushing it to the limits.
Two SSD in raid mode
Max out ram
Gtx880m 8gb (need confirmation if it will work)
Mainboard replacement (with 3d support)
120hz 3d screen.
Body modification (color+Rgb led)
Keyboard rgb color change (not sure)
Battery replacement.
Processor upgrade (reballing)
or simply look for the g750jh model with 3d panel and mainboard ?
13,940 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
It looks like that notebook has been around for at least 6 years. I see no reason to put that kind of money into a computer that old. Plus, notebooks in general just aren't designed to support mods and upgrades. Your options would be very limited, at best.
So if me and if mobility was not a necessity, I would put my time and money into building a new quality PC, a computer that is designed to support years of evolving upgrades. If having a mobile computer is absolutely essential, I'd be shopping for new notebook.
dgianstefani
TPU Proofreader
5,440 (2.04/day)
Swansea, Wales
Benchmark Scores Legendary
Waste of time.
You could buy a brand new system for $600 that would perform better.
aQi
647 (0.19/day)
Waste of time.
yeh thought of that too. But depends upon what i can get.
Its specs are:
I7 4710HQ
8gb Ram
500 SSHD
250 HDD
Geforce gtx765m
13,940 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Well, of course! But with just a tiny bit of homework, it still would not be hard to find a brand new notebook for $600 that would perform better than what you have now.
With your current hardware being 6 years old, even if able to upgrade some of the components, the rest would still be 6 years old. This would include the motherboard, battery, charger, drives, keyboard and monitor.
There is no ATX Form Factor standard for notebooks. You just can't swap everything out of notebook case like you can with an ATX compliant PC case. Notebooks are just too proprietary.
  • Sad
Reactions: aQi
aQi
647 (0.19/day)
that was the reason it kept sitting in the store for a while. It does perform but not particularly a desktop replacement.
keeping in mind. I just wanted some extra to get it going but looking at ebay its going to be expensive.
6,396 (0.87/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Put that ancient broken trash in the trash can where it belongs.
13,940 (2.04/day)
Nebraska, USA
Mouse Logitech M190
"Some extra to get it going"? Ummm you were talking about replacing the the motherboard, CPU, graphics, adding RAM and even modifying the case. That's a LOT more than "some extra"!
785 (0.22/day)
System Name Fat NCASE
Processor Ryzen R9 3900X
Motherboard ASUS TUF GAMING B550M ZAKU (WIFI) Edition
Cooling Scythe Fuma with 3 SCYTHE Wondersnail 2400RPM + Arctic MX2
Memory Corsair Vengeance 128GB @3200Mhz Cl16 (32GB X 4)
Video Card(s) Palit RTX 3060 StormX ITX 12GB
Storage MX500 4TB SATA + Toshiba MG08 16TB HDD
Display(s) LG 27UL500 4K monitor
Case Jonsbo W2 black
Audio Device(s) Onboard realtek 1200 & Soundblaster G3 usb
Power Supply ASUS ROG STRIX 850W Gundam Edition
Mouse Elecom wireless mouse :)
Keyboard RK100 Royal Kludge
Software Windows 10 HOME
Benchmark Scores Don't know any benchmark. It runs good enough for me.
Laptop upgrade is only worth it when it is functioning, since you said many parts is no longer functioning I don't recommend. It depends if you find spare parts for cheap in aliexpress or ebay. If the parts are cheap then maybe. I took a look at aliexpress the parts i found make it not worth it. Better getting a new laptop or a functioning 2nd hand one.
  • Like
Reactions: aQi
2,274 (0.97/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
i see no reason for upgrading that lappy mate, get yourself a new one or better still build yourself a ryzen desktop if you have the room, in my view id be wasting my money when it could go to something better bro.
  • Like
Reactions: aQi
aQi
647 (0.19/day)
TBH i like modding things. Not just any modding but upto the very end.
The processor reballing depends if i get another performance part in cheap. Reballing is not an average person’s DIY.
For the gfx thats pricy. The gtx880m 8gb which is the last and final upgrade for g750. Not sure where would that go from here.
I appreciate your research on Ali Express and i did that myself. Those parts are still more expensive then what i have in mind.
P.S. The g750 i have is in working order.
You are right. Threadripper is always on my mind or Ryzen 4th Gen. Yet i have alot of hardware and i mod things around. The worst things i lost my legs for atleast a few months from now.
g750 isnt a bad lappy. People owing it are still satisfied. The best thing is not to upgrade but to mod it then
