Monitor power cable making some sort of buzzing noise
52 (0.02/day)
Processor AMD Phenom X4 9950
Motherboard ASRock K10N78
Memory 4.00 DDR2
Video Card(s) NVIDIA Geforce GTX 750 Ti SC
Case Cooler master
It's not exactly a buzzing noise, it's more like a crackling noise... it happens when I push in the cable and or take it out
My monitor is the
ASUS VG248QE 24" 1920x1080 TN Widescreen 144Hz 1ms Gaming LED Monitor - Black
I only got the monitor for my christmas, so I doubt it was that
13,053 (1.95/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
It is important to understand that monitors are not "hot swappable". That is, monitors and graphics cards are not designed to have the cables connected or disconnected when the computer or monitor is powered on. It is quite possible you accidently caused a short by causing two wrong pins to come into contact with each other, causing permanent damage to the card, monitor, or both. :(
There is no solution for this - only a strong recommendation to stop doing that! Power off the computer and unplug it from the wall. Then securely connect the cable and leave it alone.
newtekie1
Semi-Retired Folder
28,473 (4.11/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
That depends on the connection used, I know HDMI is hot pluggable. I'm pretty sure Displayport is too.
13,053 (1.95/day)
Nebraska, USA
Mouse Logitech M190
I keep hearing different things so I err on the side of caution. I note here it says with a "Warning!!..... to never connect and disconnect HDMI cables while the devices are powered on.
I note "in theory" HDMI should allow hot swapping. But it assumes the cables are wired properly and not damaged. Same with the device's connector.
In any case, I should have been more clear. Thanks.
10,885 (1.58/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.47/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
The only connection type in use today that, in theory, isn't hot-pluggable is VGA. In practice, it usually is. DVI/HDMI/DisplayPort are all hot-pluggable.
qubit
Overclocked quantum bit
17,865 (2.89/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
This thread is about the power cable - see thread title.
A certain amount of crackling is actually normal when plugging/unplugging, but an excessive amount means a loose connection so the power cable should be swapped out then. This is especially true if it crackles just by wobbling the connector slightly.
It's actually OK to connect and disconnect video cables of any type with the PC and monitor on. At most, the PC would need a reboot if it doesn't detect the monitor properly.
newtekie1
Semi-Retired Folder
28,473 (4.11/day)
Indiana, USA
Oh shit, you're right! Yeah, a little crackle is ok when first connected, but it shouldn't do it all the time.
13,053 (1.95/day)
Nebraska, USA
Mouse Logitech M190
41,913 (6.61/day)
make sure monitor isnt turned on, stop plugging it in and taking it out. plug in monitor at the monitor first then at the wall
95Viper
Super Moderator
12,944 (2.21/day)
If you are sure it is the ac power cable that is buzzing, crackling, or making any noise... replace it. Chances are it has a defect, if it does as you state.
If you are like most you should some three prong ac power cables laying around... test it with another one.
Also, make sure you are getting securely plugged in at both ends.
Taylor mackie51
1 (0.00/day)
I've noticed none of these solutions worked for me and I had the problem today and this thread was In the top results so i would like to say what worked for me
Step 1: unplug the power cable and turn it off at the plug
Step 2: plug everything back in including the power cable that is off
Step 3: turn everything back on
9,401 (3.29/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Pretty much impossible for that to happen with connectors like HDMI or DP, the pins do not stick out and it's actually quite difficult for them to come into contact with anything else.
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
This is exactly what should happen and there's nothing wrong with your monitor. You'll get the crackling whether the monitor is on or off (standby).
The noise is the sound of arcing, which happens when you make or break a circuit. It will be louder and more obvious when you disconnect the monitor while it's running. You don't wanna do this, because that arcing represents large voltage spikes which aren't good for it. If the conductors were exposed, you would likely see small sparks too. This arcing effect is caused by induction, which is the opposite of capacitance. Have a Google if you wanna know more about it. :)
You don't see this arcing effect with signal cables plugged/unplugged, because the current and power are really tiny.
8,195 (2.18/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
the crackling could be a build up of static electricity, or, there might be some internal bare wires that might too close together causing a spark. Suddenly applying power can do it too
13,053 (1.95/day)
Nebraska, USA
Mouse Logitech M190
It is easier than you think. While I agree they are designed specifically to minimize the possibility of such occurrences, that does not stop some users from using too much force when not properly aligned and the connectors don't just slip in.
Note too this 5 month old dormant thread is about the power cable. Not HDMI or DP. Regardless, I stand by what I said. And please note I said it was "possible" not that it was "likely".
13,791 (1.88/day)
That's just absurd nonsense. Monitors can be connected or disconnected at any time. Be it VGA, DVI, HDMI or DisplayPort connection.
As for the crackling, signal cables still have certain power going through, if cable is bad it's possible there is something shorting or causing slight induction effect or something. Get a new quality cable. Or if you already have some other, try it.
13,053 (1.95/day)
Nebraska, USA
Mouse Logitech M190
In theory, yes. In practice, not always. FTR, the VGA standard does not require they be hot swappable. And for sure not all cables are made equally. Also, it is not uncommon for monitors to lose sync.
While in theory, no damage is likely, it is still good practice to at least power down the monitor before yanking out cables.
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
Everyone, why are you talking about video cables? The OP is talking about the power cable to his monitor (see thread title) and I gave him the definitive answer in post 14. Check it out. :)
2,350 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
didn't realize this was a necro, I withdrew my comment but so much wrong info from bill doesn't matter how many times you use "in theory", "possible" it's still wrong or highly unlikely. HPSD have been in the HDMI/DP specs since ver.1 and the connectors are recessed and keyed.
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
Duh, neither did I! And what's more ridiculous is that I'd posted in it back in 2016, see post 7. :laugh:
Jesus F
3 (0.00/day)
So if my monitor power box makes a rattle, there’s nothing wrong with it?
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
That’s kinda vague, can’t tell anything by that. If you have a technical problem that you want help with, you’re better off starting your own thread.
Jesus F
3 (0.00/day)
Well what the guy described what was happening is the same thing I’m experiencing but I just wanted to be sure that what you put on your post was basically that the rattle is normal
qubit
17,865 (2.89/day)
Quantum Well UK
Keyboard Yes
The slight crackle as you plug in a power cable that’s connected to the mains is normal, yes. It’s caused by arcing, which should be kept to a minimum.
