- Jul 25, 2006
- 13,667 (2.02/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
It is common if that sound is coming from the power connector (the plug prongs or inside the wall receptacle) itself as it is plugged into, or pulled from the wall - if truly "slight" and you don't see any sparks. Not sure I would call it "normal" however. I recommend you be more deliberate (and quick) when plugging in and unplugging. Arcs (sparks) occur as the two conductors come near or move away from each other. The faster you are, the less chance of an arc - or at least you hopefully minimize it to one smaller arc.The slight crackle as you plug in a power cable that’s connected to the mains is normal, yes.
Arcs are not good because they result in carbon buildup where the arc jumped across the gap and made contact with the other conductor. Carbon is the basic component of resistors. Over time, that carbon buildup can result in failed connections, or even excessive heat. Not good.
If your power cord looks like this where there is some distance between the wall connector and the AC/DC transformer so you can easily tell for certain that the "slight crackle" is coming from the transformer and not the power plug, that is NOT normal at all and the power supply needs to be replaced ASAP.
I would also recommend you check your wall outlets. Every home and every computer user should have access to a AC Outlet Tester to ensure your outlet is properly wired and grounded to Earth ground. I recommend one with a GFCI (ground fault circuit interrupt) indicator as it can be used to test bathroom and kitchen outlets (outlets near water) too. These testers can be found for your type and voltage outlet, foreign or domestic, (like this one for the UK) at most home improvement stores, or even the electrical department at Wal-Mart. Use it to test all the outlets in the home and if a fault is shown, have it fixed by a qualified electrician.
