MSI GeForce GTX 660 Ti Power Edition 2 GB
4,815 (0.75/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
Yea i know, ive looked at NZ many times for parts since our dollar is kickin butt at the moment and your prices are still crazy :confused: Gotta feel sorry for you guys.
I think it's more to do with the retailers than anything thing else and are probably tryng to justify the price for the card by the current price of the 560 Ti.
But still there is no good reason for the graphics card to be so high in comparison to AU sales prices.
42,609 (6.67/day)
sounds to me the max clock cap is 1080 core because after that u lose fps. its ok because on my laptop it happens after 459mhz from 350 stock on gpu
762 (0.13/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
So we've learned from this review what was already apparent.
7970: Great for compute and has bandwidth to back abundant shaders. Those same shaders and bandwidth/buffer in comparison to ROPs hurts power efficiency in gaming, and size/power requirements hinder potential market. Since it has more-than-enough of everything (for it's ROPs) and enough tdp to max out the process, it can justify it's price through unique abilities (bigger buffer for high-rez, greater compute/dpfp for gpgpu, absolute performance) for those willing to take the size/energy trade-off.
680: Very smart chip for spfp/1080p, but the no-waste design hurts yields and increases price given the state of 28nm during its (initial) lifespan.
670: 1344 (1568) Strictly shader/SFU limited versus 680...but better yields hence lower price. Slightly less optimal shader/rops and shader/bandwidth efficiency.
7950: 1792sp is an optimal design considering the ROP count (like 680) for gaming and smart choice for the mainstream performance part because it is using a salvage design on a new process; too much bandwidth/buffer hurts power efficiency/form factor but is a side-effect of 7970's strengths (even if niche). Clocks great because of high tdp and low-voltage binning.
660ti: 1344 (equivalent of 1568), efficient mix of rops, ram, bandwidth, and shaders and clockspeed potentials...hampered by overall units vs 7950 but better than 7870, tdp (clockspeed) and bandwidth limitations beyond ~1100mhz/7000 create a 'bottleneck' that actually fits with the design/market. It's a smart salvage chip considering the power consumption and clocks for ram on the smaller bus with less rops and the minimum clock to expect from the 28nm process (like an AMD xx50 part at default voltage).
7870: 1280sp. Efficient mix of bandwidth, shaders, ram, and clockspeed potentials. Clocks great and with great performance efficiency because of 170w tdp coupled with low-speed (but capable enough for the shaders at high clock) ram on a very small chip with a 256-bit bus. Hampered by lack of shaders vs. ROPs.
In essence...they all play different angles and show where each company is compounding their efforts and expectations. Judging purely on IPC/capabiities, 7950 is a great performance card. 660ti is a great gamer card. 7870 is a great point-of-entry for 1080p. Although I think the 660ti could shed $20 considering the price of the competition, it's smaller and more energy efficient. If you think purely in those terms...that's probably worth it. Some will like the over-all more robust potential of 7950 or the capabilities/$ of 7870. Not a bad choice in the bunch...but I still wait patiently for an AMD version of gk104 to drive prices down and performance/efficiency/form-factor/$ up.
42,609 (6.67/day)
it would appear to me the other boards are being pushed too hard beyond physical and electrical boundries hence the performance hit on the others and the gain this card has. GJ MSI!
W1zzard
Administrator
27,963 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
if you push a card like that it will be unstable, not slower. msi did something to their bios to improve performance.
Arska
13 (0.00/day)
From the conclusion:"The new GTX 660 Ti is almost twice as fast as the last-generation GTX 560 Ti, but comes at a $50 higher introductory cost."
50% faster according to my calculations and even the MSI card is way off from being twice as fast.
42,609 (6.67/day)
instability causes a perf hit initially before crashing i learned this with an m18 gc. 109 mhz clock increase for core 116 mhz increase for ram from stock of 350 300 was the top before artifacts frame loss
75 (0.02/day)
Hamilton, Ohio
System Name Enforcer
Processor i5 3570k
Motherboard ASrock Z77 Extreme4
Cooling Cooler Master Hyper 212 evo
Memory 8gb G.skill Ripjaws X 1600
Video Card(s) EVGA SC GTX 780 3gb
Storage Samsung 840 Evo 250gb SSD, Seagate Barracuda 1TB
Display(s) Asus VH226h 21.5" LCD (1920x1080)
Case CM Storm Enforcer
Power Supply Rosewill Hive 750w
Mouse Logitech G9x
Keyboard Corsair k70
Software Windows 7 home premium 64-bit sp1
Finally made the decision to go with this card for my 660ti, this review made me pull the trigger just bought it.
Bengali
2 (0.00/day)
What are the exact settings that Heaven 2.0 was run at in the review? I want to do a test run on my 7870 clocked at 1200Mhz core/1400Mhz memory to do a comparison to this card.
1 (0.00/day)
System Name PaZoT
Processor Intel(R) Core(TM) i7-3770 @ 3.40GHz 8Mb
Motherboard Asus P8B75-M LX Plus
Cooling Stock
Memory Corsair Vengeance 4Gb 1600 9.9.9.24
Video Card(s) MSI GTX 660 Ti 2Gb Power Edition
Storage OCZ Vertex 4 80Gb
Display(s) Samsung S22C300
Software Windows 7 Ulitmate x32=((
In the screen
it is written that the video card in idle mode operates under 32 degrees.
In fact, it is much colder, http://prntscr.com/6bjn2w What do you say?
42,609 (6.67/day)
Do you realize this threads almost 3 years old.
