MSI Teases Transparent TwinFrozr Cooling Solution
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
transparent stuff tends to change their color in long term and its kinda hard to clean if like that, i prefer solid surface or add transparent as accent
536 (0.10/day)
Bahrain
System Name Lazyman 9000+
Processor AMD Ryzen 7 3800X
Motherboard X570 Aorus Ultra
Cooling Arctic LF II 280
Memory 2x8GB Crucial Ballistix 3600 MHz DDR4
Video Card(s) PowerColor Red Devil 5700XT
Storage Never Enough
Display(s) ASUS VG248QE+ Dell E2420H
Case LIAN LI Lancool II Mesh RGB
Audio Device(s) Sennheiser HD518 / Logitech Z623
Power Supply FSP AURUM PT 850W
Mouse Logitech G600
Keyboard Logitech G810 Orion Spectrum
Software Win 11
Benchmark Scores All over the bench
Interesting choice. Substituting a heat absorbing metal shroud with a plexi one that doesn't.
But the shroud on my bro's 760 Gaming is plastic already? :wtf:
maybe they did the switch to plastic since TF4 but i don't think the shroud could or should dissipate heat
1,164 (0.20/day)
Chicago, Illinois
Well...there's a thing called heat soak. The plastic might actually be better to prevent that. However, I highly doubt you'd see much a difference at all. The only benefit about seeing under that shroud would be knowing when to pull it out and use compressed air to blow out all the dust. It would be nice if companies lowered their prices due to the cheaper cost of materials BUT we all know that probably won't happen.
30 (0.01/day)
System Name Gaming rig
Processor AMD ryzen 7 2700x
Motherboard gigabyte b450 aorus pro
Cooling AMD wraith prism
Memory Asgard 2x16gb ddr4 3200mhz cl16
Video Card(s) Asus tuf 1660 3X fan
Storage 2TB HDDs + samsung 850 evo 128gb sata SSD + silicon power A80 1TB nvme SSD
Display(s) Viewsonic xg2405 24" 144hz
Case Cooler master H500p
Audio Device(s) on-board
Power Supply Corsair RM1000i
Mouse Razer viper
Keyboard Cooler master devastator 3
Software windows 11 x64 pro
like to see this with some red LEDs
3,516 (0.48/day)
System Name Red Matter 2
Processor Ryzen 5600X
Motherboard X470 Gaming Pro Carbon
Cooling Water is Masterliquid 240 Pro
Memory GeiL EVO X 3600mhz 32g also G.Skill Ripjaw series 5 4x8 3600mhz as backup lol
Video Card(s) Gigabyte Gaming Radeon RX 6800
Storage EVO 860. Rocket Q M.2 SSD WD Blue M.2 SSD Seagate Firecuda 2tb storage.
Display(s) ASUS ROG Swift PG32VQ
Case Phantek P400 Glass
Audio Device(s) EVGA NU Audio
Power Supply EVGA G3 850
Mouse Roccat Military/ Razer Deathadder V2
Keyboard Razer Chroma
Software W10
Clear with the option to change LED back-lighting...Red, Blue, White and UV. Then maybe...
3,317 (0.52/day)
System Name Thakk
Processor 9800X3D
Motherboard MSI B650M Gaming Wifi
Cooling Id Cooling A410 + P12 Max 3300 RPM
Memory 32GB DDR5 6000 C30
Video Card(s) Zotac RTX3080 Trinity
Storage Crucial NVME 512 / Intel 250GB SSD / Samsung Pro 512 SSD / SanDIsk 1TB SSD / WD Black 6TB
Display(s) Acer Predator X34 100hz IPS Gsync
Case Generic mATX
Audio Device(s) Hyper X 7.1 USB Soundcard
Power Supply Corsair CV750 Bronze
Mouse Logitech G304
Keyboard Monsgeek MG75S Hall Effect + XDA Keycaps + Holee Mod
VR HMD HTC Vive
Software Windows
Benchmark Scores https://www.3dmark.com/3dm/123890762?
Glad they didn't tag that transparent plastic into some kind of new space tech complete with a frivolous title like "Iced View Cool Tech" or something like that.
1,927 (0.42/day)
UK
System Name TITAN Slayer / CPUCannon / MassFX
Processor i7 5960X @ 4.6Ghz / i7 3960x @5.0Ghz / FX6350 @ 4.?Ghz
Motherboard Rampage V Extreme / Rampage IV Extreme / MSI 970 Gaming
Cooling Phanteks PHTC14PE 2.5K 145mm TRs / Custom waterloop / Phanteks PHTC14PE + 3K 140mm Noctuas
Memory Crucial 2666 11-13-13-25 1.45V / G.skill RipjawsX 2400 10-12-12-34 1.7V / Crucial 2133 9-9-9-27 1.7V
Video Card(s) 3 Fury X in CF / R9 Fury 3840 cores 1145/570 1.3V / Nothing ATM
Storage 500GB Crucial SSD and 3TB WD Black / WD 1TB Black(OS) + WD 3TB Green / WD 1TB Blue
Display(s) LG 29UM67 80Hz/Asus mx299q 2560x1080 @ 84Hz / Asus VX239 1920x1080 @60hz
Case Dismatech easy v3.0 / Xigmatek Alfar (Open side panel)
Audio Device(s) M-audio M-track / realtek ALC 1150
Power Supply EVGA G2 1600W / CoolerMaster V1000 / Seasonic 620 M12-II
Mouse Mouse in review process/Razer Naga Epic 2011/Razer Naga 2014
Keyboard Keyboard in review process / Razer Blackwidow Ultimate 2014/Razer Blackwidow Ultimate 2011
Software Windows 7 Ultimate / Windows 7 ultimate / Windows 7 ultimate
Benchmark Scores cinebench 15.41 3960x @ 5.3ghz Wprime32m 3.352 3960x @ 5.25ghz Super PI 32m: 6m 42s 472ms @5.25ghz
If the shroud was a plain transparent box and they colored the fins and heat pipes instead I'd like it but a semi see through overly frilly cooler like this is just lame
