System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
System Name | Office,Home and Game PC |
Processor | Intel Core i5 12600k Up to 4.9 GHz |
Motherboard | Z690 Gaming X Gigabyte DDR4 Version |
Cooling | Fuma 2 Air Cooler |
Memory | 32GB DDR4 2x16 3600 MHz Patriot Viper Steel RAM |
Video Card(s) | NVIDIA GeForce GTX 1080 and RTX 3070 |
Storage | 512 GB M2 PCI Ex 3.0 NVMe SX6000 Pro, 1TB NV2 Kingston M2 PCI Ex 4.0 and 4TB WD Blue SATA 3.0 HDD |
Display(s) | 27 inç 75 Hz LG |
Case | Cooler Master MB511 |
Audio Device(s) | Creative 2+1 |
Power Supply | 750W 80+ Bronze PSU High Power Element |
Mouse | Logitech Wireless |
Keyboard | Microsoft |
VR HMD | N/A |
Software | Windows 10-11 |
Run Furmark or there is a mini test in this software, run it and then it will be fixed. It's normal to be like this at idle.View attachment 277604
Mobo: H1104M-C2H
Cpu:i5 7500
Gpu:GTX 1060
8 GB DDR4 RAM
i try anything replace gpu, cpu clean slots, pins trying defualt bios settings bios update clean driver setup reinstall Windows
(sorry for my english)
The Test in the ? Does the sameRun Furmark or there is a mini test in this software, run it and then it will be fixed. It's normal to be like this at idle.
VR HMD | N/A |
Yes? I already said the same thing.The Test in the ? Does the same
System Name | ROG |
Processor | i5-11400F |
Motherboard | ROG Strix Z490-H Gaming |
Cooling | Be Quiet Pure Rock (BK009) |
Memory | Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16) |
Video Card(s) | GTX1060 6Gb AERO ITX OC |
Storage | NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs... |
Display(s) | iiyama Black Hawk G-Master GB2745HSU |
Case | CM HAF-X |
Audio Device(s) | Yamaha AV Creative DTT2200 |
Power Supply | Corsair RM-1000 |
Mouse | SteelSeries Rival |
Keyboard | MS Sidewinder X6 |
Software | Windows 10/11 |
If you tested with another GPU, no misaligned cpu pins and same results, it will probably be an issue with the motherboard x16 slot or its own pchMobo: H1104M-C2H
Cpu:i5 7500
Gpu:GTX 1060
8 GB DDR4 RAM
Correct.ECS motherboard
Vender | Series | Chip | Model | VGA Memory Type | Memory Size |
Sapphire | Radeon HD 6xxx Series | HD6950 | HD6950 2G GDDR5 PCI E DL DVI.I SL.DVI.D HDMI Dual Mini DP | DDR5 | 2048MB |
ASUS | Radeon HD 7xxx Series | HD7970 | HD7970-3GD5 | DDR5 | 3072MB |
Colorful | GeForce 600 Series | GTX 680 | GTX680CH-2GD5 | DDR5 | 2048MB |
Gigabyte | GeForce 700 Series | GTX760(UEFI) | GV-N760OC-2GD 2GB DDR5 | DDR5 | 2048MB |
ASUS | GeForce 700 Series | GTX770(UEFI) | GTX770 -DC2-2GD5 | DDR5 | 2048MB |
Inno | GeForce 700 Series | GTX760(UEFI) | 冰龍超級版 GTX760 2XDVI+DP+HDMI-GDDR5 2GB | DDR5 | 2048MB |
Gigabyte | Radeon R7 2XXX Series | R7 240(UEFI) | R7 240 GV-R7240C-2CI | DDR3 | 2048MB |
Medion | GeForce 700 Series | GTX750ME(UEFI) | GTX750ME-1G GDDR5 | GDDR5 | 1024MB |
MSI | GeForce 700 Series | GTX750Ti (UEFI) | GTX750Ti GAMING 2GB GDDR5 | GDDR5 | 2048MB |
Sapphire | Radeon R9 2XXX Series | R9 280X | Sapphire R9 280X 3GB GDDR5 | GDDR5 | 3072MB |
GALAXY | GeForce 700 Series | GTX750Ti (UEFI) | GEFORCE GTX750Ti 2GB GDDR5 | GDDR5 | 2048MB |
DATALAND | Radeon R7 2XXX Series | R7 250(UEFI) | DATALAND R7 250 酷能 1G GDDR5 | GDDR5 | 1024MB |
MSI | Radeon R9 2XXX Series | R9 270X(UEFI) | R9 270X GAMING 2G | GDDR5 | 2048MB |
GALAXY | GeForce 9XX Series | GTX970ME(UEFI) | GTX970-4G GDDR5 | GDDR5 | 4096MB |
Colorful | GeForce 700 Series | GTX 780 | Colorful GTX 780 3GB DDR5 | GDDR5 | 3072MB |
ASUS | Radeon R7 2XXX Series | R7 260X(UEFI) | R7 260X-DC20C-2GD5 | DDR5 | 2048MB |
ASUS | GeForce 9XX Series | GTX960(UEFI) | GTX960-DC2OC-2GD5 | DDR5 | 2048MB |
Sapphire | Radeon R9 3XXX Series | R9 370(UEFI) | 超白金OC 4G DDR5 | DDR5 | 4096MB |
Inno3D | GeForce 900 Series | GTX980Ti(UEFI) | 冰龍超級版 | GDDR5 | 6144MB |
Medion | GeForce 9XX Series | GTX970ME(UEFI) | GTX970-4G GDDR5 | GDDR5 | 4096MB |
i try but still same i have gt 1030 and still running x2 (1030 supports x4)The Test in the ? Does the same
my gpu 'Galax GTX 1060 OC'If you tested with another GPU, no misaligned cpu pins and same results, it will probably be an issue with the motherboard x16 slot or its own pch
EDIT: Wait a minute... 11C2... is that a "chinese" gpu card? Mining card? Those fakes GTX 650 Ti ?
I thought x16 slot was enough for support. I guess it wasn't. Because i have gt 1030 (10 series) and still running x2. Thanks for answers guys. I need new motherboard or downgrade gpu.Correct.
Supports the following VGA's -
Vender Series Chip Model VGA Memory Type Memory Size
Sapphire Radeon HD 6xxx Series HD6950 HD6950 2G GDDR5 PCI E DL DVI.I SL.DVI.D HDMI Dual Mini DP DDR5 2048MB ASUS Radeon HD 7xxx Series HD7970 HD7970-3GD5 DDR5 3072MB Colorful GeForce 600 Series GTX 680 GTX680CH-2GD5 DDR5 2048MB Gigabyte GeForce 700 Series GTX760(UEFI) GV-N760OC-2GD 2GB DDR5 DDR5 2048MB ASUS GeForce 700 Series GTX770(UEFI) GTX770 -DC2-2GD5 DDR5 2048MB Inno GeForce 700 Series GTX760(UEFI) 冰龍超級版 GTX760 2XDVI+DP+HDMI-GDDR5 2GB DDR5 2048MB Gigabyte Radeon R7 2XXX Series R7 240(UEFI) R7 240 GV-R7240C-2CI DDR3 2048MB Medion GeForce 700 Series GTX750ME(UEFI) GTX750ME-1G GDDR5 GDDR5 1024MB MSI GeForce 700 Series GTX750Ti (UEFI) GTX750Ti GAMING 2GB GDDR5 GDDR5 2048MB Sapphire Radeon R9 2XXX Series R9 280X Sapphire R9 280X 3GB GDDR5 GDDR5 3072MB GALAXY GeForce 700 Series GTX750Ti (UEFI) GEFORCE GTX750Ti 2GB GDDR5 GDDR5 2048MB DATALAND Radeon R7 2XXX Series R7 250(UEFI) DATALAND R7 250 酷能 1G GDDR5 GDDR5 1024MB MSI Radeon R9 2XXX Series R9 270X(UEFI) R9 270X GAMING 2G GDDR5 2048MB GALAXY GeForce 9XX Series GTX970ME(UEFI) GTX970-4G GDDR5 GDDR5 4096MB Colorful GeForce 700 Series GTX 780 Colorful GTX 780 3GB DDR5 GDDR5 3072MB ASUS Radeon R7 2XXX Series R7 260X(UEFI) R7 260X-DC20C-2GD5 DDR5 2048MB ASUS GeForce 9XX Series GTX960(UEFI) GTX960-DC2OC-2GD5 DDR5 2048MB Sapphire Radeon R9 3XXX Series R9 370(UEFI) 超白金OC 4G DDR5 DDR5 4096MB Inno3D GeForce 900 Series GTX980Ti(UEFI) 冰龍超級版 GDDR5 6144MB Medion GeForce 9XX Series GTX970ME(UEFI) GTX970-4G GDDR5 GDDR5 4096MB
System Name | ATLAS |
Processor | Intel Core i7-4770 (4C/8T) Haswell |
Motherboard | GA-Z87X-UD5H , Dual Intel LAN, 10x SATA, 16x Power phace. |
Cooling | ProlimaTech Armageddon - Dual GELID 140 Silent PWM |
Memory | Mushkin Blackline DDR3 2400 997123F 16GB |
Video Card(s) | MSI GTX1060 OC 6GB (single fan) Micron |
Storage | WD Raptors 73Gb - Raid1 10.000rpm |
Display(s) | DELL U2311H |
Case | HEC Compucase CI-6919 Full tower (2003) moded .. hec-group.com.tw |
Audio Device(s) | Creative X-Fi Music + mods, Audigy front Panel - YAMAHA quad speakers with Sub. |
Power Supply | HPU-4M780-PE refurbished 23-3-2022 |
Mouse | MS Pro IntelliMouse 16.000 Dpi Pixart Paw 3389 |
Keyboard | Microsoft Wired 600 |
Software | Win 7 Pro x64 ( Retail Box ) for EU |
At GPU-Z click over the question mark, new small window appears ..... NOW take a screenshot of both ... for us to see.i try but still same i have gt 1030 and still running x2 (1030 supports x4)
I don't want to plug the 1030 again but trust me it's still running to x2 3.0At GPU-Z click over the question mark, new small window appears ..... NOW take a screenshot of both ... for us to see.
System Name | BOX |
Processor | Core i7 6950X @ 4,26GHz (1,28V) |
Motherboard | X99 SOC Champion (BIOS F23c + bifurcation mod) |
Cooling | Thermalright Venomous-X + 2x Delta 38mm PWM (Push-Pull) |
Memory | Patriot Viper Steel 4000MHz CL16 4x8GB (@3240MHz CL12.12.12.24 CR2T @ 1,48V) |
Video Card(s) | Titan V (~1650MHz @ 0.77V, HBM2 1GHz, Forced P2 state [OFF]) |
Storage | WD SN850X 2TB + Samsung EVO 2TB (SATA) + Seagate Exos X20 20TB (4Kn mode) |
Display(s) | LG 27GP950-B |
Case | Fractal Design Meshify 2 XL |
Audio Device(s) | Motu M4 (audio interface) + ATH-A900Z + Behringer C-1 |
Power Supply | Seasonic X-760 (760W) |
Mouse | Logitech RX-250 |
Keyboard | HP KB-9970 |
Software | Windows 10 Pro x64 |
^This, or swap CPU for some cheap 100% working one (to test if all PCIe lanes are still working).Replace the motherboard
Correct.
Whatever is easier for you to do.
System Name | ROG |
Case | CM HAF-X |
There we go... yes this can be the culprit indeed.1: Does my GPU support it even though it's not here?
2:I installed my processor upside down 3 months ago, one corner was bent and I fixed it, but it works perfectly in terms of performance. Could it be because of this?
System Name | BOX |
To make this more clear :I don't have another CPU. I replace gpu,cpu,ram,hdd,motherboard power cable 2 days ago. Still same. I have 2 question;
System Name | Trackstar |
Processor | AMD Ryzen 7 5800X3D -30 All Core CO (on Corsair XC5 block) |
Motherboard | Gigabyte B550 AORUS Elite V2 Rev 1.0 (F17 BIOS) |
Cooling | Corsair XD5 pump / Corsair XR5 1x 360mm (front) + 1x 420mm (top) rads |
Memory | 32GB G.Skill DDR4-3600 CL14 1:1 (F4-3600C14Q-32GVKA kit) |
Video Card(s) | ASRock RX 6950XT OC Formula (on Bykski A-AR6900XTOCF-X block) |
Storage | WD_BLACK SN850X 2TB w/HS (FW ver. 620361WD) |
Display(s) | Dell S3222DGM 32" 1440p/165Hz FreeSync |
Case | Fractal Design Meshify S2 |
Audio Device(s) | Realtek ALC1200 Integrated Audio |
Power Supply | Super Flower Leadex Platinum SE 1200W on Liebert GXT4-1500RT120 UPS |
Mouse | Corsair Nightsword RGB |
Keyboard | Corsair K60 RGB PRO |
VR HMD | N/A |
Software | Windows 11 Pro 23H2 (Build 22631.3958) |
Benchmark Scores | https://www.3dmark.com/sw/1131940 https://www.3dmark.com/fs/29315810 |
Dude...I installed my processor upside down 3 months ago, one corner was bent and I fixed it
It doesn't work like that.Click the ? And put a load on it
Wow! There's your problem! Probably something got burnt in the process and now you only got 2x as the result. Be more watchful how you install components.I don't have another CPU. I replace gpu,cpu,ram,hdd,motherboard power cable 2 days ago. Still same. I have 2 question;
Visit a local computers shop, deliver entire PC for inspection due an Pro expert.This is my CPU and socket. I marked the bent place. Do you guys think that's the problem?
I cannot tell if there's something burnt from those 2 pictures, however there definitely is some part of the northbridge (in CPU) damaged, because you only have 2 PCI-e lanes available to you.This is my CPU and socket. I marked the bent place. Do you guys think that's the problem?
