My pc is weak
7 (0.00/day)
hey guyss i need your help. So my pc's not very powerful and it's ok for me but last year, i can still play games at low-medium graphics. But now i can't even play for 5 minutes. The games i'm playing are dead island, World of Tanks, F.E.A.R 3, Devil may cry 4&5, Assasin's creed 3 and Mafia 2. Soo..the problem is... My monitor suddenly goes to sleep when i start/resume a game. Then i'll hear some kind of sound (that you'll hear when you adjust your sound volume in the taskbar) like it's trying to show me an error or something. I stress tested it with msi afterburner... The temp was at 37 degrees celcius then i started the stress test but the test didn't even last for 2 seconds. The monitor when to sleep again and i had to force restart my pc. I'll list down my specs below... oh i almost forgot, my pc was just given to me as a gift soo i don't know much about the hardwares.
gt 730
4 gb ram
intel pentium G3258 @ 3.20GHz
LGA 1150
350 GB storage
any suggestions will be appreciated. thanks!
866 (0.22/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
oh boy, i dont think this pc is even worth working on if you can afford to spend 450 bucks on a replacement system. you will get much better performance and less hassle. your going to be going in circles on this one.
aside form that it sounds like a bad power supply. do you know what you have in it now?
edit: make sure to clean out all dust, set optimal defaults in the bios, all connections are good and no overclock is applied. this is the best place to start. post a gpuz screenshot, and a cpuz screenshot of all the tabs. also check event viewer.
64K
6,773 (1.67/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
It's time for a new build. The GT 730 isn't going to provide the performance you want. Additionally the 730 doesn't require a power plug from your PSU.
I know this is not what you want but save up for a new build. There are plenty of knowledgeable experienced people that can help you with the build here.
1,908 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
WTF are you talking about?
socket 1150, get a 4790K for cheap on E bay. A PSU has NOTHING TO DO with a monitor, @origial poster What PSU do you have? Need to upgrade the GPU.......
44,262 (6.80/day)
8-16GB Ram, Xeon CPU, RX570
866 (0.22/day)
Cooling custom loop
Software Win 10 pro
wtf you talking about? usually a bad power supply does exactly what he is describing. secondly, upgrading an old platform is really not a wise idea. third, the cpu you recommend cost on ebay as much as a ryzen 5 1600 and motherboard combo or g2400 and board. the r5 2400g would give him more perfomance than his current gpu and cpu. forth, this system sounds like an oem platform, its a pit. your giving bad advice. his system is best left being fixed extremely cheap but not upgraded unless its to a new platform.
7 (0.00/day)
i already started saving some money for upgrades but i mostly use my pc for school works. i think i'll buy a new build when i'm in college ... and another fcking problem occured while i was typing. the pc restarted by itself thankfully i saved my work haha
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
>Xeons
Issue with that is 1150 CPUs are still priced out the ass aside from the BGA conversions which too have gone up in price.
7 (0.00/day)
okay, sir. i feel that the gpu is really the problem like it's DYING. What gpu would you suggest?
1,710 (0.52/day)
System Name The Blind Grim Reaper
Processor Xeon X5675 Westmere-EP B1 SLBYL 4.20ghz @ 1.256v
Motherboard Asus P6X58D-E
Cooling Noctua CP12 SE14, Redux Noctua 1500rpm fan Arctic F14 x3 for intake and exhaust
Memory Corsair XMS3 CMX4GX3M2A1600C9 x6
Video Card(s) EVGA GTX 1060 6GB SC Single Fan Model
Storage Crucial mx300 750gb main system + 1TB mx500 for games and music
Display(s) 22 inch samsung curved
Case NZXT Phantom 530 black
Audio Device(s) Nvidia HDMI through HDMI adaptor for output sound for turtlebeach x12 headset
Power Supply Antec HCG 850 watt
Mouse no brand
Keyboard normal usb keyboard
Software Windows 10 22H2 v1 (main is) and Windows 11 22H2 v2 on WD 250gb 7200rpm (testing purposes os)
Benchmark Scores Cinebench R20 = 2046cb
ha my computer is sporting xeon e5450 @ 4.275ghz @ 1.304v, 8gb ram gtx 1050 ti oc 850w power supply. looks like the first post need a better graphic card his spec is not too bad for performance maybe a better power supply as he didnt list what power supply he has
7 (0.00/day)
i'll post screenshots tomorrow bro. i gotta go to sleep it's 1am here haha
EDIT: here's the screenshots
7 (0.00/day)
like i said.. my pc was just given to me as gift so i don't know much about it's hardwares. But i'll find out what power supply i have tomorrow
1,843 (0.59/day)
BGD
System Name Minotaur
Processor Intel I9 7940X
Motherboard Asus Strix Rog Gaming E X299
Cooling BeQuiet/ double-Fan
Memory 192Gb of RAM DDR4 2400Mhz
Video Card(s) 1)RX 6900XT BIOSTAR 16Gb***2)MATROX M9120LP
Storage 2 x ssd-Kingston 240Gb A400 + HDD 500Gb+2xSSD Kinston 480Gb+5Tb Seagate+512Gb NVME SGI
Case NZXT H5 Flow
Mouse Asus TUF-GAMING M3
VR HMD Oculus Rift DK2
Software Win 11
Benchmark Scores Fire Strike=23905,Cinebench R15=3167,Cinebench R20=7490.Passmark=30689,Geekbench4=32885
OP you really NEED to tell us your BUDGET and what is your overall idea is it to stay on this socket or to get something newer?
44,262 (6.80/day)
1,908 (0.32/day)
Processor 5930K
Cooling WATER
Mouse DEATH ADDER
Software W10HB
LOL THE PSU makes the monitor go blank oh thank you for the education!!!!! YOU HAVE 500+ plus no clue postings!!! Oh he needs A RYZEN SO BAD doesnt he!
1,710 (0.52/day)
Mouse no brand
the point here is that not many people cant afford to spend money on the pc when it having a issue only way is fix it to narrow down what is the cause but please dont force somebody to upgrade something then again i could point out it could be a nvidia driver problem where it crashing sometimes causing the monitor to go to sleep i had to fix the regedit for the graphic card in my system to stop it from doing the error 4101. As it could be as simple as that is my guess
FreedomEclipse
~Technological Technocrat~
24,772 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Just as a suggestion.... If you are on a serious budget. Dont be afraid to buy decommissioned Dell office PCs that sell for $70-100 on ebay. some will come with quad core CPUs, some with DC depending on the price but they are an excellent platform for upgrading on a serious budget.
1,710 (0.52/day)
Mouse no brand
only problem about the videos you posted are small form factor not many graphic card would fit into it??
4,907 (1.48/day)
Processor Intel Core i7-13700 PL2 150W
Cooling Cooler Master RGB Tower cooler
Memory Crucial Pro DDR5-5600 32GB Kit OC 6600
Video Card(s) Gigabyte Radeon RX 9070 GAMING OC 16G
Storage 970 EVO NVMe 500GB, WD850N 2TB
Case Corsair iCUE 4000D RGB AIRFLOW
Audio Device(s) EVGA NU Audio, Edifier Bookshelf Speakers R1280
Power Supply TT TOUGHPOWER GF A3 Gold 1050W
Software Windows 11 Professional v24H2
If you do what @FreedomEclipse suggests, be looking for a quad core Haswell CPU.
Not all of them are small form factors.
1,710 (0.52/day)
Mouse no brand
judging by the video they are small form factor you can get mid tower version of the same model
23,814 (6.15/day)
You could start this off with a 'clean' Ryzen 2400G. Its a great base to expand later when money allows and it gives you a rig right away that will work just fine.
- Ryzen 2400G = decent GPU for light gaming, decent enough CPU for midrange GPU later on, and decent allround for 'day to day use'. Its plenty fast, and prices will drop now or soon as updates are coming. You also get 4c8t, you get DDR4 (grab 8GB to start, keep single channel if you pair it with a 2 slot ITX board or something, otherwise just 2x4GB), and you can upgrade later down the line. Another option, more temporary but cheaper is to knock down to the 2200G. Same deal, but just 4C/4T and somewhat slower GPU. That option might run into some performance hiccups while gaming, quads are no longer ideal (but good enough for low-midrange & especially older games will be no problem).
- Expand later with GPU (would not recommend anything faster than RTX 2060 / Navi 5700 with this CPU)
- Upgrade CPU when you have a dedicated GPU, to any Ryzen 6 core or better = perfect base for a high end (gaming) rig.
Right now I would refrain from second hand DDR3-based Haswell systems etc. You're stuck at quadcores that are already on the last leg performance wise, and when your next upgrade is due, you'll still be looking at a huge investment. The Ryzen G-route allows you to keep improving as you see fit, while you get a recent system right away. In the longer run, this is probably the cheaper option for you - and much more flexible.
FreedomEclipse
24,772 (3.77/day)
There are some low profile 1050Ti's that fit into it - in any case i think they managed to fit a full length low/mid range GPU into it though they needed to faff around with it for a bit but it worked. (if my memory serves me correctly)
It will only effect you if youre like "Bro - Im gonna put a 2080Ti in this thing" - Thats just not going to happen.... My point is you can still have a very serviceable desktop that will play games at 1080p that is better than the shitty specs the OP has listed.
It was never about cramming in the most powerful hardware known to man that could fit, although that is a possibility if you own a dremel tool and have lots of spare time
4,907 (1.48/day)
Or just make the jump for the Ryzen 5 3400G, unless the 2400G is selling for dirt cheap might as well get the Zen+ cores on the 3400G. I was wondering if the APU route would be the way to go.
23,814 (6.15/day)
That's an option but on a tight budget, the difference (considering some sort of clearance sale, especially!) in price is not going to be worth the faster part I think.
1,710 (0.52/day)
Mouse no brand
I can understand theres low version graphic card as from what i hear some arent great for performance. As im on asus p5q deluxe ddr2 motherboard that is even more older than any of you currently running now but it does what i need
