my pc suddenly stop and does not show anything and gpu fans rpm is to high ...... what is the reason ?
sgt.8nemi
7 (0.02/day)
My PC specs:
  • CPU: Ryzen 5 3600
  • Cooler: Cooler Master Hyper 212 Spectrum V3
  • RAM: 2x8GB DDR4 3200 MHz HP V6
  • GPU: Gigabyte Aorus GTX 1060 6GB Xtreme Gaming Edition
  • Storage: Samsung 128GB M.2 SSD, Seagate 500GB HDD, Hitachi HDD
  • PSU: Cooler Master 750W 80+ Platinum from an HP Omen build
  • Case: Technozone C11
When I use my PC for gaming or browsing, the display randomly stops, and the GPU's fan RPM becomes very high. After this happens, I need to forcefully shut down the PC and restart it for it to run normally again.
I need help fixing this issue. Any suggestions?
42,841 (6.70/day)
Gpu or psu at this rate
689 (1.14/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
Was it CM or GB who had some very dodgy PSU's only a couple of years ago? Could also be the fact he doesn't have a motherboard! :roll:
But the fans will spin up like this when there is a fatal error with your system, you need to reset your bios options to default and run HWinfo logging when you are playing games or doing usual stuff to see if it picks anything up, what is your CPU/GPU temps, OS, sure looks like either temps or power issue, without more info we could keep guessing.
9,523 (3.26/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Check the GPU PCIe power cables, make sure they are plugged all the way in and look at the pins if they are all lined up at the same height, this type of stuff can happen when there is something loose making intermittent contact.
42,841 (6.70/day)
I look at it this way, psu from a hp system, gpu as of manufacture is what 10 yo now
1,529 (3.69/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Might be HP V6 ddr4 (like corsair vengeance sticks) and AM4 Gen 3 hatred going on. Motherboard is unnamed.
FreedomEclipse
~Technological Technocrat~
24,217 (3.74/day)
London,UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Im guessing since the ram is HP and the PSU is pulled out of another HP that the motherboard itself is some unknown own brand HP one also.
385 (2.81/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
sgt.8nemi
7 (0.02/day)
ASUS PRIME B450 PLUS the motherboard
the motherboad is asus prime b450 plus
and when i test the gpu with furmark it works normally in around 60s degrees
and cpu temp in stress in 70s degrees
85 (0.21/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 speakers, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
Check Event Viewer for anything related to your problem. I suspect a GPU issue but I could be wrong; also run HWinfo64 and check the PSU for voltages on the rails.
