My RX6800XT is not giving image anymore, Please Help.
Crstxn
29 (0.05/day)
Hi, so I recently made my 5th build with this graphics card, everything was working perfectly fine until some days ago... I woke up and tried to boot up my PC like everyday, the PC didn't boot into windows and my screen was black, I tried to boot up again and it booted up into windows but after 20 seconds or something like that my screen flicked green cubes or something similar and the screen became black, I switched the graphics card bios mode from Overclock to silent and it worked perfectly fine for some days until today, I tried to switch back again to the overclock mode but the screen is black in both bios modes. So I decided to disconnect everything and take out the graphics card, I looked at the pins and the pcie slot and noticed that the slot has thermal paste inside, the thermal paste is dry... I just don't know if the thermal paste fucked up my Graphics card but it seems like it, can someone tell me what can I do to fix it please? Also a pin on the graphics cards seems to have a different color from the other ones, matching the place on the pcie slot that has thermal paste. I bought the card 2 years ago and it was used, it has never been cleaned or maintained since I got it.
Toothless
Tech, Games, and TPU!
9,777 (2.44/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Nuke drivers with DDU and amddrivercleanup while in safe mode. You'll need to use something else for display out. Card and slot look fine.
Crstxn
29 (0.05/day)
I don't know if that will work because when I managed to boot up the graphics card I made a fresh windows 11 installation and installed the latest graphics drivers on the AMD official site. I'm sure that the slot has thermal paste because that Gray color is not normal
43,927 (6.80/day)
Breadboard your current system.
Try card in another system, if it doesn't work there contact northridgefix for a pcb repair.
Get a RX 6400 to test and make sure your motherboard isn't damaged.
Or better yet go to a shop so you can make sure (damage their stuff instead of buying parts just to damage them)
5,358 (3.71/day)
Colorado, U.S.A.
Software Windows 11 Home
Clean off the thermal paste with isopropyl alcohol.
43,927 (6.80/day)
He can try that with a qtip and a magnifying glass so he doesnt wreck the peg slot.
43,927 (6.80/day)
I'm a nutcase and wash my boards with isopropyl alcohol, normally to remove flux.
You don't say?
Totally understandable if it's a lot.
4,004 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
As others have said
can try
-99% isopropyl (rubbing alcohol)
-confirm in tight in slot
-try another pcie slot
-make sure elec connectors in tight and that pins/cables good
-try another display cable or another monitor port
AMD has their own driver uninstaller utilty
