My system crashed
62 (0.04/day)
România
System Name PC Ryzen 7
Processor AMD Ryzen 7 5700X, 3.4GHz, Socket AM4, Box
Motherboard MSI MPG X570 GAMING PLUS
Cooling Cooler ARCTIC AC Liquid Freezer II 240 A-RGB
Memory G.Skill Trident Z RGB, 2x16GB, DDR4, 3600MHz, CL18
Video Card(s) GIGABYTE nVidia GeForce RTX 3060 AORUS ELITE LHR 12GB, GDDR6, 192bit
Storage M2 Kingston KC3000 1TB
Display(s) BenQ ZOWIE XL2411P 24 Inch 144Hz Gaming
Case Lian Li Lancool II Mesh C RGB
Power Supply Gigabyte G750H, 80+ Gold, 750W
Keyboard Logitech G510 Keyboard Gaming
I'll show you what configuration I have, maybe that way I can find out why my system crashes:
01. Motherboard: MSI MPG X570 GAMING PLUS
02. Processor: AMD Ryzen 7 2700X, 3.7 GHz, AM4
03. Cooler Processor: CPU Cooler Master MasterLiquid ML120R RGB
04. Graphics Card: Gigabyte Aorus GeForce RTX 3060 ELITE LHR 12GB GDDR6 192-bit
05. SSD M2: SSD WD Black SN750 500GB PCI Express 3.0 x4 M.2 2280
06. Ram: HyperX Fury RGB 2x16 Gb DDR4 3200MHz CL16 Dual Channel Kit
07. 2 x HDD: WD Blue 1TB and 1 HDD: WD Blue 1TB
10. Source: GIGABYTE G750H, 80+ Gold, 750W
11. Case: Lian Li LANCOOL II Mesh RGB Black
12. Case fan: Be Quiet! Silent Wings 3 120mm 2200RPM PWM
In event viewer: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Souce: Kernel-Power, Event ID: 41, Level: Critical
I updated last version BIOS: BIOS 7C37vAJ - 03.03.2023 and still without help. Does anyone know what could be my cause?
izy
1,022 (1.12/day)
What is the other error? It could be the PSU , a bad overclock , a power drop or a faulty component.
62 (0.04/day)
România
62 (0.04/day)
România
PSU, do you mean the source?
62 (0.04/day)
România
How can I check the source?
izy
1,022 (1.12/day)
Well , i dont think you can other than testing your computer with some other PSU.
edit: you can check with HWINFO if the voltages are right during load but that doesnt ensure that the PSU is good 100%.
edit2: by crashing you mean that your computer reboots or it just hangs , what is exactly happening and in what conditions (under load, idle etc..)? (i should have asked this first)
62 (0.04/day)
România
For example, today I opened the PC and suddenly the image on the monitor was closed and the fans could be heard running at high speed. I had to press the reset button on the case to get it back.
izy
1,022 (1.12/day)
Then is not a PSU problem , you should check all connections / cables first, remove any overclocking you did if you done any.
Lei
1,143 (0.90/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
@Detonate12
What is your monitor? Some displays with high refresh rate need settings in Nvidia control panel, otherwise they turn the system off in the same manner you described
95Viper
Super Moderator
13,061 (2.21/day)
Do you Overclock? If so, try without overclock using stock settings.
Check you temps.
Check you memory and their settings.
62 (0.04/day)
România
Izy no use overclock
Lei: I have Monitor: LED BenQ Gaming Zowie XL2411P 24 inch 1 ms Black 144Hz
Viper, I used Ryzen Master and I set the control voltage to 1.1375 compared to 1.4625 and I had a processor with cooler temperatures. I haven't activated Ryzen Master and it still does the same thing. I also set the BIOS to default!
Check you temps.
Check you memory and their settings. HOW????
9,340 (5.27/day)
Louisiana
Keyboard G710+x3
Well gigabyte power supply no telling if it's any good they do have a poor history
Only ways to rule power supply out is,
Use a different one
Move to another room and try a different electrical circuit not the same as now.
Use a ups/ backup battery if it turns on a lot it's a wall outlet issue not the power supply.
You can use hwinfo64 to get the reading I'd suggest an older portable v6.08 version not newest
izy
1,022 (1.12/day)
Check you temps.
Check all the connections / cables if they are correctly fitted and reseat your GPU in the slot.
Uninstall Ryzen Master and reset the BIOS to default. (seems that one of last versions of Ryzen Master was a bit buggy , not sure)
Check HWINFO like @ThrashZone showed and see if the values from your PSU and CPU / GPU temperatures are ok.
Reinstall your graphics card drivers (with a clean install)
Reinstall chipset drivers.
Check if you still get crashes.
62 (0.04/day)
România
Trashzone now i have v5.20 hwinfo64. Where do I see those values?
Izy bios is default. Ryzen Master no active!
Edit 2: Use Display Driver Uninstaller v18.0.6.2 clean and restart and reinstall drivers graphics card Nvidia
