Need a suggestion about RTX2060S vs. RTX3060
nicepen1
5 (0.01/day)
Hi All,
I am looking for buying a new Nvidia graphic card. I have a budget around RTX2060S and RTX3060 prices.
2060S has 8GB ram and 256bit
3060 has 12GB ram but 192bit
My motherboard is Asus Z87-A (a bit old)
CPU is Intel i7-4770 3.40GHz 4 Cores (a bit old)
My PSU is Cool Master Bronze GX 750W
Which one do you suggest me? By the way you can suggest me same tier another graphic card.
Thanks in Advance
578 (0.38/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
Depends on the prices mainly. 3060 is a bit better overall, by a tiny amount tho. If you can spend a few more and get a 3060Ti or even a 3070, that would be a much better investment. Also, are you buying them new or used? Because if you buy used then in case of 2000 series the cards were around for longer and have higher chance of failure, just saying
2,838 (0.51/day)
MN
System Name Personal / HTPC
Either should be just fine.
The 2060S is only about 5% behind the 3060.
Out of the two, I'd suggest taking these two things into consideration:
1) What is cost difference between the two cards?
2) Do you want a newer card or are you okay with a card that's already 3-4 years old?
Both perform about the same. If they're priced very close, I'd say go for the 3060. It's newer, will be supported longer and will have a warranty with it (unless you're buying it second hand, then the warranty may not be valid for it, depending on the model).
1,564 (0.87/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
3060 is about 5% faster avg and uses 5-10% less power, so I would say price should decide.
4,125 (0.86/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
if you plan on keeping the CPU the entire life of the GPU (which is fine) than get the cheaper one as you won't see a difference between the two. even with a modern CPU the difference would trivial in most games.
2,206 (1.07/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
if i was buying new id go for the 3060s but if i was buying 2nd hand id go for a 2070 because i likely find one for the price of a new 3060s with most likely a bit of money left over. i brought a used 2080 last week for a customer for £365 and it was like brand new.
Tatty_Two
Gone Fishing
25,823 (3.83/day)
Worcestershire, UK
Processor Intel Core i9 11900KF @ -075mV PL max @225w
Memory 32GB (4 x 8GB SR) Patriot Viper DDR4 @ 3600Mhz CL14 1.45v Gear 1
Video Card(s) Asus Dual RTX 4070 OC
Mouse Coolermaster Storm Octane wired
Keyboard Element Gaming Carbon Mk2 Tournament Mech
Software Win 10 Home x64
I got a brand new 3060Ti for £385 3 weeks ago, there are occasionally some really good new deals but maybe not in the OP's country.
210 (0.10/day)
Processor Intel i5-13600KF
Motherboard ASRock Z790 PG Lightning
Cooling NZXT Kraken 240
Memory Corsair Vengeance DDR5 6400
Video Card(s) XFX RX 7800 XT
Storage Samsung 990 Pro 2 TB + Samsung 860 EVO 1TB
Display(s) Dell S2721DGF 165Hz
Case Fractal Meshify C
Power Supply Seasonic Focus 750
Mouse Logitech G502 HERO
Keyboard Logitech G512
The 256 vs 192 bit is irrelevant. You should compare actual bandwidth.
The 2060S has 448 GB/s VRAM, the 3060 has 360 GB/s VRAM.
The 3060 is faster overall, despite the bandwidth deficit.
In the same tier you can compare the AMD RX 6600 or 6600XT.
2,206 (1.07/day)
south wales uk
well done bud, its getting back to being a buyers' market again thankfully we have had it bad for so long but i think we have come to the light at the end of a long tunnel.
1,343 (1.68/day)
G-City, UK
System Name My first new build
Processor Ryzen 7 5700X
Motherboard MSI B450M mortar max
Cooling Deepcool AK620
Memory 32gb Corsair Vengeance LPX 3200@XMP3200
Video Card(s) Sapphire 6900XT Toxic Air Cooled
Storage Samsung 870 QVO 1TB x 2, Lexar 256 GB, Western Digital SN550 500 GB nvme
Display(s) 32" LG GN600-B
Case Aerocool Eclipse
Audio Device(s) Corsair HS70 wireless
Mouse Glorious Model D l Pad GameSir G7 SE
Keyboard Redragon Vara K551P
Hi All,
Thanks in Advance
Where are you from so we can recommend for your country. Also what is you total budget, then we can go hunting for you! Also, have you considered AMD as they will outperform nvidia at possibly cheaper prices. As long as you aren't ray tracing.
  • Like
Reactions: Lei
izy
942 (1.27/day)
RTX 3060 has ReBar support, AV1 decoding, 12GB vram (compared with 8GB), maybe better video encoder for streaming, i think faster Ray Tracing, and ~5% better performance (maybe 2-3% against a 2060S with higher power limit / good cooling).
i would go for RTX 3060 if the price its not more than 10-15% higher compared with 2060S.
nicepen1
5 (0.01/day)
Some card has OC (overclock) on their name title in markets. Is it the most important thing? Because OC ones are more pricey
izy
942 (1.27/day)
You can OC yourself even its not an OC marketed card (mostly you have to undervolt it with curve editor for better performance) , what is more important is the power limit (some cards are capped at 100% so you cant get too much extra performance with OC, edit: cooling is also important when OC)
Lei
1,143 (1.04/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 23h2 build 22631
Benchmark Scores cine23 20000
OC cards usually come with better cooling. but you can overclock any card yourself. you may be living in a cold town or be using liquid cooling, so you shouldn't be paying extra for OC cards. cuz you can OC your card by Afterburner software.
AMD gives better price for performance and uses less electricity and comes with more memory.
I wouldn't pick an nvidia just for ray-tracing if you're aiming for a 3060. ray-tracing would make sense on a stronger card, but in your case you better pick an AMD card.
All Xbox and Play-Station consoles use AMD cards.
izy
942 (1.27/day)
At 1440p DLSS or 1080p you can use ray-tracing "medium" and ultra details in some games like f1 2022 , World of Warcraft etc.. (if you dont want very high FPS), they work just fine on my 2060S (75+ fps) and other advantage with Nvidia i would say is DLSS and Nvidia Reflex + good video encoder if you want to stream on twitch.
Edit: The cons of Nvidia GPUs are the PRICE and power consumption , but 2060s / 3060 => 150-200W , not that extreme.
5,192 (0.89/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [Asus TUF GAMING X570-PLUS]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Corsair Vengeance LPX 3600MHz (16GBx4)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Steelseries Arctis Pro]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
Lei
1,143 (1.04/day)
usually in my shirt
my PSU is 750W. is it enough for 3060 ?
if you're getting 3060 because it has more vram than 3060ti, you're wrong.....
Meme Reaction GIF by Sunny Bunnies
How about an intel gpu? Here's an option ARC A770. Take a look:
izy
942 (1.27/day)
ARC GPUs have bugs in many games (some older games arent even working) so its a risk, the value and performance are very good when it works.
  • Like
Reactions: Lei
3,117 (0.79/day)
Athens, Greece
Memory 16GB G.Skill RIPJAWS 3600 / 16GB G.Skill Aegis 3200 / 16GB Kingston 2400MHz (DDR3)
Storage NVMes, ONLY NVMes/ NVMes, SATA Storage / NVMe boot(Clover), SATA storage
If you don't care about RayTracing in this price range or a specific application that prefers Nvidia or CUDA or something Nvidia exclusive, check AMD's options. You'll probably get better performance in games.
If you have to choose between 2060S and 3060, considering that they are very close in performance, always go with the newest architecture.
Forget Intel for now. And wait November 3rd to see what AMD will announce. While they probably wouldn't announce something cheaper than $800, who knows. If they do, we might see another price drop in AMD's cards. I doubt Nvidia will lower it's prices. People just buy no matter the premium over MSRP.
ARF
4,276 (2.63/day)
Ex-usa | slava the trolls
So, the choice is between Radeon RX 6650 XT and Intel Arc A770.
From your video link it's quite visible that the Arc A770 is the faster than RTX 3060, and even when the FPS is about the same, the RTX 3060 stutters, while the A770 is silky smooth.
Forget the ngreedia's RTX 3060. Don't buy it.
  • Like
Reactions: Lei
10,526 (5.26/day)
Midlands, UK
System Name Holiday Season Budget Computer (HSBC)
Processor AMD Ryzen 7 7700X
Cooling be quiet! Dark Rock 4
Memory 2x 16 GB Corsair Vengeance EXPO DDR5-6000
Video Card(s) Sapphire Pulse Radeon RX 6500 XT 4 GB
Storage 2 TB Corsair MP600 GS, 2 TB Corsair MP600 R2, 4 + 8 TB Seagate Barracuda 3.5"
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
If they're on the same price, then 3060 because of the extra VRAM. If they're on different prices, then the one that is cheaper.
  • Like
Reactions: Lei
ARF
4,276 (2.63/day)
The thing about VRAM. The GPU and its shaders are too slow to make use of so much VRAM. You get the bottleneck in the shaders long before the VRAM limit is reached.
How do you see RTX 3080 with 10 GB and RTX 3060 with 12 GB? Doesn't make sense, right?
  • Like
Reactions: Lei
