Need advice
127 (0.03/day)
Malaysia Sabah Sandakan
System Name World Tank Blitz
Processor 8700k
Video Card(s) Asus Gtx 770 OC & 1080 TI
Storage Samsung EVO 850 120GB
Audio Device(s) Logitech
Power Supply Cooler Master V750 Fully Modular
Mouse CM Storm Reaper + MM520
Keyboard MasterKey Pro LRGB and XTI
Yo Guys ,
Need some advice
Dell OptiPlex 3020
RAM upgrade to 16GB
Storage upgrade SSD 240GB + HDD 2TB
PSU standard
and below is list GC i want to buy
Q : May i know if my current Psu can handle my whole system and how many watt needed at least ?
43,243 (6.74/day)
Yo Guys ,
Need some advice
Dell OptiPlex 3020
RAM upgrade to 16GB
PSU standard
Where are you buying the card from?
What is the intended purpose for said card?
Please be advised there are 2 versions of the RX 560.
RX 560 1024 SP
RX 560 896 SP "RX 560D"
Minimum requirements for psu are pushing it. 250Ws is bare minimum needed and thats from a strong unit...
Strong units are underrated where as weak units are overrated.
8,223 (2.14/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
When, people just buy PSU/s willynilly, this is the last thought on their mind, sad but true. Gotta give the OP props for asking here.
(I didnt say clueless this time!)
43,243 (6.74/day)
Its the oem psu and im unaware of what guts are in it...
2,267 (1.14/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
man that purple color gpu is bright
419 (0.21/day)
Processor R5 5600X
Memory 32 GB 3600 MT/s CL16
Video Card(s) Sapphire Vega 64
Storage 2x 500 GB SSD, 2x 3 TB HDD
Case Phanteks P300A
Software Manjaro Linux, W10 if I have to
I would switch the PSU.
18,016 (2.44/day)
It's a Dell, they use their own types of PSUs that aren't easy to swap, as they don't have standard ATX power connectors.
127 (0.07/day)
Australia
System Name wasted talent
Processor i5-11400F
Motherboard Gigabyte B560M Aorussy Pro
Cooling Silverstone AR12
Memory Patriot Viper Steel 2X8 4400 @ 3600 C14,14,12,28
Video Card(s) Sapphire RX 6700 Pulse, Galax 1650 Super EX
Storage Kingston A2000 500GB
Display(s) Gigabyte M27Q
Case open mATX: zwzdiy.cc/M/Product/209574419.html
Audio Device(s) HiFiMan HE400SE
Power Supply Strix Gold 650W
Mouse Skoll Mini, G502 LightSpeed
Keyboard Akko 3084S
Software 1809 LTSC
Benchmark Scores 3968/540 CB R20 MT/ST
on paper you should be fine - the OptiPlex seems like it can be configured with up to a 50w gpu by default (HD8490). The system comes with default haswell i3/i5 so if you have not upgraded that CPU to an i7, there should be ample power for a rx560 which is 75w default, and LP cards rarely attempt to up power limit. if the i5/i3 is 65w the system should also follow that power limit outside of boost.
the card you posted seems to pull power from pcie slot as lp cards usually do. I don't think dell would go so far as to modify their motherboard or pcie slot or the power supply so that you cannot use a gpu that needs more than 50w.
however, while I think the system is perfectly capable in terms of amount of power it can give to the GPU, there's no guarantee that the BIOS works with a card much newer than it's default.
It is capable, but I don't know if it is compatible. I think u could look on youtube, see if people upgraded the same optiplex to rx400/500 cards, of similar/higher power draw.
that said, I think anything GPU is a terrible deal right now, especially in what used to be the "value" market.
419 (0.21/day)
Processor R5 5600X
Case Phanteks P300A
Good point. I wouldn't buy a Dell :p
1,703 (1.07/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
The graphics card you're buying is the OEM RX 560D with a TBP of 65w. Your Dell has a 72w HD8570 listed as an option.
As @Post Nut Clairvoyance pointed out, as long as you haven't upgraded the CPU, you should be able to run the new card without a problem. Make sure to update to the latest BIOS.
43,243 (6.74/day)
I mentioned sys psu and gpu psu req.
1,703 (1.07/day)
The OEM for the card doesn't seem to specify the minimum PSU requirement on their product page: Yeston RX560-4G D5 LP
This is the PSU inside the OptiPlex 3020 SFF:
The GPU shouldn't draw more than 6A on the 12v rail with a TBP of 65w. From what I found, the advertised power consumption for the card is even lower, at 50w. IMO the OP should do fine.
And yes, I would also recommend a higher rated PSU with upgrades in mind, but this is a pre-built. I don't think Dell offered more powerful units on this series.
127 (0.03/day)
Processor 8700k
Thanks guys for you all input
Now im gonna change my chassis and psu
43,243 (6.74/day)
I went directly to AMD for that
43,243 (6.74/day)
Since your image did not appear ths other day the psu is made by AcBel it is a 255 w unit. I can see which model it is
