Need help wiring power push momentary switch
Taly.21@live.com
12 (0.00/day)
well, lets see what i can come up with ms paint :D
yep, solid state type.
basically, relay is just an electrically controlled switch. apply a voltage and the switch will close / open.
there are 2 type of contact on relay, a NO (normally open) means a contact that are open in un-powered/de-energized state and will close when you energized the relay; and a NC (normally close) which is the opposite.
i'll come back with schematic drawing.
EDIT:
here's the schematic, well, sort of :laugh:
http://www.techpowerup.com/forums/attachment.php?attachmentid=52103&stc=1&d=1375933445
Seems really simple, I'll try it out. Thank you.
397 (0.08/day)
System Name potato
Processor Ryzen 9 5950X
Cooling Custom WC Loop
Memory 2x16GB G.Skill Trident Z Neo 3600
Video Card(s) RTX3090
Storage 512GB, 2TB NVMe + 2TB SATA || 32TB spinning rust
Display(s) XIAOMI Curved 34" 144Hz UWQHD
Case be quiet dark base pro 900
Audio Device(s) Edifier R1800T, Logitech G733
Power Supply Corsair HX1000
Mouse Logitech G Pro
Keyboard Logitech G913
Software win 11 amd64
just a small addition, make sure you pull the + from the battery through a fuse, just to prevent fire hazard in case of short circuit occur :)
PS: i miss labeled one of the lamp, it should be dome light, not doom light, doh :banghead:
