Need help with Dell 7520 SE
2,002 (0.32/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
FilhoSenhor
29 (0.19/day)
Brasil
Like I said before: I tried to update the signature. Try at own risk.
I understand, I was finishing configuring the computer and I haven't tested it yet, I'm going to build the signature on the device because I want to use the functions on the platform, did you notice how bigger the SecurityFlash_x86_WIN_100.00.02.03 folder is, when did you build isflash.bin and how did you do it? is in the V4 folder, does the SecurityFlash_x86_WIN_100.00.02.03 process itself create the platform based on the FD? Thank you for all your efforts in helping!
You need to generate a signature yourself with MakeKey.bat. Since makekey.bat uses makecert.exe and pvk2pfx.exe, it must be present on the system by installing the Windows SDK.
The signature which is generated by MakeKey.bat has a different name. It will be called CerTest.pfx instead of QA.pfx but the installation is the same beside a different file name.
Did you try to flash the v4?
Test V4:
2,002 (0.32/day)
FilhoSenhor
29 (0.19/day)
Brasil
I used the extractor for that. After reinjecting the certificate, I renamed it back to *****.FD
With the exception of the new folder I created, this only came in v4 and no *.fd present can guide me in what to do after using the extractor to extract the BIOSFILE.fd and after signing the command to merge the 3 back into FD files, BIOSFILE.fd, EC.bin and platforms.ini?
2,002 (0.32/day)
I see, I adjusted the platform.ini to read the isflash.bin instead
FilhoSenhor
29 (0.19/day)
Brasil
I saw this too, yes and a lot of information from different cases too, now I understand better, what I have to do is simply update the original FD certificate that has expired and the extractor will no longer be a problem I believe, the question in my case is how to update the specific certificate expired, which creates isflash.bin updates another certificate. And another issue to check after updating is the checksum, whether it matches the original file.
FilhoSenhor
29 (0.19/day)
Brasil
Could it be that the BIOS died? Afraid to hang up!
2,002 (0.32/day)
Solaris17
Super Dainty Moderator
27,320 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
FilhoSenhor
29 (0.19/day)
Brasil
Bios didn't die, its corrupted now since the flash failed. Did you try to flash the original bios? Did you make a backup before flashing?
It's still the same, I think I locked it with an Unlocker that I found reading articles on the site that recommended Security Flash but now I can't find the article but I think it's on the same link, this flasher is from the A04 which from the beginning should having used it before testing other alternatives, now I have to find out how Unlocker works to unlock or is it still the same problem with the lack of bios.fd signature, how angry, bro. At least I already know that the Insyde flashes from the A04 bios flashes on my windows.
Try again! Don’t shut down!
It's starting normally, thank God and Insyde, the part that updates, I believe it's the EC, it writes just the BIOS just fine, even though it grabs the SM, I still don't even understand what part this part of the bios is, but it has to do with the flashing insurance, it seems!
