New external hard drive running hot and slow
189 (0.09/day)
Processor Ryzen 7 5600x @ stock
Motherboard B550M motar wifi
Cooling Thermalright assassin 120 se
Memory DDR4 G.skill 32gb @ 3600mhz
Video Card(s) 6700xt
Storage 2x Crucial MX500 1tb SSDs 1TB SN850x
Display(s) Acer nitro XV272U 1440p 170hz
Case Deepcool M370
Power Supply Corsair RMx 850w
I bought a new external harddrive for storage 8TB WD easystore and soon I noticed some strange things, like when I check it with HD sentinel or HD tune it shows it running close to 50c none of my other drives get this hot also another thing that really bothers me is that it takes a few seconds to spin up and I could make out the disc spinning up and the head making noise when it's writing that is noticeable.
I have contacted WD about it and they say it's all normal because it uses helium I thought all drives had that?
Am I just too used to having quiet harddrives or is my drive possibly bad? Any help with this would be great.
43,546 (6.77/day)
Id rma it.
Otherwise get fans on it
No HDD likes running 50 °C
189 (0.09/day)
Case Deepcool M370
Id rma it.
Is it normal from running 24/7? I turned the timer off so it's on and doesn't take time to spin up since I got it which was 2 weeks ago.
43,546 (6.77/day)
Lots of info
50°C is maximum threshold, which I wouldn't keep it running at that for 24/7 use. I'd swap for another.
1,349 (0.22/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
Make sure you leave some space underneath the drive to allow air to flow up through the case and cool the drive. You can also set the drive on a (case) fan, as that will move air up and through the case. Temps in the 40's are pretty normal for a drive in a plastic case with no fan, that's been active for a while. I own a number of Easystore drives.
1,223 (0.65/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2699 V4 22c/44t / i9 14900K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Taichi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6800
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 2TB Solidigm P44 Pro & more.
Display(s) 43" Samsung 8000 series 4K / 65" Hisense U8N 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX/ Asus Xonar Essence STX II
Mouse Logitech Performance MX, Microsoft Intellimouse Explorer 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC 24H2
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
My 8TB WD My Book is running at 25 degrees C at the moment and it's been on for weeks.
43,546 (6.77/day)
That's normal temp for any HD out there from the Quantum Fireball to now.
