New PC Incoming
the54thvoid
Super Intoxicated Moderator
13,070 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
Wife just paid for a new PC. It's ordered, so I'm not looking for advice on parts. Just thought it was cool, and hopefully it'll serve me well.
MSI MAG B650M Mortar WIFI (Socket AM5) DDR5 Micro-ATX Motherboard
AMD Ryzen 7 7800X3D Eight Core 5.00GHz (Socket AM5) Processor - Retail
Kingston FURY Beast EXPO RGB 32GB (2x16GB) C36 6000MHz Dual Channel Kit
Seagate FireCuda 530 1TB SSD PCIe Gen4 NVMe M.2 Solid State Drive with EKWB Heatsink
be quiet! Pure Power 12 M 850W ATX 3.0 80 Plus Gold Power Supply
be quiet! Dark Rock Pro 4 CPU Cooler
Thermal Grizzly Kryonaut High Performance Thermal Paste
be quiet! Shadow Wings 2 120mm Fan x 3
Asus Prime AP201 TG MicroATX Case
I bought a 4070ti a couple months back, so it'll go into it as well.
I'll DL the appropriate MSI mobo BIOS for SoC correct voltages if I need to.
It's my first complete build since the Ryzen 1700X came out. Getting older makes this seem less like fun and more like a test.
Of note - power draw was a consideration for me. I'm on the PC all day (writing during day, gaming at night), so the 7800X3D was appealing over the equally priced i713700K.
64K
6,773 (1.73/day)
Processor i7 7700k
Motherboard MSI Z270 SLI Plus
Cooling CM Hyper 212 EVO
Keyboard Logitech G105
It looks like a very nice rig to me. That be quiet! PSU caught my eye. Looks like a really good unit and I like my PSUs to have a 10 year warranty also. I've never owned a be quiet product but I'm going to have to check out their PSU line next year when I finally do my new build.
6,929 (3.04/day)
California
System Name His & Hers
Storage lots of SSD.
Looks pretty awesome, Congrats.
I've seen that Asus case pop up in a couple builds looks interesting.
828 (1.12/day)
Processor Intel i7 77OOK
Motherboard Gigabyte Aorus something
Cooling Noctua NH-U12S dual fan
Memory Ballistix 32 Go
Video Card(s) MSI 3060 Gaming X
Storage Mixed bag of M2 SSD and SATA SSD
Display(s) MSI 34" 3440x1440 Artimys 343CQR
Case Old Corsair Obsidian something
Audio Device(s) Integrated
Power Supply Old Antec HCG 620 still running good
Mouse Steelseries something
Keyboard Steelseries someting too
Benchmark Scores bench ? no time to lose with bench ! :)
Everything will fit in the case ?
That's clever !
6,203 (1.53/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
No, nope, notta, no way 'Jose..
you will need at least 19TB of ram, 646.1PB of storage, 13.02 additional fans, and a 3.79164GW psu for that rig......:roll:
j/k... seems like a nice, well rounded rig that should serve you well for several years, congrats !
the54thvoid
13,070 (2.39/day)
Software W10
I'm not an Asus groupie but this case has fantastic reviews and it's not stupid expensive.
2,109 (1.06/day)
Hungary
Mouse Canyon Puncher GM-20
Thats pretty nice of your wife to do that and that looks like a solid build/have fun with it!:)
I've never owned a small-ish form factor PC but that case I kinda like and its actually affordable from what I see. 'I always play around with the idea of switching to a smaller case/system but then I'm not sure if I'm capable enough building a good looking/cable managed one with much less space:oops:'
1,351 (0.90/day)
Tel Fyr
Software W10 LTSC 21H2
Good choices. Enjoy.
ir_cow
4,498 (0.76/day)
USA
Make sure to update the BIOS before doing stuff. If the ram doesn't run at 6000 using XMP/EXPO, the solution is to raise the SoC and VDDIO-MEM voltage. Hopefully it works on auto for you.
the54thvoid
13,070 (2.39/day)
Software W10
I did say in the OP:
Hopefully, I'll not need to touch the SoC voltage.
ir_cow
4,498 (0.76/day)
USA
I noticed the VDDIO-MEM has been a lot lower since the meltdown BIOS update. Vendors are playing it Super safe, but 1.0- 1.1V (default) may not be enough now. Sure isn't if you are using 4 DIMMs or dual rank. It use to be 1.25-1.35 by default.
the54thvoid
13,070 (2.39/day)
Software W10
What does the extensive memory start up testing achieve (if not to stabilise settings)? I'm aware it takes a while to boot.
the54thvoid
13,070 (2.39/day)
Software W10
They're here.....
(Boomer level reference).
I'll maybe build it at the weekend. And cry when the EXPO fails :roll:
7,545 (1.77/day)
You clearly forgot about the key ingredient ~ dual socket 256c/512t Zen5c(3d?) EPYC's :slap:
dgianstefani
TPU Proofreader
5,045 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
AP201 is great case, just bear in mind the psu/cpu size compatibility is either/or, you can't max out both. I tried a 10mm shorter psu with a 4080 and although both were well within specs of "support" they didn't fit together.
No mention of this of course in the documentation.
the54thvoid
13,070 (2.39/day)
Software W10
Max PSU is 180, the beQuiet is 160. I'll be pissed if the 320mm GPU and that isn't compatible. As you say, it's not mentioned in the literature.
Edit: I'll break things to make it work.
10,793 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 CL30-36-36-76
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Super excited to see this build and process -- let us know how it goes.
dgianstefani
TPU Proofreader
5,045 (1.99/day)
Swansea, Wales
System Name Silent
I think I used a dark power 12, which was 175mm and a 330mm GPU, that didn't fit at all.
3,015 (0.83/day)
That´s indeed a nice wife you have. Praise your self lucky. Very lucky. Be sure to spoil her a bit back for this.
Pc parts looks good to. christmas in summer. Remember the feeling when building my current pc two years ago after having the same X58 system for twelve dam years.
the54thvoid
13,070 (2.39/day)
Software W10
I've already checked the case - The GPU is < 320mm, it doesn't reach the PSU enclosure area. It'll be good.
6,835 (4.74/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Congrats on your new beast, man. That is one sweet build :toast:
the54thvoid
13,070 (2.39/day)
Software W10
Seriously, I've been away from this for too long. I've not built a complete new system for 6 years. That's a lot of rust. The system is assembled now (and sitting in case), but I'm holding off the start-up until later in the week. Need to find an HDMI for the CPU iGPU to connect to monitor. Using DP with my 4070ti in my current PC. I figure I can link the HDMI and have both PC's connected (though not on), and cycle the display output via the monitor. That way I don't have to disassemble the PC I'm typing on at the moment (no iGPU - once I remove the 4070ti, there's not output).
I'm using the 12v ATX3.0 GPU cable, even though it's rigid as a dead man's fingers. I've bent the cable 30mm from the header to allow it to flex inside the case. With the height of the GPU though, I may not be able to put the side on. This is where the ATX3.0 design choice starts to show it's flaws, in that it is a limiting factor for fit in some conditions (worse than the old connectors, at least).
42,359 (6.65/day)
View attachment 302403View attachment 302404
You should look up the combo I did in 2021.
Zalman Z1 Neo
AsRock B550 Steel Legend
Thermalright ARO-M14G
Seasonic Focus (GX) 650
That case was cramped. I had to use a pair of long needle nose pliers to plug the EPS 12V connector in.
It cleared due to the joggled window flange.
the54thvoid
13,070 (2.39/day)
Software W10
Progress report:
System running correctly at BIOS stage - no errors to see. Updated to latest BIOS (30th May) E7D76AMS.A50. So that should keep the CPU safe from mobo vendor over-volting.
Need to figure what to do with regard to OS. Go with Win 10 or 11? Either way, it's another £100.
dgianstefani
TPU Proofreader
5,045 (1.99/day)
Swansea, Wales
System Name Silent
Progress report:
You paying full price for Windows?
10 LTSC is my suggestion.
