Newb trying to get to 3200MHz
6 (0.00/day)
System Name Mine
Processor Ryzen 7 2700x
Motherboard MSI x470 Gaming Pro Carbon
Cooling Wraith
Memory 32gb (4x 8gb) Corsair Vengeance LPX 3200MHz
Video Card(s) Zotac RTX 3080ti
Storage NVME Samsung 970 EVO m.2a 1TB, Samsung 860 EVO 1TB
Display(s) MSI Optix AG32c
Case NZXT H710
Power Supply EVGA Gold 1000W
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
This will probably be a repeated question, and a dumb newb question, so I apologize in advance.
My system only seems to be clocking the memory at 2133MHz, no matter what settings I've tried messing with. I only know enough to damage something, so I'm trying to keep this as simple as possible. I have no desire to OC everything. I just want my memory to run at or near 3200MHz if possible. If not, I'd just like to identify what the issue is, be it hardware or software incompatibility, wrong settings, etc. I have the most updated BIOS version. A-XMP is enabled, and I've tried both profile options. I have not messed with any voltages or timing. I'll put some screenshots up for reference.
43,250 (6.74/day)
Are those vengeance memory fully compatible with ryzen from the Corsair website? Corsair has been a huge problem with vengeance ram on ryzen platforms. If there is no ryzen badge, sell them.
6 (0.00/day)
System Name Mine
Cooling Wraith
Case NZXT H710
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
43,250 (6.74/day)
Do you know how to save settings in the uefi bios. What does the DOCP/AMP profiles give you for the memory?
You may need that
And then this.
6 (0.00/day)
System Name Mine
Cooling Wraith
Case NZXT H710
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
Yes, I make sure to hit "save changes and reboot" before leaving BIOS, if that's what you mean. The 2 profiles are:
Profile1: DDR4 2933MHz 16-18-18-36
Profile2: DDR4 3200MHz 16-18-18-36
But no matter which one I select, my readings in Hwinfo64 are
Clock - 1066.4 MHz Mode- Dual Channel CR-2T
Timing 15-15-15-36 tRC 51 tRFC 374
Edit: I've looked at the DRAM calculator, but it mights well be in Greek to me.
1,758 (0.32/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
If those are indeed 4x dual rank sticks and you're trying to cram 8 ranks on two channels, and overclock them on 2700x then good luck. It might be easier to find the top stable frequency, whether it is 2666, 2993, or whatever then try tightening timings. Corsair Vengeance hates Ryzen, but you should be able to manually tune. My wife has that same mobo and 64GB (4x16) of CJR but she's running a 5800x. Pretty sure also that board is series (daisy chained) so 4 sticks is even harder to OC.
43,250 (6.74/day)
Get a screenshot of hwinfo 64, update it even
6 (0.00/day)
System Name Mine
Cooling Wraith
Case NZXT H710
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
So are you saying that I should be using 2 - 16gb sticks instead of 4 -8gb sticks? I did buy 2- 16gb packages of the RAM when I got it.
here you go.
My plans for the next week or two are to upgrade to a 5800X and new cooler, and get some new 3600MHz RAM, but I want to make sure I'll get full performance from the RAM before I spend the money. I never considered the difference between running 2 pairs of 16gb sticks. I didn't think it mattered.
1,758 (0.32/day)
Azalea City
System Name Main
Cooling Water
Memory Ballistix
Display(s) MAG401QR
Case QUBE 500
Software 11 Pro
here you go.
Not to say you can't do it, but you have two factors working against you.
Series circuit RAM slot layout (daisy chain) motherboards prefer 2 slots filled over 4, but even with 4 you can usually just overvolt them to make up for signal drop.
The memory controller on the Ryzen 2700x is designed for up to two 2933MT/s single rank DIMMs at JEDEC timings. You can see how many ranks your DIMMs are organized into via Thaiphoon burner or AIDA64. Older 16GB sticks are usually 2 ranks, and the newer ones are single. For most performance you want 4 ranks over 2 channels (interleaving), but 2 ranks over 2 channels is easier on the memory controller.
Each 16GB package is probably 2 ranks per DIMM and certified to run as such. The reason the packages of 4x16GB DIMMs cost more is because they are probably denser ICs with 1 rank per DIMM.
Motherboard and Memory vendors really need to explain this stuff better.
43,250 (6.74/day)
here you go.
If i were you id get away from corsair and use gskill, crucial, ADATA, Geil, Team, Mushkin.
6 (0.00/day)
System Name Mine
Cooling Wraith
Case NZXT H710
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
So I guess my next logical question would be, considering the rest of my specs, keeping the same MoBo, upgrading to a 5800X, for replacing RAM, should I go with 2 16gb sticks, and if so, what would you recommend?
I already had a set of Crucial Ballistix RAM in my cart, but 2 packs of 16gb. I'm guessing I should spend the extra $20 for 2 16gb sticks then?
43,250 (6.74/day)
Can it handle a 5800X? Can the board handle ram higher than 3466?
6 (0.00/day)
System Name Mine
Cooling Wraith
Case NZXT H710
Mouse Corsair
Keyboard Corsair
VR HMD HP Reverb G2
Everything I've researched says it can, but I'd defer to your judgement with more experience.
So now I'm not so sure. Pcpartpicker doesn't list it as compatible, but pangoly does.
3,760 (1.91/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 200W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2605), upgraded from Win10 to Win11 on Jan 2024
I guess some do not know that Z series (Z3200) corsair LPX memory is compatible with Ryzen... I use a a Z kit with my R5 3600 (see PC specs) at 3733MHz.
It’s just that ZEN/ZEN+ is more picky with memory than latest ZEN2/3 and not really officially supports 3200MHz, even tho I build a Zen (1500X) PC with LPX 3200 memory 3.5years ago and has no issues. But this system as mine is 2 stick builds and not 4.
4 stick configurations are even harder with ZEN/ZEN+ at higher than 2933 speeds. It’s hard to get stability even with ZEN2/3 at higher than 3200MHz.
45 (0.03/day)
System Name pc
Processor İ7 11700K
Motherboard ASUS ROG Z590-F
Cooling Lian Lİ Galahad 360
Memory Crucial Ballistix RGB 3200 MT/S tCL16
Video Card(s) ASUS ROG STRIX RX 6700XT OC
Storage 980 PRO 500GB+Crucail P5 500GB + WD BLUE 1TB HDD
Case Corsair 5000D Airflow
Power Supply Corsair RM850
Mouse Asus Pugio II
Keyboard XPG Summeoner Cherry MX Red
Software WINDOWS 10 PRO
Yes, you can keep 1:1:1 ratio between 3800-4000, I don't know if 2000 FCLK will cost but 3866 DRAM-1933FCLK Possible
4,518 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
On a X570 board yes but I doubt that a X470 will go much above 3466 and I will keep believing that until someone post proof of otherwise.
45 (0.03/day)
System Name pc
Processor İ7 11700K
Mouse Asus Pugio II
Yes, Zen and Zen+ IMC limit 3466 in general
4,518 (0.81/day)
Denmark
I will have to adjust my view on things a bit since that board has 4000 and 4133 Gskill 2X8 GB kits on the QVL for 3000 Zens but nothing above 3200 for 2000 series.
45 (0.03/day)
System Name pc
Processor İ7 11700K
Mouse Asus Pugio II
In Zen 2, the limit is above 3733-3800 fabric clock : latency increases due to uclk clock
