Newbie needing help with getting surround sound from PC
Status
Not open for further replies.
818 (0.36/day)
System Name Dell Inspiron 7375
Processor AMD Ryzen™ 7 2700U Mobile Processor with Radeon™ RX Vega 10 Graphics
Memory 16GB (total) 2400MHz DDR4 SODIMM
Video Card(s) Radeon™ RX Vega 10 Graphics
Storage SanDisk X600 SATA SSD 512GB
Display(s) BOE NV13FHM
Audio Device(s) Realtek ALC3253 (Dell Labelling) ALC255 (Real name)
All right OP my suggestion is to run like my setup. Don't plug the GPU to the AVR than tv as you'll get latency which depending on games sucks
How i run my 5.1 Setup
Take the HDMI cable from the GPU to the TV, than take another HDMI cable from the TV HDMI Port labeled ARC and plug it directly to the AVR. This will allow Dolby HD and DTS HD and you will be able to control volume and power with the TV remote.
But you must note what you are playing or watching must support 5.1/7.1 which may require you going in there menu settings and changing audio profile specifically games.
ARC, in OP case cannot do HD formats; it is similar to spdif.
Durvelle27
6,788 (1.50/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700
Video Card(s) ASUS DirectCU II R9 290 4GB
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Depends on the TV
Most newer TVs made in 2019 and above support eARC which supports higher bandwidth for HD formats.
But we need to know what source material the OP will be using as most moves and games don't support lossless\ HD audio formats
818 (0.36/day)
Depends on the TV
The receiver doesn't support eARC.
FreedomEclipse
~Technological Technocrat~
24,028 (3.74/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
can we all just BTFU until the OP comes back and posts something rather than turning this thread into a mud slinging match??
if you gotta bro-down then take it to pms, stop unnecessarily shitting up the thread
trickson
OH, I have such a headache
7,595 (1.04/day)
Planet Earth.
System Name Ryzen TUF.
Processor AMD Ryzen7 3700X
Motherboard Asus TUF X570 Gaming Plus
Cooling Noctua
Memory Gskill RipJaws 3466MHz
Video Card(s) Asus TUF 1650 Super Clocked.
Storage CB 1T M.2 Drive.
Display(s) 73" Soney 4K.
Case Antech LanAir Pro.
Audio Device(s) Denon AVR-S750H
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
I game with my setup. No problem here. Though the the signal drops to PCM but PCM is able to carry 5.1 and 7.1 streams. The only real caveat I see is you can kiss goodbye to EAX. But there hasn't been any new titles that made use of that tech in a very long time.
Use the AVRs audio profiles to get the best out of gaming and movies
OMFG I have been saying this too but I am told that there is NO WAY IN HELL that PCM can transmit 5.1 nor 7.1 hell from what I have been told PCM is nothing more than stereo! WTF!
freeagent
8,470 (3.76/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Why are you using PCM? Gross..
Durvelle27
6,788 (1.50/day)
Memphis, TN
I think it clearly flew over your head
From my ready though of the thread, no one ever said PCM is stereo
The statement was clearly optical can't transmit uncompressed 5.1/7.1 which is 100% true. Meaning no it can not transmit DTSHD or DolbyHD
But it can transmits standard dolby and dts compressed formats
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
All I know is I am done!
You people are right that is all. good luck.
I have banged my head about this long enough.
818 (0.36/day)
7,508 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Get a stiff one... I am usually out of these half arsed audio threads, it too hard to teach someone, the others also don't understand and sink the boat completely.
Once and for all... don't post if you don't understand and steer out of the threads.
SPDIF does support ONLY 2 channel PCM stream. It cannot do more due to limited bandwidth.
Do NOT mix up the darn HDMI, as that is capable of multi channel PCM.
Multi channel through SPDIF is done with compression algorithms, in order to have enough bandwidth, those are - DTS and Dolby Digital.
Are we clear now?
freeagent
8,470 (3.76/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Multichannel gaming uses PCM.
What is gross in PCM?
Nothing gross about it at all, I thought everyone was into the DD thing. If it sounds good use it. I've seen multichannel gaming use dd and dts too, all good.
818 (0.36/day)
Not on PC. Game engines send out uncompressed PCM signals.
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Are we clear now?
YES SIR!
27,617 (6.65/day)
That is not only incorrect, but it's downright silly.
S/PDIF is based on the AES3 interconnect standard.[3] S/PDIF can carry two channels of uncompressed PCM audio or compressed 5.1/7.1 surround sound (such as DTS audio codec); it cannot support lossless surround formats that require greater bandwidth.[4]
Please review.
818 (0.36/day)
That not only incorrect, but it's downright silly.
Please review.
"two channels of uncompressed PCM audio or compressed 5.1/7.1 surround sound (such as DTS audio codec)"
What part is incorrect? Unclear?
Original post said "2 channel PCM" or "Multi channel through SPDIF is done with compression algorithms, in order to have enough bandwidth, those are - DTS and Dolby Digital"
P.s. Sorry to OP, still going to semantics of formats instead of discussing real specific needs.
Durvelle27
6,788 (1.50/day)
Memphis, TN
27,617 (6.65/day)
Let's review;
That's what he said and my response was;
Please review.
Where is your difficulty of understanding?
818 (0.36/day)
@lexluthermiester Lower in the same comment DTS compression over SPDIF was explained. Thus the Wikipedia line
was fully explained in the original comment.
27,617 (6.65/day)
The point was that it was stated that SPDIF could ONLY do 2 channel PCM, which is patently false. SPDIF can do 2 channel uncompressed AND 5.1/7.1 compressed.
That was the false statement and that is what I addressed. Why are you arguing? :kookoo:
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Please review.
I was trying to say this but man did you see the beat down I got?!
I am now starting to get offended by some of the comments directed at me. I know I am RIGHT yet told how wrong I am? WTF!
RIGHT! I am really at a loss on to how I am wrong!
I guess my ears not only are lying to me but so is my OSD telling me digital Dolby surround , 7 channel and the like right? ALL FROM THE FIBER OPTIC CABLE! OMG NO!!!!!!!!!
27,617 (6.65/day)
Yup, saw it.
Your frustration is easily understood. :toast:
You're not wrong, they're trolling you, which is why I jumped in with a statement of fact that they can not refute. The only argument they have left will be one of ego, little more.
trickson
7,595 (1.04/day)
Planet Earth.
Cooling Noctua
Mouse Optical
Yup, saw it.
Your not wrong, they're trolling you, which is why I jumped in with a statement of fact that they can not refute. The only argument they have left will be one of ego, little more.
Thank you so much man it's just so frustrating knowing the sky is blue but being told it's really GREEN!
7,762 (2.82/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
You're misreading the statement. You're reading it to say "SPDIF can only do 2-channel PCM and nothing else, period." What it's meant to say, which is clear from both the rest of the post and the rest of this thread is "SPDIF can only do 2-channel PCM, no more channels than that of uncompressed audio." Sure, there is some ambiguity in the wording, but you're reading this directly against all relevant context and then stating that it's wrong. I think you're the one who should review.
Edit: to make this a bit more clear: you're reading this as "SPDIF can ONLY do [X]" where X is 2-channel PCM. The correct reading would be "SPDIF can only do [X] channel PCM" where X is 2. I don't know the linguistic terms for this, but you're misreading this entirely.
7,762 (2.82/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Wow, @lexluthermiester, here I had the impression that you were one of the more sensible people on these forums in terms of people actually capable of having an adult exchange of views, and you like that post? Damn, that's disappointing.
@trickson for the entirety of this thread you have been saying that SPDIF is capable of transferring more than two channels of uncompressed audio. You have been arguing harshly against people stating that no, for SPDIF to support more than two channels, the audio must be compressed. Yet here you are saying you agree with Lex when he (through misunderstanding a previous post) states exactly that. Care to explain?
Status
