No signal detected afther upgrade
akimboReapy
2 (0.01/day)
Im having bit of a issue, i upgraded my pc from ryzen 3 integrated GPU to Ryzen 5 4500 and gtx 1660 super
For no reason it doesn't want to display anything and only says "no signal" on my monitor
Specs:
Asus prime B350-plus
Msi Gtx 1660 super
16gb ram
Ryzen 5 4500
500w pws
2,789 (2.16/day)
Germany
System Name Sunk Cost Fallacy
Cooling Thermalright Phantom Spirit 120
Storage WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo.
Display(s) Alienware AW2723DF, LG 27GR93U, LG 27GN950-B
Case Streacom BC1 V2
VR HMD Oculus Rift S
did you plug your displaycable in your GPU?
2,199 (0.47/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Video Card(s) Sapphire Nitro+ Radeon RX 6750 XT
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Dead CPU or motherboard problem.
In the case of video cards, OTOH, I would reseat the video card, been having that issue with my Asus socket 1366 motherboards for some reason, especially my GTX 970, IIRC.
Looks more like you need another motherboard though!
2,789 (2.16/day)
Germany
1,810 (0.40/day)
Romania
Specs:
Msi Gtx 1660 super
16gb ram
Ryzen 5 4500
500w pws
Did you update the BIOS to the latest version ? https://www.asus.com/supportonly/prime b350-plus/helpdesk_bios/
If you still have the old CPU, put it back in, install the latest BIOS in the link above then put the 4500 back in and it should work.
2,199 (0.47/day)
System Name KHR-1
Case Corsair 275R
Thats a bit extreme lol. Probably just need to update the BIOS. I would put the old CPU back in and if all is good update the BIOs and try again.
Update: Or motherboard problem.
Mussels
Freshwater Moderator
58,413 (8.05/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
I don't have a displaycable
He didnt say display port, you probably use a HDMI cable.
If you connect it to the onboard graphics, you wont get an image if the systems running off the dedicated card now.
Post clear photos of the assembled system, starting with a shot that shows the insides of the PC clearly
189 (0.12/day)
WorldWideWeb
System Name MPG
Processor i3-10105F
Motherboard Z490 Gaming Plus (MS-7C75)
Cooling Be Quiet Dark Rock Advanced
Memory GSkill RipJawsV 32Gb 3200
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMW WD Black SN750 Samsung EVO 840 SSD and Mechanical TBs...
Display(s) Asus VS278Q
Case CM HAF-X
Audio Device(s) ALC1200 Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
R5 4500 needs bios 6042 (2022/05/12)
These and other, are important hardware details to provide when posting in a forum regarding such issues.
CLR CMOS, put back old APU, update the bios.
CLR CMOS again and put back the R5 4500.
486 (0.17/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Did you use something like DDU (Display Driver Uninstaller) to get rid of the old drivers before you put the new GPU in?
It looks like that's Ryzen 5 4500, but not 4500G, there's no IGP anymore.
Mussels
58,413 (8.05/day)
Oystralia
Same problem in the end, yes i could have worded that post better.
If theres no IGP in the CPU, connecting to those connections gives no signal.
