Noctua and Seasonic Introduce Ultra-quiet 1600W Power Supply
4,849 (0.97/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
424 (0.27/day)
Toronto
System Name GraniteXT
Processor Ryzen 9950X
Motherboard ASRock B650M-HDV
Cooling 2x360mm custom loop
Memory 2x24GB Team Xtreem DDR5-8000 [M die]
Video Card(s) RTX 3090 FE underwater
Storage Intel P5800X 800GB + Samsung 980 Pro 2TB
Display(s) MSI 342C 34" OLED
Case O11D Evo RGB
Audio Device(s) DCA Aeon 2 w/ SMSL M200/SP200
Power Supply Superflower Leadex VII XG 1300W
Mouse Razer Basilisk V3
Keyboard Steelseries Apex Pro V2 TKL
I've used Seasonic primes all my life and they've been rock solid. I'm sure this is a great PSU but they've increased the prices for the prime lineup quite a bit and Vertex isn't as great for the price.
So to prep for my upcoming build, for $200 I got a SuperFlower Leadex VII 1300W + 3x 120mm Megacool fans for free. Hwbusters reviewed the 1000W Leadex VII and it sits at the top of their 1KW PSU chart. 1300W was only 20 more so figured might as well.
This fan grille looks sick though, I wish it was sold separately.
43,571 (6.77/day)
Should have used a Gentle Typhoon or a black fan
3D Print 1
4,849 (0.97/day)
Firstly, it's a halo product,
this, it gets people talking about the brands and articles on all the tech web sites. End of day the majority of people who need that performance and want to go with seasonic will get the regular PRIME TX-1600
2,829 (6.36/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Sure, but counterpoint - when you already are paying 500 you might as well go full hog and add 70 for the Noctua Edition to get (theoretically) better and quiter cooling on it. Although that would all depend on availability - might end up being a very limited drop, like the Asus Noctua GPU collab which were, at least from what I heard, near unicorns.
4,849 (0.97/day)
sure if you want but you would need to be pushing that PSU to some high wattage to really hear that difference (BTW I think it's great so I'm not knocking the unit)
Noctua version
Because of the load pattern that I apply, the fan’s semi-passive operation doesn’t last long, but the fan’s speed is within 400-600 RPM at up to 1050W, so the noise output is below 6 dBA. Actually, the fan’s noise doesn’t exceed 6 dBA at up to around 1120W. Moreover, the fan’s noise doesn’t exceed the 30 dBA mark, even at full load. Compared to the “plain” TX-1600, the average noise output difference is 8 dBA, which aligns with what Noctua claims.
regular TX-1600w
Because of the load pattern that I applied, the semi-passive operation didn’t last long, but thanks to the super-relaxed fan speed profile, noise output is minimized at up to 1000W loads. With up to 1300W, the PSU doesn’t exceed 25 dBA, and the unit enters the 30-35 dBA zone at around 1480W. The high efficiency minimizes the thermal loads, so the cooling fan doesn’t have to spin fast to remove the heat.
424 (0.27/day)
Toronto
Case O11D Evo RGB
5,690 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Corsair TX
80+ rating in 2007, I mean its good enough I guess, but it wasnt even bronze?
Idk, not something I would use to power my 600+ dollar gpu, let alone the rest of it.
9,758 (3.47/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Corsair TX line is not budget. Can you believe these used to be $89.
2,829 (6.36/day)
There WAS no Bronze/Silver/Gold delineation in 2007 yet. So it was what it was - either a PSU had 80+ cert or not.
9,758 (3.47/day)
Cooling In Win SR36
For me one of the buyers of this will be people with money to afford a 5090 and whatever Intel gives us with the refinement of the new node. With that about 800 will be the realistic power draw. There are people that look for that ultimate 50% highest efficiency curve. Truth be told a PSU this expensive should have a USB connection so that you can control the fan and monitor it in HWinfo.
443 (0.09/day)
Pricing aside, I like the idea. Most PSUs have horrendous working acoustics when you really push them (or even when not in many cases).
However my biggest issue with this model is 210mm length. It's like 2016 has called and wants its enormous PSUs back. You can easily fit Titanium/Platinum grade 1.6kW PSU inside 150-160mm shroud. 2kW and above I understand. You need more & thicker stuff inside. Dealing with such long devils is utter pain in backside in most cases.
2,266 (1.23/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
