System Name | HTC's System |
Processor | Ryzen 5 5800X3D |
Motherboard | Asrock Taichi X370 |
Cooling | NH-C14, with the AM4 mounting kit |
Memory | G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB |
Video Card(s) | Sapphire Pulse 6600 8 GB |
Storage | 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III |
Display(s) | LG 27UD58 |
Case | Fractal Design Define R6 USB-C |
Audio Device(s) | Onboard |
Power Supply | Corsair TX 850M 80+ Gold |
Mouse | Razer Deathadder Elite |
Software | Ubuntu 20.04.6 LTS |
Why isn't anybody screaming or making videos about the blatant ripoff of Scythe fans?! I guess people only do that when they already hate the company, like they did with Thermaltake. These people are so objective...
System Name | No name / Purple Haze |
Processor | Phenom II 1100T @ 3.8Ghz / Pentium 4 3.4 EE Gallatin @ 3.825Ghz |
Motherboard | MSI 970 Gaming/ Abit IC7-MAX3 |
Cooling | CM Hyper 212X / Scythe Andy Samurai Master (CPU) - Modded Ati Silencer 5 rev. 2 (GPU) |
Memory | 8GB GEIL GB38GB2133C10ADC + 8GB G.Skill F3-14900CL9-4GBXL / 2x1GB Crucial Ballistix Tracer PC4000 |
Video Card(s) | Asus R9 Fury X Strix (4096 SP's/1050 Mhz)/ PowerColor X850XT PE @ (600/1230) AGP + (HD3850 AGP) |
Storage | Samsung 250 GB / WD Caviar 160GB |
Display(s) | Benq XL2411T |
Audio Device(s) | motherboard / Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Pro + Front panel |
Power Supply | Tagan BZ 900W / Corsair HX620w |
Mouse | Zowie AM |
Keyboard | Qpad MK-50 |
Software | Windows 7 Pro 64Bit / Windows XP |
Benchmark Scores | 64CU Fury: http://www.3dmark.com/fs/11269229 / X850XT PE http://www.3dmark.com/3dm05/5532432 |
How so???
The blade can be approximated by a cantilever beam fixed at the fan hub. There can be flapwise, chordise and torsional vibration (torsional is due to the excitation due to the propelling forces). In this problem the critical speeds will depend not only on the geometry of the blade, material properties (density + stiffness (torsional and transverse) and viscoelasticity (material damping) ) but also on the rotational speed of the blade because there will be a stiffening effect due to the centrifugal forces (depend on the density and rotational speed) acting upon the blade. If the rotational speed of the fan crosses or is close enough to one of the natural frequencies of this system (critical speed) or if the excitation due to air flow and even parasitic vibrations introduced by external elements are close to the critical speed (eg: other fan slightly of balance in any other point on the case) the vibrations on the fan can be significant.
This means that in one scenario the fan with the new material/geometry can be better than the old one, but in other scenarios the old one can be better (in terms of vibrations).
I hope that this was clear enough, if you have questions don't hesitate in posting them.
Best regards
System Name | LenovoⓇ ThinkPad™ T430 |
Processor | IntelⓇ Core™ i5-3210M processor (2 cores, 2.50GHz, 3MB cache), Intel Turbo Boost™ 2.0 (3.10GHz), HT™ |
Motherboard | Lenovo 2344 (Mobile Intel QM77 Express Chipset) |
Cooling | Single-pipe heatsink + Delta fan |
Memory | 2x 8GB KingstonⓇ HyperX™ Impact 2133MHz DDR3L SO-DIMM |
Video Card(s) | Intel HD Graphics™ 4000 (GPU clk: 1100MHz, vRAM clk: 1066MHz) |
Storage | SamsungⓇ 860 EVO mSATA (250GB) + 850 EVO (500GB) SATA |
Display(s) | 14.0" (355mm) HD (1366x768) color, anti-glare, LED backlight, 200 nits, 16:9 aspect ratio, 300:1 co |
Case | ThinkPad Roll Cage (one-piece magnesium frame) |
Audio Device(s) | HD Audio, RealtekⓇ ALC3202 codec, DolbyⓇ Advanced Audio™ v2 / stereo speakers, 1W x 2 |
Power Supply | ThinkPad 65W AC Adapter + ThinkPad Battery 70++ (9-cell) |
Mouse | TrackPointⓇ pointing device + UltraNav™, wide touchpad below keyboard + ThinkLight™ |
Keyboard | 6-row, 84-key, ThinkVantage button, spill-resistant, multimedia Fn keys, LED backlight (PT Layout) |
Software | MicrosoftⓇ WindowsⓇ 10 x86-64 (22H2) |
Like a bug or anything small enough to fly past the grills of the chassisUnless this sort of thing can be cause by a non-related PC case component?
Rigidity means something has to provide some dampening to what the fan will produce as vibration in the blade hub -> Axle -> Shaft -> Frame...if it's reflected against the fan, it cannot eliminate it, it will just add to the overall system...if i'm not mistaken here...
Mouse | Zowie AM |
I'm assuming they did extensive testing to come up with this material: seriously doubt any problems like the ones you describe surfaced @ the regular operating speeds. @ higher speeds, perhaps.
System Name | WorkInProgress |
Processor | AMD 7800X3D |
Motherboard | MSI X670E GAMING PLUS |
Cooling | Thermalright AM5 Contact Frame + Phantom Spirit 120SE |
Memory | 2x32GB G.Skill Trident Z5 NEO DDR5 6000 CL32 |
Video Card(s) | Asus Dual Radeon™ RX 6700 XT OC Edition |
Storage | WD SN770 1TB (Boot)|1x WD SN850X 8TB (Gaming)| 2x2TB WD SN770| 2x2TB+2x4TB Crucial BX500 |
Display(s) | LG GP850-B |
Case | Corsair 760T (White) {1xCorsair ML120 Pro|5xML140 Pro} |
Audio Device(s) | Yamaha RX-V573|Speakers: JBL Control One|Auna 300-CN|Wharfedale Diamond SW150 |
Power Supply | Seasonic Focus GX-850 80+ GOLD |
Mouse | Logitech G502 X |
Keyboard | Duckyshine Dead LED(s) III |
Software | Windows 11 Home |
Benchmark Scores | ლ(ಠ益ಠ)ლ |
Processor | Ryzen 2600x |
Motherboard | ASUS ROG Strix X470-F Gaming |
Cooling | Noctua |
Memory | G.SKILL Flare X Series 16GB DDR4 3466 |
Video Card(s) | EVGA 980ti FTW |
Storage | (OS)Samsung 950 Pro (512GB), (Data) WD Reds |
Display(s) | 24" Dell UltraSharp U2412M |
Case | Fractal Design Define R5 |
Audio Device(s) | Sennheiser GAME ONE |
Power Supply | EVGA SuperNOVA 650 P2 |
Mouse | Mionix Castor |
Keyboard | Deck Hassium Pro |
Software | Windows 10 Pro x64 |
System Name | Indis the Fair (cursed edition) |
Processor | 11900k 5.1/4.9 undervolted. |
Motherboard | MSI Z590 Unify-X |
Cooling | Heatkiller VI Pro, VPP755 V.3, XSPC TX360 slim radiator, 3xA12x25, 4x Arctic P14 case fans |
Memory | G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3600 14-14-14 1.45v) |
Video Card(s) | EVGA 2080 Super Hybrid (T30-120 fan) |
Storage | 970EVO 1TB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB |
Display(s) | BenQ XL2546K, Dell P2417H |
Case | FD Define 7 |
Audio Device(s) | DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5 |
Power Supply | Seasonic 860w Platinum |
Mouse | Razer Viper Mini, Odin Infinity mousepad |
Keyboard | GMMK Fullsize v2 (Boba U4Ts) |
Software | Win10 x64/Win7 x64/Ubuntu |
Anyone who believed any of the "Scythe" ripoff fans made so far were any good has clearly knows nothing about fans. The GTs already had a remarkably tight blade tip clearance, none of the GT copy fans had similar clearance. The SSTs don't even use a larger bearing... I hope these noctuas live up to the job and do actually compete with or outperform the GTs, because it is really ridiculous that the companies selling fans have not made any progress in performance or noise since the GTs were originally released, yet people still believe in all the marketing crap that companies like Corsair, NZXT, TT, SST, etc throw out. Even from Noctua I have heard a fair share of what I'd call "objectively bullshit" claims when it comes to their fans.Why isn't anybody screaming or making videos about the blatant ripoff of Scythe fans?! I guess people only do that when they already hate the company, like they did with Thermaltake. These people are so objective...
Scythe didn't make any of the GTs, so let's get that cleared for everyone. The company making and selling them is Nidec-Servo, and currently you can still buy them from a couple of vendors in North America. I will soon have one of those reviewed on TPU as well.
The EK Vardar has fewer blades and a raised lip so it's not really a copy. The closest visually are the Swiftech Helix120 and Silverstone FQ121 but even here both have small differences visually and larger differences performance wise as mentioned before. So until I get to see these new Noctua NF-A12 fans in person and test them myself, I will keep an open mind and not judge them as copies or clones or anything.
System Name | Cumquat 2021 |
Processor | AMD RyZen R7 7800X3D |
Motherboard | Asus Strix X670E - E Gaming WIFI |
Cooling | Deep Cool LT720 + CM MasterGel Pro TP + Lian Li Uni Fan V2 |
Memory | 32GB GSkill Trident Z5 Neo 6000 |
Video Card(s) | PowerColor HellHound RX7800XT 2550cclk/2450mclk |
Storage | 1x Adata SX8200PRO NVMe 1TB gen3 x4 1X Samsung 980 Pro NVMe Gen 4 x4 1TB, 12TB of HDD Storage |
Display(s) | AOC 24G2 IPS 144Hz FreeSync Premium 1920x1080p |
Case | Lian Li O11D XL ROG edition |
Audio Device(s) | RX7800XT via HDMI + Pioneer VSX-531 amp Technics 100W 5.1 Speaker set |
Power Supply | EVGA 1000W G5 Gold |
Mouse | Logitech G502 Proteus Core Wired |
Keyboard | Logitech G915 Wireless |
Software | Windows 11 X64 PRO (build 24H2) |
Benchmark Scores | it sucks even more less now ;) |
Reminds me of Gentle Typhoons.
