NVIDIA "Ampere" 12-pin Power Connector Pictured Some More
20 (0.00/day)
South Borneo
Processor 9900k, 3950x
Motherboard Z370 Strix, Max Hero
Cooling NZXT X72, TT M360 Plus
Memory Trident Z RGB 32g, Royal 32gb
Video Card(s) 2080Ti FE, 3080 Strix Gundam, 3090 Strix
Display(s) Dell S2716DG, 34" Ultrawide
Case Lian-Li O11DW, TT Core P3 White
Power Supply Seasonic
No I'm saying this new plug is more about cable management than new break through power delivery lol
Exactly, more compact for clean build especially for sli as you mentioned above.
I'll take this 12pin anyday
1,503 (0.37/day)
Processor 11900K
Motherboard ASRock Z590 OC Formula
Cooling Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas
Memory G. Skill Trident Z 2x16GB 3600MHz
Video Card(s) eVGA RTX 3090 FTW3
Storage 2TB Crucial P5 Plus
Display(s) 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz
Case Lian Li Lancool MESH II RGB (I removed the RGB)
Power Supply Seasonic Prime 850 TX
Mouse Glorious Model D
Keyboard Glorious MMK2 65% Lynx MX switches
Software Win10 Pro
what if the new plug is standing at 45 and 90° angle.
I seen that. Wtf was that, it was all space saving then stuck it in vertically. Maybe it saves more space on the PCB for something else.
32 (0.01/day)
So a card maker uses a smaller on-board connector and provides an adapter cable....
This makes world headlines? Raging arguments across the forums? Gawd.
Score another one for NVidia marketing which all by themselves can bury Radeon - better products or not.
1,227 (0.48/day)
Processor AMD Ryzen 9 5950X
Case Cooler Master Cosmos
Power Supply Corsair HX850i
Keyboard Cherry MX
So the nGreedia hype train is built on...
1.) A new triple slot cooler design, that's the bestest evaaaaar. Marketing BS for "It's hot".
2.) A new 12pin Molex connector that's the bestest evaaaaar. Marketing BS for "it's power hungry, and you have to look at buying a new 850W PSU anyway", 'cos it eats power for breakfast, and spits out heat.
3.) A new high price, which is the bestest evaaaaar. nGreedia BS for everybody needs to buy them a beer, because of all the good we do...
4.) I'm really struggling here...
Great... But I liked it more when there were new features and serious performance improvements to look forward to, and not just a space heater halo card pushed beyond its limits, while pushing the cost of entry to PC gamers in to the stratosphere, right at a time where we are looking at new consoles which will perform the same for all intents and purposes, for a fraction of the price, and problems.
I look forward to when sanity prevails, but I think that's a long way off.
647 (0.32/day)
I'm just talking about those 12 pins so they can't handle more amp than those 2x8 pins.What I thought that 12 pins is equal or better than 2x8 pins which is not true
Yup, the mini fit jr has superior current characteristics in same PCB area to micro fit. The problem is that they can’t just re-use the same connector as it would confuse people, so they simply chose the least bad other option.
2,772 (0.57/day)
East Europe
System Name PLAHI
Processor I5-13500
Cooling 120 AIO IWONGOU
Video Card(s) RX 6800XT
Case TT URBAN R31
Mouse Logitech Triathlon
Keyboard REDRAGON MITRA
Software Windows 11 Home x 64
Ahahaha, that was such a good observation/burn :). I love it when a department in a company does the job well.
On topic: we get an adapter, so not much to complain about. I'd prefer 10/10 for this adapter to be 90 degree or something like EVGA cable-hiding-thingy, but not proprietary of course.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Display(s) DELL U2311H
Keyboard Microsoft Wired 600
Smaller diameter of pin this might translate that actual male pin this is made of a different composition, perhaps more gold plating on it?
NVIDIA this feels confident that their own wired adaptor an 12P to double 8 Pin this will do the job too.
What is missing from the puzzle this is a high in resolution picture of the actual 12P connector pins over the graphic card.
25 (0.00/day)
London
Processor AMD Ryzen 7 3700X
Motherboard Gigabyte X470 AORUS ULTRA GAMING
Cooling Arctic Cooling Liquid Freezer II
Memory 32GB Corsair @ 3000Mhz
Video Card(s) AMD 5700XT
Storage Samsung NVMe 960 EVO
Display(s) 27" 2560x1440
Case Thermaltake Core P5
As an electrical engineer I spend far too much of my time choosing connectors with appropriate power specifications. It's probably one of the more boring aspects of my job. I'm finding it very amusing that there are now whole threads of discussion over a power connector! :laugh:
19,379 (3.46/day)
"zomg EnVidEaUh (EnGr33d1a) has 2 p0wer 1ts r3act0r"
...as said from the usual suspects. Par for this course!
306 (0.05/day)
EU
This card is for the 0.1% and they can easily buy a new PSU with the new cable, plus water cooling of course..
647 (0.32/day)
Wouldn't 5A per pin only supply 360W? (12 pins x 12V x 5A / 2: where "divided by 2" is because +power must also travel to the -power pins).
EDIT: Also +75W from the PCIe connection. So I guess 435W. IIRC, rumors are that this is a ~400W board, so I guess 5A per pin + 75W PCIe connection is within specifications. 2x8 pin is 300W (150W per 8-pin connector).
Yeah, but you can add more amps if you have active cooling for the connector, or don’t mind it melting.
2,062 (0.35/day)
Volos, Greece
System Name ATLAS
Were did you get this fake-news tip from ? Wikipedia for five years old ones ?
Temperature this generated at metal pins when amperage this is all ready excessive.
If the connector housing this become warm at 35C then you better stop right away of what you are doing.
14,545 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
"The cables going into the 12-pin connector appear to be of a higher gauge than the ones making up the 8-pin."
Shouldn't that be a smaller gauge?
The wire size has increased, making it a lower number, from 18AWG to possibly 16AWG.
That equates to roughly a 30% increase in power transmissable.
