NVIDIA GeForce RTX 5000 Series “Blackwell” TDPs Leaked, Entire Lineup Unified with 12+4 Pin Power Connector
7,493 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
as leaks have suggested the RTX 5070 might not even bet the RTX 4070 but will still cost properly more.
(I know several users will correct me on this, but I am still saying this, and only time in 2025 can tell what will happen fra NV's side if they don't just stick to their nickname NGreedia....)
I really hope that the "rumored" 8800 XT if AMD do not change the name is as good performance wise as power efficiency looks with rumours started with 220-275watt it would have been cool I believe to see AMD do something like this.
Energy Saving Mode: 220W
Normal Mode: 250W
OC Mode: 275W
It could be a physical switch on the board or a software toggle that just required a reboot than users could test which mode was the best for them power/performance wise.
3,986 (1.32/day)
Case Thermaltake Core P5
Keyboard Corsair K100 RGB
VR HMD HTC Vive Cosmos
Normal Mode: 250W
OC Mode: 275W
What? This has always been an option as is as easy or easier today. Open Adrenalin (or Nvidia app, or Afterburner) and set power limit to where you want it. In downwards direction it should work perfectly. Doesn't even require a reboot.
7,493 (1.04/day)
My RTX 4070 refuses to budge from 195W under full load, even tried undervolting it, it doesn't give a damn it just keeps going up to 195W even adding about is it 2000Mhz on the ram still just runs at 195W.
Plus it was meant for normal people that doesn't really do much and it would be easy.
I never had an issue really with my AMD cards they did great but my current Nvidia card from Asus just refuses.
3,842 (2.66/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
leaks just want clicks, and the more they make you upset the better for rage views, that makes no sense. Sure it happened before but there was the insane amount of unsold cards from the covid/crypto days to get rid off. That will not happen again, that's why they are no longer making 4000 series cards and stocks are dropping.
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
The "normal" TDP has increased a LOT in 2 decades. And gains from overclocking have gone down, also a LOT. From outside factors, cost of power has increased in most countries since then.
2 decades ago was 2004.
Cream of the crop GPUs were 6800 Ultra with its horrible 105W and X800 XT at 85-90W.
Best CPUs were Athlon 64s with 90W TDP. On Intel side the much-maligned Prescott P4s and older Gallatin P4EEs at 115W.
Potential overclocking gains, especially for 24/7 usage, were significant.
In most cases, TDP was not the limiting factor for performance and often enough parts did not consume up to TDP.
Compare this with today where high-end GPU consumes 300W and more. High-end CPU consumes over 200W.
Gains from overclocking are kind of there but for 24/7 usage the power cost for any performance increases is very bad.
Oh, and TDP is generally the limiting factor as well :)
We have gone from 250W or so for a high-end PC in 2004 to 600W or so in 2024. Or potentially much more if you have a 4090 and something like "TDP is just a suggestion" Intel CPU.
It would be a totally different story if performance hasnt improved much, but thats not the case. Performance these days is absolutely bonkers compared to what we used to have.
3,986 (1.93/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -25, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6200MT/s 1.42V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (370W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower, Fans: 9x140mm + 3x120mm
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3775), Install March 2025
True
In 20years power increased 5-10x and performance... 300-400x if not more
144 (1.06/day)
CO
System Name Zen 3 Daily Rig
Processor AMD Ryzen 9 5900X with Optimus Foundation block
Motherboard ASUS Crosshair VIII Dark Hero
Cooling Hardware Labs 360GTX and 360GTS custom loop, Aquacomputer HighFlow NEXT, Aquacomputer Octo
Memory G.Skill Trident Z Neo 32GB DDR4-3600 (@ 3733 CL14)
Video Card(s) Nvidia RTX 3080 Ti Founders Edition with Alphacool Eisblock
Storage x2 Samsung 970 Evo Plus 2TB, Crucial MX500 1TB
Display(s) LG 42" C4 OLED
Case Lian Li O11 Dynamic
Power Supply be Quiet! Straight Power 12 1500W
Mouse Corsair Scimitar RGB Elite Wireless
Keyboard Keychron Q1 Pro
I think you're mistaken about the jump in IPC from Ampere to Ada. The SMX is essentially the same; it was Ampere that saw nearly a 25% increase in clock normalized throughput per SMX compared to Turing. Turing also improved performance per SMX when compared to Pascal; just compare a 2070 Super to a 1080.
Ampere also improved the data pathing from Turing. Where Turing had a split of INT32 and FP32 per clock cycle, Ampere modified this pathing where the INT32 path could also do FP32, so you either had INT32/FP32 or FP32/FP32 per clock cycle per core. Ada is basically the same as Ampere (at least in how it manages that data per clock cycle). Biggest change from Ampere seems to be the massive increase in L2 cache and then of course new Tensor and RT cores and some other minor changes.
1,879 (1.50/day)
Mississauga, Canada
Processor Ryzen 7 5700X
Memory 2x16GB DDR4 3200
Case Fractal Design R5
Mouse Logitech
VR HMD Oculus Rift
For the most part, Ada is to Ampere what Pascal was to Maxwell: higher clocks with the same microarchitecture leading to much higher performance. For changes outside the shaders, your list covers it: the one standout feature is shader execution reordering.
144 (1.06/day)
CO
Thanks. The shader execution reordering was what I was thinking of for "other minor changes" but couldn't remember what it was called.
Also going from Samsung 8nm (a 10nm node) to TSMC N4 (5nm node) made a huge difference too. Very much like Maxwell to Pascal, exactly like you say.
298 (0.10/day)
Why would anyone want to buy a new PSU in order to run a 5060 or 5070? I don't get it. Why push a new PSU on cards that need up to 300w?
15,776 (6.86/day)
Midlands, UK
Processor AMD Ryzen 7 7800X3D @ 45 W TDP Eco Mode
Case Corsair Crystal 280X
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Even entry level cards requiring power through the new standard connector is a real bummer. The 5050 could have been a nice HTPC upgrade.
3,842 (2.66/day)
Mouse G502
what?! That most likely wont need a connector at all, and i don't care what any leaks say. Especially a PSU manufacturer that never uses the exact values
15,776 (6.86/day)
Midlands, UK
I don't expect any card that doesn't need external power these days, especially from Nvidia, but fingers crossed.
3,842 (2.66/day)
Mouse G502
the 3050 doesn't need one. And don't tell me is one generation old, because nvidia is actively selling them new on their own website. If you had a 4050 it most likely wouldn't require one either
3,986 (1.93/day)
Ay GPU card above 70-75W requires external power and even 3050 8GB FE is 130W.
Newer 4060 8GB FE is 115W and laptop oriented 4050 is 100W.
Very hard today for a GPU to be below 100W and can do even basic gaming.
Cant tell where 5050 will land or if it will be a dGPU for desktops.
3,623 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
3050 6GB LP seems to be doing okay for not needing a power connector
There is also the RTX 2000 ADA Workstation GPU without power connector
3,842 (2.66/day)
Mouse G502
there is a 6GB that doesn't require external power and don't forget 3000 series was using more power hungry samsung sand.
15,776 (6.86/day)
Midlands, UK
It's not hard. All we need is AMD/Nvidia limiting power and clocks in the BIOS. If they could do it with the RX 6400, then they could do it with a 7500, 3050, 4050, 5050, etc. as well.
3,986 (1.93/day)
What I’m saying is keeping power below 100W and also have adequate gaming performance.
Of course everything can be restricted, but with what performance.
Unless someone plays games with lowest settings 1080p
15,776 (6.86/day)
Midlands, UK
1080p low is totally fine at this price and performance range, let's be realistic.
411 (0.24/day)
In line and awaiting for the drop. Money is ready and earning interest while I wait.
Talking to you @ASUS ROG Strix!
118 (0.10/day)
Unbelievable! Are people going to pay 4-5k USD if not more for this card!? :roll: :kookoo:
1,287 (0.74/day)
System Name Gamey #2 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Red Dragon 6800 XT / Eagle 3070
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
100% on this.
The 4060 could be run at 70W and many laptop 4060s (almost identical specs to desktop 4060) run at that power level but there is a laptop 4050 which could (and IMO will in ~1 year) directly translate to a 70W desktop 4050. It's ~40% faster than the current 3050 6GB which itself is a very good slot-power only GPU for 8th to 11th Gen office machines, even being overkill for 3-7th Gen quad core machines.
411 (0.24/day)
That seems a stretch but IF you had a 3090 and got a 4090, you'd definitely would want a 5090 no matter what anybody else says
