NVIDIA GeForce RTX 5060 and RTX 5060 Ti Could Use Standard 8-Pin PCI Power Connectors
AleksandarK
2,777 (1.02/day)
The GPU market is heating this March as both NVIDIA and AMD prepare to launch competing mid-range graphics cards. NVIDIA's GeForce RTX 5060 and RTX 5060 Ti, part of its Blackwell architecture lineup, are rumored to debut alongside AMD's Radeon RX 9070 and 9070 XT, setting the stage for a high-stakes battle in the mainstream gaming segment. According to leaks from Chinese hardware sources at Douyin, including ZOTAC-affiliated leakers, the RTX 5060 series will retain traditional 8-pin power connectors instead of adopting NVIDIA's newer 12V-2x6 16-pin design, simplifying upgrades for users with older PSUs.
However, the cards will reportedly require a minimum 650 W power supply—a 100 W increase over the RTX 4060 series—with estimated total graphics power (TGP) of 150 W for the RTX 5060 and 200 W for the Ti variant. While NVIDIA has not confirmed specifications, the RTX 5060 Ti will reportedly launch in two variants: 8 GB and 16 GB GDDR7 configurations, leveraging a 128-bit bus.
1,257 (0.26/day)
South-Africa
Processor AMD Ryzen 9 5900X
Cooling Noctua NH-D15 G2
Video Card(s) ASUS GTX 1650 TUF
Storage SAMSUNG 990 PRO 2TB
Display(s) Dell S3220DGF
Case Corsair iCUE 4000X
Such attractive power usage, wonder what the performance will look like.
6,403 (1.55/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
wimpy, gimpy, and dimpy, just like all of nGreediya's cards of the past 10 yrs or so.....in other words: 2-5% increases, at MOST...
As for the connectors, as long as they don't melt, then so much the better :)
23,210 (6.11/day)
2,801 (6.34/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
Literally the only card so far with THAT bad of an uplift gen on gen for the same tier of model is the 5080 (even then it’s closer to 10-ish% averaged out at 4K). So I wouldn’t start ringing that particular alarm just yet. And 10 years? It’s 2025. 10 years ago was sandwiched between Maxwell and Pascal releases, which were a lot of things, but wimpy with low increases? Absolutely not.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Personally I see no issue of them having only 8GB considering they're practically 1080p cards. At least the difference between 4060 Ti 8GB vs 16GB was practically marginal. And when thinking of the difference between 4080S and 5080, I doubt that 5060 series are much faster than the 4060 series.
7,511 (4.98/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
Wow, I think this is a new low as far as source reliability goes. We've begun to get hardware news off TikTok.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
Honestly, that's even worse source as tabloids in general.
777 (3.98/day)
The Nvidia 5060 will serve as a worthwhile replacement for dead older graphic cards.
The title says * could use *. So everything is speculation and no facts
bug
14,074 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
About that recommended PSU, has anyone noticed how much a dive power draw takes once you enable Vsync and limit rendering to 60fps?
634 (0.39/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Obviously, and the dive becomes deeper for the most powerful GPUs.
Ruru
S.T.A.R.S.
13,325 (3.00/day)
Jyväskylä, Finland
Those PSU recommendations are always practically for the F-tier worst ones.
Add undervolting to those as well. ;)
9,730 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
People can say what they want 8GB is paltry for Gaming at anything over 1080P. I look forward to the Indiana Jones raw numbers for these cards. Or everyone favourite to bash Spiderman 2.
3,425 (2.51/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
very low power and with few generational uptake, this doesn't look good unless they have a metric ton of cores extra in comparison to the 4060 cards.
bug
14,074 (3.96/day)
Not necessarily for the worst PSUs, but they do have to assume you'll be running a number of peripherals, maybe more than one SSD and sometimes a few add-in cards.
3,425 (2.51/day)
Mouse G502
to go from 200 to 650W you have to be running a small army of hard drives
bug
14,074 (3.96/day)
You know there's someone out there running exactly that.
Joking aside, that 650W is spread across 3 rails. That makes these "recommended PSU wattage", pretty meaningless. You can be well below the rated number, but if you you load one rail excessively, your PSU will still run out of juice without going anywhere near the max.
freeagent
9,697 (4.14/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
What are you running?
I only see you posting in the news section and never anywhere else :confused:
Should you even be posting about current hardware :laugh:
2,253 (0.78/day)
Tanagra
System Name El-budgetero
Processor Ryzen 5600X
Motherboard MSI Pro B550M-VC WIFI
Memory PNY 16GB 3600MHz
Video Card(s) AsRock 6700 XT 12GB
Storage WD NVME 1GB
Display(s) ASUS Pro Art 27"
Case Antec P7 Neo
I’m playing Forbidden West at 1080p and it will pull 9-10GB on my 6700xt. I’m sure I could run it okay on 8GB (I ran it on 6GB on lower settings), but it obviously will make use of more.
14,253 (6.42/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
The best news in the whole 50-series so far.
1,130 (0.75/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case DAOTECH X9
Power Supply SF450
Amazing. RT 5030 /50 aka 5060/Ti should be powered by the slot. Not requiring any
