NVIDIA GeForce RTX 5060 and RTX 5060 Ti Could Use Standard 8-Pin PCI Power Connectors
14,900 (6.63/day)
Midlands, UK
Cooling be quiet! Dark Rock 4
Case Kolink Citadel Mesh
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Amazing. RT 5030 /50 aka 5060/Ti should be powered by the slot. Not requiring any
Sure, but if 4060 on TSMC N4 did 115 W, then the 5060 on the same TSMC N4 has to eat more in order to be faster. Unless there's architectural improvements, of which there are plenty of, right? Right? :p
1,232 (0.81/day)
RT cores are wasted on this card but since it's getting mandatory. Only good with upscaling some cases even multi frames, I use FSR3
My 2080 Ti /w 4352 Cuda is essentially the same thing 4X the die size. and I run it at 200Watts so 5060 should be 50 Watts.
But now with GDDR7 it's closer to a 4070 in performance.
3,668 (2.63/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
why not 10W?
power doesn't scale like that
bug
14,183 (3.96/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
23,466 (6.13/day)
bug
14,183 (3.96/day)
Its pretty easy to see that the 4060ti 16GB has no use for all that VRAM because the bandwidth is entry level and identical to the already bandwidth limited 8GB card. We'll see what GDDR7 does for the new crop of x60 E waste.
Also note games are all tested at max settings (necessary for a fair comparison), but that's not how you run the more demanding games of a x60-class GPU.
But yes, let's wait to see if GDDR7 can put that 128bit bus to better use. Won't be long now...
226 (1.93/day)
System Name le fish au chocolat
Processor AMD Ryzen 7 5950X
Motherboard ASRock B550 Phantom Gaming 4
Cooling Peerless Assassin 120 SE
Memory 2x 16GB (32 GB) G.Skill RipJaws V DDR4-3600 DIMM CL16-19-19-39
Video Card(s) NVIDIA GeForce RTX 3080, 10 GB GDDR6X (ASUS TUF)
Storage 2 x 1 TB NVME & 2 x 4 TB SATA SSD in Raid 0
Display(s) MSI Optix MAG274QRF-QD
Power Supply 750 Watt EVGA SuperNOVA G5
128bit bus seems fine (the 4060ti 16gb version had no problems, when it was on pcie 3 or higher) but the 3gb vram chips can't come early enough, 12 gb would be really nice.
793 (0.23/day)
Earth's Troposphere
Mouse various/various/various
VR HMD -
So, the 5040 and the 5050LE are taking shape, vram wise.
14,900 (6.63/day)
Midlands, UK
If they do a 5030 with 8 GB VRAM, no power connector and half-height (true SFF) version, I'll upgrade my HTPC with it. Maybe. :D
bug
14,183 (3.96/day)
Afaik, Blackwell is a beast when it comes to encoding/decoding, so from that pov it would be a great pick for a HTPC. Though it remains to be seen whether the video engine in 5090 will carry over across the product stack or it will see some downsizing in the lower end parts.
23,466 (6.13/day)
14,900 (6.63/day)
Midlands, UK
When you've evidently hit the bottom, and then discover you can go even further down :D
Bottom? What happened with decent low-end cards like the 1030 GDDR5 or 1050 Ti? I miss them so much. :(
bug
14,183 (3.96/day)
They don't make much sense anymore, IGPs have caught up with them. I don't miss them much, but they came with the advantage of VRAM, so they wouldn't eat into the system RAM and be dependent on how fast that is.
14,900 (6.63/day)
Midlands, UK
Not to mention, you need a full system upgrade to have a modern iGPU.
  • Like
Reactions: bug
3,887 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Yeah Nvidia quit that part of the market.
I still feel my GT 1030 was a great purchase, wont ever sell it. Luckily iGPU is more common on AMD side now though, so it does reduce the need for these dGPU parts. Ironically now out of support for latest drivers though.
14,900 (6.63/day)
Midlands, UK
Same with mine. And my passively cooled 1050 Ti (Palit KalmX).
6,481 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
VR HMD Whahdatiz ???
Benchmark Scores PDQ
What are you running?
Well, my personal rig has an integrated Iris Xe GPU, but that's only for office/web/photo/video tasks, which it handles extremely well & is all I need for those things, thank you !
But back when I used ATX rigs, I had a top of the line 2xxx & 3xxx cards, so I understand GPU performance for what it is.
However, my son's gamin rig runs a Radeon RX 7800 XT, which will be replaced with a 9070 XT when they come out....
I only see you posting in the news section and never anywhere else :confused:
Should you even be posting about current hardware :laugh:
Sorry, but I did not realize that members were required to post in any particular or multiple sections, be it about current or legacy hardware or otherwise....and I have posted in other sections from time to time, occasionally offering advice or suggestions on various topics that are discussed there too...
BUT, if it makes any difference, I will now re-read the membership rules & requirements just to make sure that I am in full compliance with them :D
And just to be clear, my "gimpy/wimpy" comments were about the "massive" performance increases that nGreediya always promises but only delivers as little as possible, which has happened with every new generation of their GPU's since way back....
1,232 (0.81/day)
why not 10W?
5060Ti is 1/4 of 5090 in every possible way except the Ti had to give up 25% Cuda for common stuff. 5090 works with the 450 cable. 5060 should work with no cable at all. The way it works is double the clock speed, double the power. 2080 Ti 300 W same die size as 5090 600 W
1,241 (0.73/day)
System Name Gamey #1 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Ventus 3060 / Challenger B580
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
You'll be waiting at least 3 years for the 8GB slot-powered 5050.
The slot-powered Ampere 3050 6GB was released just a year ago so we're a year away from the Ada 4050 6GB (matching the laptop SKU). ~2 years after that we see 70W Blackwell. I expect 70W Ada to be roughly similar to 70W Blackwell so that 4050 will be a good performer vs. Ampere, likely about +40%. But with only 6GB. Maybe Blackwell will also get 96-bit bus but with 3GB chips for 9GB buffer, that would be nice.
2,193 (0.50/day)
Deez Nutz, bozo!
Nothing has changed since the RTX40 Series, eh? Gonna just get the 4070 Super at this point (at a discount) while skipping this gen of garbage cards.
