- Jan 29, 2021
- 2,086 (1.28/day)
- Alaska USA
Natural progression of the video card. 3090 was hot! 4090 hotter and 5090 is hottest(so far).
System Name | Deneb |
Motherboard | Asus ProArt X670E-Creator WiFi |
Cooling | CPU: Noctua D15. Case additional : ML140 Pro blue PWM (400-2000) x1, ML140 Pro RGB PWM (400-1200) x2 |
Memory | G.Skill Flare X5 DDR5 6000Mbps EXPO 2x16Go |
Video Card(s) | Geforce RTX 4070 Asus Dual 12Go |
Storage | SSD Solidigm (SK Hynix) P44 Pro 2To (Gen4). HDD WD80EAZZ (8To, CMR) x2 in AMD RAID1 |
Display(s) | Asus VG27AQ 27" 1440p 165Hz ELMB Sync, Freesync/Gsync compatible |
Case | Fractal Design R6 Tempered Glass Black |
Audio Device(s) | Motherboard soundcard. Logitech Z623 2.1 THX speakers. |
Power Supply | Corsair RMx 2018 850W |
Mouse | Logitech G502 |
Keyboard | Filco Majestouch Convertible 2 (USB/BT) TKL Cherry blue |
Software | Windows 11 Pro |
Benchmark Scores | Cinebench R23 18440, Geekbench 6 CPU 2671/14823, GPU 181588, 3DMark Speedway 4723, Steel Nomad 4019 |
Well there is a good amount of layers on the PCB for that but I agree PCI Gen5 doesn't make it easy. Basically 90% of the IOs have a very high bandwidth, which is actually not so frequent.PCIe 5.0 makes things even more complicated. Given the memory chip layout, some lanes probably run under the memory chips and/or other lanes. This is quite unfavourable because these wires require a specific geometry (distance to ground, to other lanes etc).
Sure, what are you willing to bet? I am confident in my assessment. A 5080 that can’t catch the 4090 just doesn’t make sense stack-wise. It will match it or be faster.
Hmm I'm not him but apparently the bet didn't take into account DLSS4 which is a bit ridiculous. Software and DLSS is definitely a huge part of today's GPUs, like it or not. I'm a hardware engineer but you can't count on hardware only to push the Moore's Law further.You lost the bet? Lol.
Who cares for RT ? Most people who buy a xx90 and actually play games with it ??I'd accept the bet. Math doesn't lie. 4080S had 10240 shading units vs 3090TI's 10752, with 3090TI being on shitty samsung node. 5080 has 10752 shading units vs 4090's 16384 on similar nodes. No way can DDR7 speed close that gap in rasterization. Sure it will have better RT (who really cares?) and maybe support new frame gen tech in DLSS (again who really cares), but in raw performance 4090 will be the 2nd best, only behind 5090.
Who cares about DLSS ? Probably less people but again, using the device to its fullest is using it with DLSS, and no it's not a mess anymore. And most games in 4K are slower than 200 fps with DLSS on a 4090 when everything else is maxed. And someone who buys a xx90 is likely to have a 4K display with 240Hz or above. I don't think anything above 240Hz is useful but it's still a decent improvement to have more than 144fps with a 240Hz screen, which will require DLSS on a decent amount of games. And Frame Gen x4 in performance with DLSS4 is actually a better quality than FG X2 in quality with DLSS3. So with DLSS on the 5080 is above the 4090.
So yes, that guy lost his bet, they were talking about raw rasterization, but the assessment that we shouldn't care about RT and DLSS absolutely ridiculous, and in a more realistic comparison, the 5080 is indeed above the 4090.
System Name | The Workhorse |
Processor | AMD Ryzen R9 5900X |
Motherboard | Gigabyte Aorus B550 Pro |
Cooling | CPU - Noctua NH-D15S Case - 3 Noctua NF-A14 PWM at the bottom, 2 Fractal Design 180mm at the front |
Memory | GSkill Trident Z 3200CL14 |
Video Card(s) | NVidia GTX 1070 MSI QuickSilver |
Storage | Adata SX8200Pro 1 TB |
Display(s) | LG 32GK850G |
Case | Fractal Design Torrent (Solid) |
Audio Device(s) | Sennheiser HD598, FiiO E-10K DAC/AMP, Samson Meteorite USB Microphone |
Power Supply | Corsair RMx850 (2018) |
Mouse | Zaopin Z1 Pro on a X-Raypad Heavy Bee Redtail |
Keyboard | Cooler Master QuickFire Rapid TKL (Cherry MX Black) |
Software | Windows 11 Pro (24H2) |
The bet was never formalized, but yeah, I did. No shame in admitting it. And I stand by what I said - a 5080 slower than the 4090 didn’t make sense and doesn’t now - no wonder we mostly look at the 5000 series as a meme - outside of the 5090 the generational uplift is questionable at best.You lost the bet? Lol.
Nah, if we do take MFG into account then sure, I would be technically correct, but that wasn’t a part of the discussion and I wouldn’t be able to force it even if I tried since most people seem to count “native only, raster only,Hmm I'm not him but apparently the bet didn't take into account DLSS4 which is a bit ridiculous. Software and DLSS is definitely a huge part of today's GPUs, like it or not. I'm a hardware engineer but you can't count on hardware only to push the Moore's Law further.
System Name | His & Hers |
Processor | R7 5800X/ R9 7950X3D Stock |
Motherboard | X670E Aorus Pro X/ROG Crosshair VIII Hero |
Cooling | Corsair h150 elite/ Corsair h115i Platinum |
Memory | Trident Z5 Neo 6000/ 32 GB 3200 CL14 @3800 CL16 Team T Force Nighthawk |
Video Card(s) | Evga FTW 3 Ultra 3080ti/ Gigabyte Gaming OC 4090 |
Storage | lots of SSD. |
Display(s) | A whole bunch OLED, VA, IPS..... |
Case | 011 Dynamic XL/ Phanteks Evolv X |
Audio Device(s) | Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech G560/Samsung Q990B |
Power Supply | Seasonic Ultra Prime Titanium 1000w/850w |
Mouse | Logitech G502 Lightspeed/ Logitech G Pro Hero. |
Keyboard | Logitech - G915 LIGHTSPEED / Logitech G Pro |
Nah, if we do take MFG into account then sure, I would be technically correct, but that wasn’t a part of the discussion and I wouldn’t be able to force it even if I tried since most people seem to count “native only, raster only,Final Destination” type of performance.
That's what I said in my next comment.Nah, if we do take MFG into account then sure, I would be technically correct, but that wasn’t a part of the discussion and I wouldn’t be able to force it even if I tried since most people seem to count “native only, raster only,Final Destination” type of performance.
Not counting side technologies as a plus is ridiculous to say the least. You can talk about raw performance and compare cards with each other using that only, that's an intersting comparison to make. But if you want to tell this card is better than this one, you have to take into account everything. I don't play games where a few ms of latency make any difference so it doesn't matter to me and I won't talk about that. But I don't care about image differences that I can't see when playing even if I try.Interpolation is not performance it's a screen smoothing effect at best with two major downsides. If Nvidia can create a similar technology where the latency goes down at each step and there is 0 additional artifacts vs using DLSS SR by itself sure we can call it performance.
The only people who consider it performance are Nvidia and people who have drank too much green Kool-aid.
Make a blind test in normal playing conditions, make several runs, with or without MFG (faster fps could be compensated by using either a slower card or by downclocking) and try to guess which one is played with MFG and if you can't see any difference, then call it a performance uplift.
