NVIDIA GeForce RTX 5090 Runs on 3x8-Pin PCI Power Adapter, RTX 5080 Not Booting on 2x8-Pin Configuration
14,094 (6.37/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
So how much power does a 3090 need? Cause there are 2 and 3 pin models. Same with the 3080 and probably the 3070ti. There is no such thing as need, hardware doesn't have needs. They take as much power as the user decides to give them.
So can I give my 6750 XT just 150 Watts through a single 6-pin coming from a noname 300 W PSU and the PCI-e slot? :p
23,131 (6.10/day)
What 2/3 are you talking about?
This is a 5080 with 360W power limit and 2x8pin can supply 300W + the 75W from PCI-E. Total of 375W.
Compared to a 5090 that requires 575W and only getting 450W + 75W (525W) the 5080 should be "easier" to run with 2x8pin.
Clearly this is a limitation somewhere that could/should(?) have been avoided. Maybe it would require a more complex PCB/Power delivery subsystem that most likely the 5090 has.
In all honesty when you buy a 1000~1500+ GPU you dont try to cheap on power...
The 12VHPWR has a build-in sensing system for 450W and 600W options.
Well maybe the card just doesn't look at slot power and 'wants' all of it from the other end? Is that possible? We've seen in the past its not just 'oh this gives me juice I'll just take it' as we've also seen cards pull too much from the slot.
I can see why, 450w+ is starting to get crazy. I'm getting comfier with the 300w range though :twitch:
2w I'd say seems to low, maybe 10-40w seems more reasonable if it really wants all it's power through the plug in cables.
300W was always my hard limit and it hasn't changed. 250W being optimal to me in a regular system. If you go bigger you need to worry a lot more about case cooling, case choice, but also PSU sizing, etc. Its a straight up price increase for almost the entire system. And those systems also tend to be louder.
4,280 (2.52/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
If you limit it to 150w sure, why not. I've used my 4090 on a 650w psu
14,094 (6.37/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
4,280 (2.52/day)
Heh, I'd like to see someone try.
650 W is enough for a 4090 as long as you don't have an unlocked i9 CPU and ten HDDs, pumps, fans and such.
If 650 is enough then what are we even talking about?
14,094 (6.37/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
This:
Obviously hardware has needs. You need a certain voltage to maintain certain clock speeds, which means power is being used. There's also no power saving limiting things when you press the power button.
The only hardware that doesn't have needs is the one sitting on your shelf.
4,280 (2.52/day)
If you can run the until recently highest end gpu that costs over 2k$ with a 650w gpu then it's a non issue.
714 (3.80/day)
I don't know what you mean by argument? does undervolting not work when using software?
I think you misunderstood the basics.
in the direct current world is wattage equal voltage multiplied with current or current multiplied with current multiplied with resistance or voltage multiplied with voltage divided by resistance. Basics.
(Blame this forum for not proper software to make mathematical basic formulas from 3rd school year here.)
Auswolf stated - the card will not boot without all proper connectors during bootup.
You need to bootup the hardware first.
than you can make software hacks and tweaks
when the hardware does not bootup with less connectors, you can not undervolt
i hope this is clear now.
Remember:
Like in OSI layered modell. (that is very important you may read it and learn it please)
Physical layer = hardware first - missing connector - nope
much later comes software
much later comes the application
edit: don*t be angry. These are basics in electronics or physics or mathematics. The other stuff are basics from my education. nothing new.
edit: That is not an argument get another power supply unit. When the card takes less Watts an older power supply could be more the fit. The real reason are those power spikes which are insane. Which most likely previous cards did not really generate. See igorslab. Sometimes he is right, sometimes there is room for improvement. Why should someone needs a new power supply unit when the older card had similar wattage as the newer card? the only reason are those power spikes.
556 (1.49/day)
Processor Ryzen AI
Motherboard MSI
Cooling Cool
Memory Fast
Video Card(s) Matrox Ultra high quality | Radeon
Storage Chinese
Display(s) 4K
Case Transparent left side window
Audio Device(s) Yes
Power Supply Chinese
Mouse Chinese
Keyboard Chinese
VR HMD No
Software Android | Yandex
Benchmark Scores Yes
This is nonsense, the cards must boot with close to idle power settings, not at maximum peak clocks, etc...
714 (3.80/day)
I wouldn't expect a card with 2x8-pin to work with only one connected for example, even if a power target was set needing less than 225w.
In my point of view it hsould be possible.
The connector can distinguish between 4 different wattage modes for the 600 Watt connector. The card should bootup.
Check post #22 link - the card should even bootup with 100 Watts - initial permitted power at system power up. The card should run fine with 150 Watts. Any questions?
Assuming htat spec is correct in #22 - nvidia has a design error with that particular graphic card mainboard - or software error with that particular graphic card mainboard
Sense0Sense1Initial Permitted Power at System Power UpMaximum Sustain Power after Software Configuration
GndGnd375 W600 W
OpenGnd225 W450 W
GndOpen150 W300 W
OpenOpen100 W150 W
When you reply, please provide datasheet for all components involved, especially for the controller ics, provide full schematics for a recent powersupply unit, atx 3.1 spec and full schematics for those cables and adapters.
Naturally, cards with external power connectors don't use the PCI-e slot to its full 75 W specification, but to say they use 2 W is a bit daft.
I doubt the Wattage is limited over the PEG slot. I forgot which card it was, i think one card even took over 125 Watts over the PEG slot.
Anyway. Nvidia does not contribute to open source software - see recent gamers nexus video.
I invite AMD, Nvidia, INTEL, power supply companies and the others: Please publish the full specifications, the full schematics, the full datasheets, the full register and programming sheets for all components being used on pc parts.
Well it's easy to sell garbage, when you do not publish the full specifications and no one can check if the firmware, software, hardware is working according to the specifications. Check e.g. the linux kernel (it is only the kernel!) for all the workaround for the hardware and firmware bugs. A generic statement.
I really want to see in less than 2 minutes the full nvidia graphic card connector specs on the nvidia homepage in english. That includes datasheet, application notes and other common documents needed to design a device.
wolf
Better Than Native
8,454 (1.30/day)
System Name MightyX
Processor Ryzen 9800X3D
Motherboard Gigabyte B650I AX
Cooling Scythe Fuma 2
Memory 32GB DDR5 6000 CL30
Video Card(s) Asus TUF RTX3080 Deshrouded
Storage WD Black SN850X 2TB
Display(s) LG 42C2 4K OLED
Case Coolermaster NR200P
VR HMD Meta Quest 3
I'm thinking it's you that's misunderstood the basics. I'm not providing you anything. It's reasonable to expect hardware to be connected as the manufacturer intended. I have zero intention of proving or justifying anything to you, as if you're some barrier that if I don't what I've said is invalid, the hubris.
714 (3.80/day)
No. As a rule Nvidia only pulls about 2W from the PCIe slot.
I wrote on igorslab for ages that I want to see proper measurements.
I only know gamers nexus measures with internal checked and before external calibrated measurement device the peg slot and all the cables.
I doubt 12 Watts on the peg slot are 2 watts. I doubt the windows software reads out these values correctly.
source:
NVIDIA GeForce RTX 5090 Founders Edition Review & Benchmarks: Gaming, Thermals, & Power​
That measurement is plausible.
I also wrote on those cpu tests in teh past. I want to see the wattage for every cpu pin - not the hole mainboard nonsense. Like igorslab does for example in the past. Igor for example can not differentiate between cpu only consumption and the correct cpu + mainboard + mainboard peripherals + ram consumption + something else which may be on the mainboard I forgot as of now.
