- Jun 10, 2014
- 3,131 (0.77/day)
Processor | AMD Ryzen 9 5900X ||| Intel Core i7-3930K |
Motherboard | ASUS ProArt B550-CREATOR ||| Asus P9X79 WS |
Cooling | Noctua NH-U14S ||| Be Quiet Pure Rock |
Memory | Crucial 2 x 16 GB 3200 MHz ||| Corsair 8 x 8 GB 1333 MHz |
Video Card(s) | MSI GTX 1060 3GB ||| MSI GTX 680 4GB |
Storage | Samsung 970 PRO 512 GB + 1 TB ||| Intel 545s 512 GB + 256 GB |
Display(s) | Asus ROG Swift PG278QR 27" ||| Eizo EV2416W 24" |
Case | Fractal Design Define 7 XL x 2 |
Audio Device(s) | Cambridge Audio DacMagic Plus |
Power Supply | Seasonic Focus PX-850 x 2 |
Mouse | Razer Abyssus |
Keyboard | CM Storm QuickFire XT |
Software | Ubuntu |
It's about time that they use a decent stock cooler. Both Pascal and Vega cards boost way into throttle territory, and this card will probably (unfortunately) push this even further.
Some notable quotes:
- Similar to Pascal GP100, the GV100 SM incorporates 64 FP32 cores and 32 FP64 cores per SM. However, the GV100 SM uses a new partitioning method to improve SM utilization and overall performance.
- Integration within the shared memory block ensures the Volta GV100 L1 cache has much lower latency and higher bandwidth than the L1 caches in past NVIDIA GPUs.
- Unlike Pascal GPUs, which could not execute FP32 and INT32 instructions simultaneously, the Volta GV100 SM includes separate FP32 and INT32 cores, allowing simultaneous execution of FP32 and INT32 operations at full throughput, while also increasing instruction issue throughput.
Learn the basics before you start complaining about lack of innovation.
"Volta" is still more energy efficient than Pascal, and miles ahead of the competition.
I guess you mean higher TDP rather than lower efficiency? GV104 does have up to 40% more CUDA cores, some TDP increase is to be expected, but "Volta" is still more energy efficient.The GeForce GTX 1080 set high standards for efficiency. Launched as a high-end product that was faster than any other client-segment graphics card at the time, the GTX 1080 made do with just a single 8-pin PCIe power connector, and had a TDP of just 180W. The reference-design PCB, accordingly, has a rather simple VRM setup. The alleged GTX 1080-successor, called either GTX 1180 or GTX 2080 depending on who you ask, could deviate from its ideology of extreme efficiency. There were telltale signs of this departure on the first bare PCB shots.
Then I would recommend you get educated on the Volta architecture.If this is true, and it's running hot, then it looks like nVidia is struggling to innovate, and is instead relying on overclocking the chip to get performance...
nVidia has had a long time with no pressure on them to make this "new" GPU, so this is rather telling, if true.
Definitely fake. This is just the usual rambling from AdoredTV, the Youtuber behind "AMD's master plan", and other ridiculous claims.This is allegedly leaked info by an nVidia employee:
<snip>
It should come as no surprise that an architecture launched towards the end of a node lifecycle should be larger and push the node further. The same will also happen with 7nm; first relatively modest GPUs, then gradually pushing the node.Exactly. Probably 12nm which means Turing chips are big, hot, and hungry.
