Ruru
S.T.A.R.S.
- Dec 16, 2012
- 13,165 (2.98/day)
- Jyväskylä, Finland
System Name | 4K-gaming / console |
Processor | 5800X @ PBO +200 / i5-8600K @ 4.6GHz |
Motherboard | ROG Crosshair VII Hero / ROG Strix Z370-F |
Cooling | Alphacool Eisbaer 360 / Alphacool Eisbaer 240 |
Memory | 32GB DDR4-3466 / 16GB DDR4-3600 |
Video Card(s) | Asus RTX 3080 TUF OC / Powercolor RX 6700 XT |
Storage | 3.5TB of SSDs / several small SSDs |
Display(s) | 4K120 IPS + 4K60 IPS / 1080p60 HDTV |
Case | Corsair 4000D AF White / DeepCool CC560 WH |
Audio Device(s) | Sony WH-CN720N / TV speakers |
Power Supply | EVGA G2 750W / Fractal ION Gold 550W |
Mouse | Logitech MX518 / Logitech G400s |
Keyboard | Roccat Vulcan 121 AIMO / NOS C450 Mini Pro |
VR HMD | Oculus Rift CV1 |
Software | Windows 11 Pro / Windows 11 Pro |
Benchmark Scores | They run Crysis |
Didn't even install the Relive when I installed drivers. I just find that as an unneccessary bloatware.It's a bit hit and miss. For AMD you should try AMD Relive, if that ain't give you acceptable quality non other software can(If your audio goes out of sync, enable HPET on bios. It had bug for OC Ryzens an timer did havoc on audio sync, I don't really know if it fixed).
Problem with streaming on gpus is h.264 that every streaming service uses, it can be done with gpu but the quality is crappy on lower bitrate, thus cpu encoding is usually way to go. H.265 would work better, but no service provider want's to pay that license fee for MPEG LA and I don't really blame them.
Software encoding with "faster" preset, 720p output @ 3000kbit/s and watchers said that works flawlessly.
