- Sep 3, 2019
- 3,953 (1.93/day)
- Thessaloniki, Greece
System Name | PC on since March 2025, upgraded from 5900X |
Processor | Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -30, +100MHz (up to 5.65GHz) |
Motherboard | Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A |
Cooling | Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet |
Memory | 2x32GB G.Skill Trident Z5 RGB (March2025) 6000MT/s 1.35V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D |
Video Card(s) | Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v25.3.1 |
Storage | NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20) |
Display(s) | Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR400/1000, VRR on |
Case | Thermaltake Core P8 TG Gaming Full Tower |
Audio Device(s) | Astro A50 headset |
Power Supply | Corsair HX750i, ATX v2.4, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch) |
Mouse | Logitech MX Master (Gen1) |
Keyboard | Logitech G15 (Gen2) w/ LCDSirReal applet |
Software | Windows 11 Home 64bit (v24H2, OSBuild 26100.3476), Install March 2025 |
Can't argue with this.In this situation, I don't think lots of airflow is going to solve much. Imagine having a radiator in a car that is just large enough for cool weather conditions, then you try upsizing only the fan in order to drive it in the summer. That extra airflow will help, but it can only do so much if the cooling solution gets saturated due to insufficient mass and surface area. It feels like NVIDIA designed the FE to counter all the flack it got for that rumored 4-slot cooler that never even made it out. The 5090 FE is physically smaller than the 4090 FE, but consumes over 100W more energy in loads. Yes, the cooler is an innovative design, and I actually like the concept. However, it feels like it's insufficient to put it on this GPU with its increased TDP. At best, the design is barely sufficient. 3-slot+ AIB 5090s perform 20C better at the same noise level to bare that out. I think had they made this same cooler a 3-slotter, it would have given them the extra mass they needed to properly cool this thing. 2 slots for a 600W card? That's just insane unless it's a waterblock.
Nobody would complain if the 5090FE was the same size as the 4090FE + the innovative PCB/Cooler design for the extra 125W.
I mean why would they? When you're getting a 450~575W GPU card you expect its going to be big for cooling unless its a watered one with the extra volume on the radiator.
