NVIDIA Readying GeForce RTX 3090 SUPER, A Fully Unlocked GA102 with 400W Power?
884 (0.66/day)
I'm prepared to call the Ampere stack finished, myself.
heh, all of us are, but I'm sure NVidia still has a few spare horse carcasses to kick around in the Ampere ring, much to the profit & entertainment of the Huang Dynasty. Afterall, there are plenty of numbers/letters/names that can follow 30xx, although I can't say the same for the fab materials. :laugh:
7,022 (4.81/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Keyboard IBM Model M type 1391405 (distribución española)
I mean, short of calling this a "Titan A" and leaving NVLink + full hashrate present or something of the sort, I don't think there's any space left in the GeForce stack or any logical business reasoning behind a 3090 Super. There is a limit to what the market is prepared to spend, even in these troubled times, even the richest guys out there don't exactly fancy throwing money in a fire pit, even at the height of scalped pricing, the 3090 never really exceeded the Titan V's MSRP, while still being a much faster and advanced processor than that not-so-old Volta behemoth.
Besides, TPU benchmark data shows the 3080 Ti performs 99.5% of the 3090 already, and having one I can tell you that unless you have a model that can draw well above 600W, you can't quantify any meaningful performance increase beyond closing the gap between the shipped and the rated memory speed with one.
The honest truth that may make many NVIDIA fans sad is that this eventual card would never achieve what it would set out to do: make Ampere retain the crown in any titles where the 6900 XT beats the 3090, in those, AMD's performance advantage overcomes anything that's left in any GA102 type at any clock speed, feasible for 24/7 usage or not.
10 (0.00/day)
Right by the Bay
System Name DeskStar Rev 3.0
Processor AMD ThreadRipper 3960X
Motherboard Gigabyte Aorus Xtreme TRX40
Cooling Cutsom Liquid
Memory 128GB G Skill Trident Z Neo 16-19-19-36-1T 3600MHZ
Video Card(s) EVGA RTX 3090 FTW3 Ultra (Optimus waterblock)
Storage Quad M.2 1TB Raid 0 AIC pci-e 4.0
Display(s) Viotek 49" 5120x1440 120hz, BenQ 120hz 1080p
Case Case Labs MAGNUM STH-10 with Pedestal
Audio Device(s) On Board Rig 800XL and Klipsch 2.1
Power Supply X2 Evga SuperNova 1500 watt with Add2PSU adapter
Mouse Razor Death Adder Elite
Keyboard Razor Huntsman
Software All kinds
Benchmark Scores Superposition 4k 15762 Valley 4k 96.3fps 4030 score Heaven 4k 94.8fps 2389 score
Already have a "SUPER" because I've clocked mine way higher. But the cuda cores aren't even worth it either it's not that much more.
And still need some exotic cooling for sure pushing that realm of TDP. I've gotta waterblock from Optimus. Couldn't imagine without it!!
2,881 (1.19/day)
Guaranteed to hit $4K in Australia. Really can't believe the point of this release. How many wafers do they get that are perfect and they want to waste them on an ultra niche product. Rather why don't they start from scratch and relaunch Ampere with a fresh line-up:
Note DDR6X is now cheaper than DDR6
3060 6GB/12GB $269/$319
3060 TI 8GB DDR6X 17GB/s 256bit $379
3070 Super 8GB DDR6X 17GB/s 256 bit $459
3070 Ti GA102 10GB $599 ~ 7000 cuda cores (replaces 3080 bit lower performance)
3080 TI 12GB $799
3090 24GB $1299
3090 Super 24GB $1599
884 (0.66/day)
I don't see any "Titan" equivalent coming out for the 3000 series. If a true Titan equivalent were ever to crop up later, I would expect it to have more than 24Gb VRAM and at least 2k-3k more CUDA cores & takes up 3 or more PCI-e slots. It would be nice, but the power draw would be insane.
Anyway, I think they need to start thinking outside of the box. These cards just keep on getting bigger and bigger and requiring more and more power. With this noted pattern, in the future we might not be gaming on desktops anymore the way we are now.
3080 TI 12GB $799
3090 24GB $1299
They don't need the in-between "Ti" crap. Just get rid of all Ti's, increase the price of the 3090's by 1.5 times, and lower the price accordingly for all of the cards below the 3090.
1,761 (1.02/day)
It is going to be the dumbest refresh ever. The improvement is going to be very small. I am sure the increase power limit is just so that the card can boost and maintain a higher clock speed to paint a better picture of the pathetic hardware improvement.
3080 TI 12GB $799
3090 24GB $1299
The prices that you mentioned, are unlikely to happen unfortunately. And I am not surprise that GDDR6X is cheaper than GDDR6 now given the fact that that GDDR6X have limited use as compared to GDDR6 which is widely used, which means demand is higher on the latter. However, between GDDR6X and GDDR6, I would gladly go for the GDDR6 since the former is a power hog and really isn't significantly faster than the fastest GDDR6 @ 18Gbps. This is evident when you consider the existing RTX 3070 vs 3070 Ti. I own a RTX 3070 Ti because I can't get a 3070, and even after under clocking the VRAM, I don't see significant lost in performance in games. I do see drops in benchmark scores, but again, I don't really care about benchmark results.
joey121215
4 (0.00/day)
At least 400W? Get ready for more stories of burnt-out RAM chips and PCIe power cords...
Once upon a time people actually cared about not turning their PCs into self-destructing ovens... :shadedshu:
The 3090 already draws over 400w on a regular basis, if you know how to build a PC you're not gonna have those issues. If you are burning out your ram and power cables, you designed a system with poor airflow and were way more concerned about the aesthetic than the performance. Probably also too obsessed with getting one good part that you could flash around as having and bought a cheap power block/ cables that used low grade metals and cables, or went for a lower wattage power supply than you should. You can't just shove an enthusiasts level part into a mid range system.
364 (0.07/day)
System Name Matar Extreme PC.
Processor Intel Core i9-12900KS 5.2GHZ All P-Cores ,4.2GHZ All E-Cores & Ring 4.2GhZ bus speed 100.27
Motherboard NZXT N5 Z690 Wi-Fi 6E
Cooling CoolerMaster ML240L V2 AIO with MX6
Memory 4x16 64GB DDR4 3600MHZ CL15-19-19-36-55 G.SKILL Trident Z NEO
Video Card(s) Nvidia ZOTAC RTX 3080 Ti Trinity + overclocked 100 core 1000 mem. Re-pasted MX6
Storage WD black 1GB Nvme OS + 1TB 970 Nvme Samsung & 4TB WD Blk 256MB cache 7200RPM
Display(s) Lenovo 34" Ultra Wide 3440x1440 144hz 1ms G-Snyc
Case NZXT H510 Black with Cooler Master RGB Fans
Audio Device(s) Internal , EIFER speakers & EasySMX Wireless Gaming Headset
Power Supply Aurora R9 850Watts 80+ Gold, I Modded cables for it.
Mouse Onn RGB Gaming Mouse & Logitech G923 & shifter & E-Break Sim setup.
Keyboard GOFREETECH RGB Gaming Keyboard, & Xbox 1 X Controller & T-Flight Hotas Joystick
VR HMD Oculus Rift S
Software Windows 10 Home 22H2
Benchmark Scores https://www.youtube.com/user/matttttar/videos
Nvidia is like oh there is still a little drop in the honey jar and we cant though that away...
joey121215
4 (0.00/day)
400W, this is out of control. Some of these prebuilt PCs can no longer be shipped to some states because they use too much estimated power per year.
Yet another reason to not go pre-built
14,170 (3.81/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
400W of baking powa, takes twice as long as your basic 800W microwave.
243 (0.17/day)
USA
System Name Desktop PC
Processor AMD Ryzen 5 5500
Motherboard MSI B450I Gaming Plus Max Wi-Fi
Cooling Corsair Hydro X Series Custom Loop
Memory 32 (2x16) GB Corsair Vengeance LPX DDR4 3200 MHz
Video Card(s) NVIDIA GeForce RTX 2060 Super FE
Storage 1 TB Samsung 970 EVO PCIe 3.0 NVMe SSD
Display(s) Vizio 1080p TV Screen (Temporary)
Case Fractal Design Define Nano S
Audio Device(s) Razer Kraken X Headset
Power Supply Corsair RM650x 650W
Mouse Razer DeathAdder V2 Gaming Mouse
Keyboard Razer Cynosa Lite Gaming Keyboard
VR HMD HTC Vive Cosmos
Software Windows 10 Home 64 Bit
Benchmark Scores 3DMark Time Spy: 8706 (Stock)
You're entitled to your opinion, and that's fine. If flagship performance is worth putting up with 400+ watts of power consumption to you, feel free to buy a 3090 Super when it comes out. I won't stop you. To me it's just not worth it, regardless of whether the card is prone to frying itself or not. On top of that, as you pointed out, a great deal of effort must be made to keep the card safely cooled and powered. With Ampere, it's a great deal of effort that wasn't necessary for previous generations of cards.
884 (0.66/day)
You're entitled to your opinion, and that's fine. If flagship performance is worth putting up with 400+ watts of power consumption to you, feel free to buy a 3090 Super when it comes out. I won't stop you. To me it's just not worth it, regardless of whether the card is prone to frying itself or not. On top of that, as you pointed out, a great deal of effort that must be made to keep the card safely cooled and powered. With Ampere, it's a great deal of effort that wasn't necessary for previous generations of cards.
I wouldn't respond. It looks like the new user might be randomly quoting or possibly trolling people, because I have no clue what he's quoting me about since it doesn't seem to jive from a disagreeing or agreeing perspective with the entirety of the post they quoted from me.
1,207 (0.76/day)
People: "Nvidia's release of 3070Ti and 3080Ti is tone-deaf, we need affordable mainstream GPUs"
Nvidia: "Hold my beer"
9,509 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I, for one, am very skeptical about this. First, why would they remove the NVLink capability? It was already only present on the 3090 to begin with, the 3080 didn't have it and the 3080 Ti followed suit.
The 3090 is often the targeted by consumers that want to use it for compute because of the memory size, NVLink is essentially worthless for gaming but relevant for compute. I guess that Nvidia no longer wants people to "cheap out" on 3090s and shell out even more money for a Quadro.
3,413 (0.99/day)
System Name M3401 notebook
Processor 5600H
Motherboard NA
Memory 16GB
Video Card(s) 3050
Storage 500GB SSD
I wanna hear what people whining about 6600XT MSRP have to say about this... :D
102 (0.02/day)
Netherlands
System Name LazyOldMan
Processor 9900KF
Motherboard Asrock z390 Taichi Ultimate
Cooling Corsair custom Watercooled
Memory 64 Gb
Video Card(s) RX 6800 XT
Storage Too much to mention in all 980 TB
Display(s) 2 x Dell 4K @ 60 hz
Case Crap case
Audio Device(s) Realtek + Bayer Dynamics 990 Pro headset
Power Supply 1300 watt
Mouse Corsair cord mouse
Keyboard Corsair red lighter cabled keyboard ages old ;)
Hahaha another paper launch with a few lucky people ever getting any of them or be filthy rich to buy a computer store to get a few
Or become victim of the hundreds of scalpers becoming rich on the people really wanting to pay 1+ million zero's % too much on the new card
671 (0.18/day)
System Name Work in progress
Processor AMD Ryzen 5 3600
Motherboard Asus PRIME B350M-A
Cooling Wraith Stealth Cooler, 4x140mm Noctua NF-A14 FLX 1200RPM Case Fans
Memory Corsair 16GB (2x8GB) CMK16GX4M2A2400C14R DDR4 2400MHz Vengeance LPX DIMM
Video Card(s) GTX 1050 2GB (for now) 3060 12GB on order
Storage Samsung 860 EVO 500GB, Lots of HDD storage
Display(s) 32 inch 4K LG, 55 & 48 inch LG OLED, 40 inch Panasonic LED LCD
Case Cooler Master Silencio S400
Audio Device(s) Sound: LG Monitor Built-in speakers (currently), Mike: Marantz MaZ
Power Supply Corsair CS550M 550W ATX Power Supply, 80+ Gold Certified, Semi-Modular Design
Mouse Logitech M280
Keyboard Logitech Wireless Solar Keyboard K750R (works best in summer)
VR HMD none
Software Microsoft Windows 10 Home 64bit OEM, Captur 1 21
Benchmark Scores Cinebench R20: 3508 (WIP)
Will they accept a house as a payment?
How big? How much land? Where?;)
At least this will be used for gaming as the hashrate/$ ratio is shit!:kookoo:
qubit
Overclocked quantum bit
17,865 (2.87/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
78 (0.01/day)
System Name Blah
Processor Ryzen 7950x
Motherboard Asrock X670E Taichi
Cooling BLACK ICE SR2 480,EKWB Quantum Magnitude AM4,D5 Pump,17 CORSAIR SP120 RGB ELITE
Memory 32Gig Gskill 6000 DDR5
Video Card(s) MSI RTX 4090 LIQUID X 24G
Storage Optane 900P 480GB,2x SX8200 2TB ,SAM 980 PRO 2TB,2xSAM 860 EVO 1TB,SAM 870 EVO 4TB,SAM 860 EVO 2TB
Display(s) Samsung Odyssey Neo G9 57
Case CORSAIR 7000X
Audio Device(s) Realtek ALC4082
Power Supply CORSAIR HX1500I
Mouse Corsair Harpoon
Keyboard Corsair Strafe MkII
VR HMD Oculus
Super.........
884 (0.66/day)
I would like to see that happen. Sure, they'll make money no doubt, but they will also find themselves in a higher tax bracket. If they're not already rich, they're certainly not going to become rich scalping graphics cards. Its probably even more difficult for the majority of the scalpers to buy them in bulk for selling than it is for us to get a single one.
Simplykt0420
1 (0.00/day)
I bet they could make at least 3 3060s or 3070 out of one 3090 waffer... its stupid to make a highend gpu 10 percent better than there already expensive flagship.... they would make more people happy making lower level gpus...
2,508 (0.78/day)
This card alone would max out my PSU's rated wattage better not overclock it.
6,762 (1.39/day)
Case NZXT PHANTOM410-BK
Power Supply Corsair 850W
Mouse Logitech Hero G502 SE
nGreedia milking to the last cent. Sorry, last CUDA core....
Breastfeeding Lactating GIF by Scary Mommy
2,939 (1.15/day)
System Name System V
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Case NZXT Source 210
Power Supply Corsair CX650M
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
joey121215
4 (0.00/day)
Lmao y'all are great pc enthusiasts, bench about enthusiast level cards just because you can't afford them. I can't afford a Lamborghini either, but I don't complain about the price I just appreciate the craftsmanship. If you don't want them to make 3090 supers than y'all really don't want lower grade cards either.
Whatever done with this forum. Got too many games to play on my 3090/5950x
