NVIDIA Releases DLSS 3.7.0 With Quality E Preset for Image Quality Improvements
13,898 (6.29/day)
Midlands, UK
Cooling Yes
Storage A lot
Display(s) Monitors and TVs
Case The smaller the better
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Tbh even if I had a 4k monitor and say a 4090 I would still use DLSS or DLAA regardless, at that resolution I would literally need a magnifying glass to notice anything different so why not use it then. 'even if only to fix the said flickers'
Upscaling gets better at higher resolutions. I can hardly notice it on my 4K TV (if at all), while I can definitely notice it on my 1440 UW monitor, and it was hot garbage back on my 1080p one.
2,110 (1.03/day)
Hungary
Mouse Canyon Puncher GM-20
Yeah I know, thats why I've mentioned that at 4K I would simply use it casue I could never tell the diff so I would rather take the 'free' performance + less power draw/fix for TAA issues,etc.
Tbh after ~30+ hours played with Forbidden West and DLSS on Quality 'I've updated to the latest DLSS dll' I can maybe point out a few things that are worse with DLSS at my resolution but the funny thing is.
Those specific things look meh/bad even at native so basically crap in crap out. 'Aloy's holo/energy shield glider and the dust tornadoes and some water reflections are pixelated even w/o ANY upscaling + maxed settings'
13,898 (6.29/day)
Midlands, UK
Cooling Yes
Storage A lot
Mouse Wireless
Keyboard Mechanic
VR HMD Not yet
Agreed. I think the purpose of upscaling is to lower the entry requirements to 4K, and to extend the life of a relatively weaker graphics card, and for that, it's great. But that's it. I wouldn't want to use it on my main PC (unless it's a temporary measure).
2,110 (1.03/day)
Hungary
Well I don't really plan on upgrading till the 5060/Ti drops so ye DLSS helps me a ton in new AAA games already, like I've mentioned before I'm not sensitive to it so its a win-win situation for me.:)
Personally I prefer to play at higher settings with DLSS Quality than lowering my settings and play at native which often looks worse to me anyway.
Ever since I've bought my 3060 Ti in 2022 september I've pretty much used DLSS Quality in every single game that I've played and it had a support for it, nowadays I instantly enable it after starting up a new game and then I make some personal comparisons between native/check the upscaling implementation quality and then decide how I'm gonna play the game. I did ran into some questionable implementations or with dated DLSS versions shipped with the game but then I just switched the dll file and that worked out most of the time. 'so basically if a game had DLLS then TAA never won me over'
At the end of the day its still optional, like you said you wouldn't want it and thats perfectly fine but for me at this point its almost a must have and I prefer it this way.:) 'I only wish that AMD would step up their FSR game cause upscaling is a selling point to me as a ~mid range user'
2,036 (0.77/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
DemonicRyzen666
you sound like the ppl complaining when a +300K gets announced, about the cost of ownership (maintenance, gas, insurance),
while not owning one yourself.
part of capitalism is to have options, doesnt mean i will ever sour it for someone else because they bought one brand (over another),
"as you didn't get told to bend over and no lube is used", its up to wallet owner, to determine what they spend THEIR money on.
if you dont like a brand, fine, doesnt mean everyone else needs to stop buying ..
@Sithaer
that's the thing, just because you dont notice it doesnt mean no one, especially given we dont all play the same staff.
once you played a shooter with fixed (smaller) map dimensions like Siege, you have enough time to look at stuff,
usually in just one direction (unless its pvp), and visuals are part of the reason i play on pc..
anything to taxing for my gpu, i rather drop res to QHD, and usually gain more fps anyway, panel is still 4K, so ..
