NVIDIA Tells AICs to Collect RTX 4090 Cards with Burnt Power Connectors, Send Them to HQ
tanaka_007
12 (0.01/day)
Heats up when certain pins become unbalanced.
It is necessary to check with a tester whether solder cracks have occurred inside.
7,762 (2.70/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
Yeah, they really should have bridged the solder tabs on the terminals on these. Though solder cracks aren't the biggest issue here - the terminals are thin enough that the copper will fail long before any solder joint does, so the thing to look for is stress fractures in copper, not failed solder joints. The pic you posted shows this - the solder joints haven't failed, the solder tabs on the terminals are sheared off entirely.
Kartoff
1 (0.00/day)
This is so funny... They want to convert 3x8 = 24 total pin to 12 pin connector and expect no problems ?!?
10 years ago, a friend of mine, who was a Power Color representative and we used to buy video cards from him, opened every single card and took out all the power adapters from inside! One day I asked him why there were none in the boxes of the cards bought by him, and that's how I found out that he does it... He explained that to some extent he prevents the use of cards with power supplies that are not intended for them... At that time adapters were Molex to PCI-E and with them you was able to power whole 6 pin PCI-E connector with 2x Molex connectors which is unacceptable...
7,762 (2.70/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
There's a pretty major difference here though: molex to PCIe adapters could allow you to use a GPU with a PSU that was rated far too low for the GPU, especially as they were often used with molex connectors on the same wire from the PSU. That isn't the case with these adapters - the cumulative rating of three/four 8-pin PCIe cables matches the 450W/600W modes of the 12VHPWR connector, and of course you'll need a PSU with a sufficient amount of PCIe connectors for this to work. Lower rated PSUs don't typically have that high a number of PCIe power connectors to begin with. You can still use daisy-chained connectors and have some minor issues, but these actually need to be rated for 300W power delivery when they have two 8-pin plugs on them, so the problem is much smaller.
As for the pin counts, remember that the PCIe 8-pin only uses three pairs for 12V, with the two last pins being sense pins.
On a fundamental level there isn't any real problem with doing this - but the implementation needs to be properly done, technically competent, mechanically sturdy, well executed, etc. Nvidia's adapter fails this miserably.
57 (0.07/day)
The FEs undercutting Aftermarket cards is probably what triggered enough is enough. EVGA will probably return in similar fashion as XFX.
3,049 (0.53/day)
MN
System Name Personal / HTPC
Seems Nvidia is saying they have stupid consumers that have been purchasing their cards and that the fires from the adapters are user error. So, not only are these people stupid enough to spend $1600+ on a 4090, clearly Nvidia also feels they're extra stupid because they can't fully connect the power adapter to the GPU.
Okay, Nvidia didn't officially call anyone stupid, those were my words, but they did claim user error
Here's the link to Nvidia's official response:
9,340 (5.06/day)
Louisiana
Keyboard G710+x3
Yeah this is an interesting response
Our findings to date suggest that a common issue is that connectors are not fully plugged into the graphics card. To help ensure the connector is secure we recommend plugging the power dongle into the graphics card first to ensure it’s firmly and evenly plugged in, before plugging the graphics card into the motherboard.
Do they not know the power cable does not connect to the mother boards they connect to the psu :kookoo:
1,088 (0.34/day)
System Name Main System
Processor i9-10940x
Motherboard MSI X299 Xpower Gaming AC
Cooling Noctua NH-D15S + Second Fan
Memory G.Skill 64GB @3200MHz XMP
Video Card(s) ASUS Strix RTX 3090 24GB
Storage 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a
Display(s) Dell U4320Q; LG 43MU79-B
Case Corsair A540
Audio Device(s) Creative Lab SoundBlaster ZX-R
Power Supply EVGA G2 1300
Mouse Logitech MK550
Keyboard Corsair K95 Platinum XT Brown Switches
Benchmark Scores Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855
You misread what they are saying. If you look at the picture, they demonstrated that the connector is not fully plugged in into the GPU. Therefore, they want the users to plug in the connector to the GPU first, to ensure that it is fully plugged in, before plugging in the GPU to the motherboard.
3,049 (0.53/day)
MN
If you watch the Gamers Nexus youtube about the 4090 fire and their testing, even just watching how they're trying to plug in the power adapter into the 4090 looks sketchy. You can see them using a good amount of force, yet the adapter doesn't seem to always go down all the way. That's probably Nvidia says to connect the power before even plugging the card into the motherboard, so you can apply equal force up on the card and not have the fear of warping/damaging your MB as you pushed down hard.
9,340 (5.06/day)
Louisiana
Keyboard G710+x3
Poor wording
You install a gpu you don't "plug" it in.
8,923 (4.03/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Update Derbauer just dropped a video on this connector fyi.
Yeah, the pins in the 12V HPWR connector are just too f*ckin' small.
Using worst-case limits from that video (so maximum safety margin assuming lowest-quality parts permitted in the entire chain) you get 72W per 12V wire pair with the classic MiniFit Jr.
That means that by modern safety standards, the 12V 4+4/8-pin EPS is good for 288W, an 8-pin PCIe is good for 216W, and a 6-pin is good for 144W. In theory if the PCI SIG introduced a "proper" 12-pin that used the standard-sized MiniFit Jr connector and had 5 12V wire pairs, you'd end up with a 360W cable, allowing for safety margins.
Let that sink in. A chunkier connector based on those safety standards can only handle 360W, so what the hell are Nvidia doing trying to force 600W down a cable half the size? Even 450W cables with dedicated sense wires are exceeding what would be max safe recommendation for 6 wire pairs on the much larger traditional connector. It's no wonder they are still melting left, right, and centre...
What's wrong with two 8-pins? That's 432W which in addition to the PCIe slot is >500W and IMHO that's far more power that should ever be consumed by a regular graphics card fit for 99.9x% of the market.
Deleted member 229121
I think they're a little late to the game in terms of burning the evidence lol.
Aquinus
Resident Wat-man
13,186 (2.75/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 14.6.1
Just another reason why I don't want to touch nVidia with a 10 foot pole.
Self-burning evidence. :roll:
3,542 (1.12/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
I've said it way back when this issue started but I don't expect this to go away, even for the new 12V2X6 connector. As people's cards age, resistances between the socket and connector will increase either through pins spreading naturally or debris / corrosion and thus increasing the chance for a meltdown. They need to solve the issue with not being able to bend the cable until after a certain length and they need to increase the safety margin.
I frequent repair videos and burned up 4090s and 4090s / 4080s with snapped PCBs from the weight are commonly seen in repair shops.
23,483 (6.13/day)
Good riddance, May many fools be parted with money so they learn a lesson. Good for that new generation of gamers. Quick way to build experience on not trusting marketing and jumping headfirst into new 'standards'.
Customer. Due. Diligence.
No single company is here to help you
Also yet another strike for Nvidia. Top quality? Nah. Just greed.
2,671 (0.95/day)
They are called 'ngreedia' for a reason. Also, their color is green; you wanna guess why that is?
1,824 (0.52/day)
North Dakota
System Name Office
Processor Ryzen 5600G
Motherboard ASUS B450M-A II
Display(s) Dell S2719DGF
Case Fractal Define 7 Compact
Power Supply EVGA 550 G3
Mouse Logitech M705 Marthon
Keyboard Logitech G410
Software Windows 10 Pro 22H2
3,889 (1.74/day)
UK, Midlands
System Name Main PC
Processor 13700k
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
Need someone to mod the proper working 8 pin connectors on to these cards.
Aquinus
Resident Wat-man
13,186 (2.75/day)
Concord, NH, USA
System Name Apollo
I don't know, criticizing a company for their brain dead decisions seems like a mature line of thinking to me. It's quite literally one of the reasons why I don't buy nVidia. I'd argue that it's more childish to ignore these things and blindly buying from Team Green.
2,671 (0.95/day)
Team Greed. :D
Aquinus
Resident Wat-man
13,186 (2.75/day)
Concord, NH, USA
System Name Apollo
ARF
4,670 (2.50/day)
Ex-usa | slava the trolls
The issues are still not fixed. Are there any rough consequences for nvidia or are they going to get out of this dry?
Repair shop continues to replace 200 RTX 4090 power connectors each month
