- Feb 11, 2024
- 89 (0.41/day)
- Canucksland
System Name | Main / HTPC / Server |
Processor | i5 14600K / Ryzen 5 2400G / i7 7700K |
Motherboard | Z790 PRO RS / B450M Mortar / Z270 IX Code |
Cooling | AS500 PLUS WH / Wraith Stealth / NH-D15 |
Memory | 32GB 6000 C30 / 8GB 2666 C16 / 32GB 3000 C15 |
Video Card(s) | GTX 780 (temporary) / iGPU / iGPU |
Storage | (OS) 1600X 118GB / V200 120GB / 850 EVO 250GB |
Display(s) | Predator XB271HU / KDL-55W950B / VH238H |
Case | Eclipse P400S / LC13-BU / Define R5 |
Audio Device(s) | Xonar U7 (HD 598) / Xfi Titanium (Azur 851A) |
Power Supply | Prime Titanium 750W / M12II EVO 620W / AXi 860W |
These CDM benchmarks of the P1600X were made on a clean Win 11 Pro 23H2 install for the first run. Then as a second step, to sort of parallel the conditions in which W1zzard tests these, I filled the drive furthermore to about 80% capacity to rerun all tests – twice.
It’s not like I went into the fresh install for that. In fact, the main goal of the operation was to install Windows 11 on an ineligible system AND live with it for a few days. But as I did so I thought I should bench the drive, since there is so little verifiable benchmarks of these out there.
Core system:
Still the P1600X is running on par to its specs on the main PCIe 3.0x4 M.2 slot from the PCH. Little done to Win 11 except installing a few everyday programs and cutting the prying to an acceptable minimum. No drive optimization nor specific drivers other than what Win 11 deemed proper.
Last thing I would like to add is that I had not used CDM for benching anything since the old days when Sata SSD changed our world and it became all the hype among enthusiasts to use CDM and show their results. Now there’s a nVME SSD setting that did not exist back then, and Peak/Real World profiles that might have but I couldn’t remember. Anyhow I got carried on trying each as-is combination, as I wanted to cover those tests often used in shady marketing tactics to hype the numbers. That nVME setting seems explicitly intended for that.
Strictly speaking, one would only need to run one pass with Real World settings, one pass with Default/Peak settings, then one pass with Nvme SSD/Peak Performance settings switching SEQ1M Q8T1 to SEQ128K Q32T1, to cover the same ground I did here. No test wasted in redundancy, and voilà. It even has the beauty to keep Q1T1 stuff together AND hype stuff together. I kept with redundancy for this post however because it gave 9/12 samples RND4K Q1T1/SEQ1M Q8T1, which are after all the strict numbers we can look at to get the real idea of the drive’s peak performance and of its “OS” capabilities.
Here’s a compilation I made in Excel averaging all tests. I even left there for you the RND4K Q1T1 data set I compiled last.
I got a lot of variance with SEQ128K and RND4K Q32T16 writes, which clearly usually aim to give the highest results. In the Compilation SEQ128K in fact has the lowest results of Write and Mix even compared to SEQ1M Q1T1. You’ll see a good example of such variance in the Verification results in the last post: MUCH better SEQ128K writes there but conversely quite lower RND4K Q32T16 writes to still a better Mix score. I have no explanation to offer about that much – it might be typical test behavior.
I take note that the more we circle closer to Q1T1 either Sequential on Random, the less the Optane gets any variance. SEQ1M Q1T1 and RND4K Q32T1/Q1T1 writes are pretty much flatlining. Read speeds very consistent throughout the entirety of tests as well, unaffected by what makes SEQ128K and RND4K Q32T16 writes vary so much. Could also be typical behavior.
In the next posts all results obtained, each post for each setting/profile combinations, ordered from the first test with just Windows installed at the top to the second test at 80% capacity filled at the bottom. In the last post a last Verification using the simplified “test it all in three runs” method, and a last few comments for those interested.
Default
Default / Peak
Nvme SSD
nVME / Peak
Real World
First the verification. Meanwhile I stumbled upon the CDM thread, so also adding a Verification using the unified settings there, that I will also post over there.
I’d like to add that I’ve found it pretty interesting to open Task Manager Performance tab and pin up the OS drive there. For one thing, you can see clearly what the drive is aiming at while CDM is running and how consistently it manages to sustain it. These were made while the “Verification 2/3 – Default/Peak Performance” test just above was taking place.
As I’m posting this I’m preparing to go back to Windows 10. I cannot truthfully form an opinion on Optane speeds on Windows 11 because of the registry bypass allowing my PC to make the upgrade. I’ve also briefly installed Windows 11 on my Samsung Evo 970 and it had the same effect: POST sequence is “abnormally” lagging. I didn’t linger much on the 970 EVO Win11 install since I got the Optane the day after and did another clean install straight away. But I must ask myself: what OTHER effects could be happening day to day once the OS is loaded for similar reasons? I’ve not noticed anything out of line there, but perhaps that’s because Optane is indeed very snappy. So I need to go back to my old environment where I’ve got years of experience with the 970 EVO, and see how Optane feels there.
I’ll repost some tests from Win10 but I don’t expect those to be much different. Just while I’m there, you know, I’ll add to the dataset... And by when I’ll post these I should have a final opinion on IF the 1600X brings perceptible OS uplift.
I hope that from here, some of you will post some results from their drives and hardware running it.
Core system:
- Maximus IX Code
- I7 7700K
- 2x8GB DDR4 3200Mhz
- BIOS is per default except XMP profile applied and HD Audio/WiFi/Bluetooth disabled.
Default
Default / Peak
Nvme SSD
nVME / Peak
Real World
