P8z77-I shut down issue and sleep issue
the8thdwarf
5 (0.56/day)
The computer works excellent with Windows 10 Pro however it won't shut down or sleep. I have tried everything I can think of but nothing works to solve the problem. Anyone please help.
342 (2.90/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Going to need more info. please fill out your system specs in profile. What does it do upon being told to shutdown or sleep? Have you tried shutdown /p in elevated command prompt?
42,491 (6.66/day)
Probably bios needs an update and reset to defaults, and fastboot might need to be disabled
342 (2.90/day)
Texas, USA
Certainly sounds plausible. A good place to start. I would add I've seen chipset drivers (or lack there of) cause similar behavior.
13,293 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Please explain what this means in more detail. You say it won't shut down. Does that mean when you go through the Start menu and select "Shut down", it won't?
I agree we need you to fill our your TPU System Specs.
42,491 (6.66/day)
I remember Windows back then having a message of It's Now Safe To Turn off Your Computer, oh the Physical Hard switch AT/XT Days. If that user gets that message his OS was misconfigured
159 (0.03/day)
Northern California
Processor AMD Ryzen 9800X3D
Motherboard Gigabyte Aorus Pro X870E
Cooling Cooler Master ML360R AIO w/ 6 fans in push/pull
Memory 64GB G'Skill DDR5 6000 CL30
Video Card(s) RTX 4080 FE
Storage Samsung 960 Pro + Samsung 980 Pro
Display(s) Alienware 38" AW3821DW 144Hz
Case Corsair Obsidian 800D
Audio Device(s) X-Fi Titanium Fatal1ty Pro + Maverick Audio TubeMagic D2 DAC
Power Supply Superflower Leadex III Gold 850w
Mouse Logitech G600
Keyboard Corsair K55
Yeah, not a lot to go on here.
I will say that back when I had my 2500k in my main computer, with a P8Z68-V motherboard, I had it overclocked at 5Ghz and everything was stable but sleep was always quirky to the point where I simply left my computer on all of the time. I assumed that it was a side-effect of the overclock but never really cared enough to investigate further.
But what do you mean when you say that it won't shut down? Do you just mean that at the very end of the shutdown routine it simply sits at a black screen without actually turning off? I've had that happen on a few computers before also over the years. After a certain amount of time, it's okay to simply flip the switch on your PSU or hold your power button down for 4 seconds. The main purpose of "shutting down" is to close all in-progress operations first, and anything relevant would have closed by that point.
42,491 (6.66/day)
And there are tweaks that force programs to shut down
the8thdwarf
5 (0.56/day)
When I hit shutdown from the desktop it seems to but the chassis fan keeps running, can't tell if the chip fan shuts down. Then in order to wake it or shut it down, I need to force it down by the power button then turn it back on.
1,006 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
I've had this happen on some setups in the past, something to do with the bios. Try disabling (or enabling) Fast Startup, that usually "fixed" it for me.
the8thdwarf
5 (0.56/day)
I also just tried the "shutdown /p" and that didn't work, also I eliminated the fast boot option. Still no luck.
the8thdwarf
5 (0.56/day)
Thanks for trying to come up with something, but I already tried that it didn't work. Also I tried "shutdown /p" on an elevated command prompt. Thanks again though.
4 (0.00/day)
System Name i5 PC
Processor i5 12500
Motherboard b 660 gaming x ax d4
Cooling fortis 5
Memory 2x 16 kingston 3600 xmp
Video Card(s) rtx 4070 dual deshroud with 2x arctic 12
Storage kc 2500 1tb (system), mx 500 1tb (other)
Display(s) 24" full hd 60fps
Case define r4, 2x 140mm in + 3x 120mm out
Audio Device(s) icon udac 2 + shp 8900
Power Supply rmx 850 atx 3.1
Software w10
Do you have the PC in PC case?
the8thdwarf
5 (0.56/day)
4 (0.00/day)
System Name i5 PC
Processor i5 12500
Cooling fortis 5
Software w10
I had exact the same problem.
Nothing worked, so i was ready to turn off the PC with PSU switch after turn off in Windows
But when i put the MoBo to PC case, it turns off without problems.
