PC system max power draw?
91 (0.26/day)
Processor 7600x -- 8600k
Motherboard MSI B650 -- ASRock z370
Cooling TR PA120 -- CM212
Memory 2x16GB -- 2x8GB
Video Card(s) PNY 4080 -- Zotac 2080ti
Storage 4TB SN850x / 4TB 870evo / 2TB SN770 -- 512GB 970 / 2TB WDBlue / some HDDs
Display(s) LG C3 (42) + Acer XB271HU -- Sony X950H (49)
Case Torrent Compact Steel Panel -- Define R2
Power Supply BeQuiet Darkpower13 750 -- Seasonic X750
Keyboard Epomaker TH80SE/EK21 -- Logi G710+
Software Win10 (both)
You can do a lot in the bios to get the power drain down and also in Windows. I have around 60-65W {monitor not included} idle. Measured with a T-RMS meter. Those cheap Wattmeters you find everywhere are only good to measure a resistive load. Switch Power Supply's it does a very bad job, and you're not sure what you measure. Do the test, put in the wall and connect a small Phone Charger in it without any load connected. Does your Wattmeter shows about 1W to 7W or more, then you have a cheap meter that can only measure resistive loads.
A good T-RMS meter will show something around 0.1 or 0.3W even less, for a charger without load connected. More then 1W is impossible because at that power draw it would burn up itself...
The readout on these UPS' only moves in 5w increments, is why I made that earlier statement about it not be particularly accurate, but 'good enough' for my use.
1,316 (0.92/day)
Tel Fyr
Display(s) Mi 2K Gaming Monitor 27", AOC 24G2U
Software W10 LTSC 21H2
The thread isn't meant to be a scientific project. I got my meter for around 15EUR, OFC it's not accurate.
You have proved your point, now please stay on topic and have fun.
487 (0.63/day)
System Name Firestarter
Processor 7950X
Motherboard X670E Steel Legend
Cooling LF 2 420
Memory 4x16 G.Skill X5 6000@CL36
Video Card(s) RTX Gigabutt 4090 Gaming OC
Storage SSDS: OS: 2TB P41 Plat, 4TB SN850X, 1TB SN770. Raid 5 HDDS: 4x4TB WD Red Nas 2.0 HDDs, 1TB ext HDD.
Display(s) 42C3PUA, some dinky TN 10.1 inch display.
Case Fractal Torrent
Audio Device(s) PC38X
Power Supply GF3 TT Premium 850W
Mouse Razer Basilisk V3 Pro
Keyboard Steel Series Apex Pro
VR HMD Pimax Crystal with Index controllers
My breaker is at its wit's end! I'm like 200-watts below the 1500-watt limit.
It's a big room with lots of screens and two computers on one breaker. I'm pretty sure I cant trigger it but another power hog might do the trick.
323 (0.67/day)
System Name Computer
Processor Intel 12700K
Motherboard Asus Prime Z690-A
Cooling Twin radiator open loop
Memory Corsair Dominator 32GB DDR5
Video Card(s) eVGA 3080 FTW3 Ultra
Storage Sabrent Rocket 4 Plus 2 TB
Display(s) Asus PG348Q and two Asus VN279Q monitors
Case Corsair 4000D Airflow
Audio Device(s) Sennheiser GSX 1000 with Sennheiser HD599 SE
Power Supply Asus Thor 1200P
Mouse Corsair Scimitar Elite RGB Wireless
Keyboard Keychron Q3 Max
VR HMD Oculus Rift CV1
140W? Damn, that can't be right... My system uses only 60-65W idle... Are you sure you measured with a TRUE RMS Wattmeter? Those cheap stock Wattmeters can't measure exactly from a Switch Power Supply.
I'm going by what the PSU reports. 12700K, 3080 FTW3, 6 case fans, a water pump, and a bunch of lite brite.
485 (1.74/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
I used a P3 to measure this a few times just because I was curious about it.
The Athlon 64 box pulls 43-48W and is on 24/7, averaging 1047W per day.
The FX-8370 rack pulls 65-225W outfitted with two disks and an SSD among other modules, pulling north of 1825W per day.
My Ryzen workstation pulls 113-295W with its fully designated loadout including an aging RX 580 and SolarFlare cards. No HDDs. It can climb up to 3790W per day.
I'm about to break the trend of that last one by switching up to a RX7900 XT.
1,589 (1.08/day)
Processor 5800X3D -30 CO
Motherboard MSI B550 Tomahawk
Cooling DeepCool Assassin III
Display(s) Dell S2721QS 4K60
Got two more results from Ubisoft's recent releases. Highest recorded momentary values for the built-in benchmark in maxed out native 4K + TAA:
GameUncapped frame rate [W]60 fps cap [W]Difference [%]
Assassin's Creed: Mirage447368-18
Avatar: Frontiers of Pandora461443-4
My meter shows 0.0 W.
According to the manufacturer, its tolerance is +/-1% (and +/-1 W) across 1-3000 W load, with maximum deviation of 4% over 2500 W. And testing power consumption even with a basic meter can offer insights into ways to limit its usage.
359 (0.46/day)
The issue with basic meters is that they typically use an integrated circuit that measures power usage averaged over a 1 second timespan. Actual power consumption can vary by a significant amount, particularly where a graphics card is involved. But for relative readings they can be OK.
3,426 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -8~12
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.8.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.1882), upgraded from Win10 to Win11 on Feb 2024
FarCry 6
Max settings + HD textures
3440x1440 (4.95Mp) rendered in x1.5 mode = 5160x2160 (11.15Mp)
1. Uncapped FPS
TBP: 399W
Max clock limit: 3400MHz
Vcore: 1070mV
Avg FPS: 93
Avg TBP: 370W (max 404W)
Max avg TBP: 409W (max 554W)
CPU avg PPT: 108W
Avg total PC power: 550W (74% load, 595W est. socket, ~93% PSU eff)
Peak total PC power: 660W (88% load, 720W est. socket, ~93% PSU eff)
2. Capped FPS to 62
TBP: 467W
Max clock limit: 2800MHz
Vcore: 1050mV
Avg FPS: 62
Avg TBP: 226W (max 380W)
Max avg TBP: 317W (max 415W)
CPU avg PPT: 100W
Avg total PC power: 380W (51% load, 410W est. socket, ~93% PSU eff)
Peak total PC power: 550W (74% load, 600W est. socket, ~93% PSU eff)
1st uncapped run was for the sake of the thread, I always run the game capped at 62fps with 366W TBP (helpes trim the high peaks on power)
Feel free to check also CPU/Vram/GPU/PSU temperatures and fan rpm of all components.
What a waste of power on first run, let alone the +noise. +185W avg socket power for a completely unnecessary (to me) 90+fps
The game feels as smooth to me at 62. I'm used to play at 30-50fps without VRR in past, so...
The GPU has the power when needed for much more demanding games.
Next on my list is CP2077, but after I finish FC6
773 (1.22/day)
System Name Asus G16
Processor i9 13980HX
Motherboard Asus motherboard
Cooling 2 fans
Memory 32gb 5600mhz cl40
Video Card(s) 4080 laptop
Storage 16tb, x2 8tb SSD
Display(s) QHD+ 16:10 (2560x1600, WQXGA) 240hz
Power Supply 330w psu
It would be a good idea to test old (DSR), ugly graphically, or badly optimised games, tha make the GPU/CPU (aio wc) fans crazy, like : Pathologic 2 (oh yeah, this one)...
... so we would know if it takes a lot power too !
Starfield is a perfect example, both ugly and badly optimized
2,698 (4.57/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
[System specs 1] a.k.a. DLSS: Around 380 W + whatever percentage due to <100% PSU efficiency.
[System specs 2] a.k.a. YOLO-PC: Around 340 W + <100% PSU efficiency accounted.
Both measured at full tilt (Cinebench + Furmark simultaneously) using HWinfo readings. Of course it's far from accurate, yet I don't have proper measuring tools. Both consume ~30 to 40 W at idle.
The only reason I care for wattage is I don't wanna get my PSU explode. Electricity is $7 per 100 kW where I live and it's cold 70+ % of the year.
3,110 (1.64/day)
Memory Micron DDR4-5600 ECC Unbuffered Memory (2 sticks, 64GB, MTC20C2085S1EC56BD1) + JONSBO NF-1
Power Supply Corsair RM750x
Mouse Logitech M575
Anyone have a recommendation for one of these using US 120v?
323 (0.67/day)
I have it on good authority from Todd that you just need to upgrade your computer.
301 (0.74/day)
System Name Personal computers
Processor Ryzen 7000, 8000 & 9000 series
Motherboard X670E & B650 boards
Cooling Deep Cool, Cooler Master, Thermal take & Stock air coolers
Memory G.Skill Flare X5, Corsair Vengeance RGB, Team T-Create & Adata
Video Card(s) Asus TUF gaming RX 7900 XTX OC edition / iGPUs
Storage 1 + 2TB T-Force Cardea A440 pro / 2 x Kingston KC3000 1TB
Display(s) 34 " / 32" / 27" LCDs
Case MSI MPG Sekira 100R / Silverstone Redline mATX / Antec C8
Audio Device(s) Asus Xonar AE 7.1 + Audio Technica -AD500X / Onboard + Creative 2.1 soundbar
Power Supply Corsair RM1000x V2 / Corsair RM750x V2 / Thermaltake 650W GF1
Mouse MSI Clutch GM20 Elite / CM Reaper /
Keyboard Logitech G512 Carbon / MSI G30 Vigor / Ttesports Challenger Duo
I've seen 450W avg power draw when running 3D marks's Timespy graphic tests on my system according to my CCI Pty Ltd power mate. This on a system with factory OC GPU & custom PBO settings on my Ryzen 7600X box.
However, when running 30 + mods in Skyrim Anniversary edition at 1440p with maxed out graphics, the system avg 250W. So I'm happy with that cause' 144Hz monitor maxed out. :)
622 (0.73/day)
PeakTech 9040 (wireless)
0 W without load connected
0.2 W with a second transmitter connected to the first transmitter.
The same result obtained when reversing the transmitters.
The receiver is powered by batteries.
1,373 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
just google killawatt and you will find a bunch of listings for ones like it
Just looked at my UPS, 410-440watts in watchdogs legion, ultra settings + RT on medium. that includes my modem and 2 routers which modem and 1 router is around 11-18watts between those 2. last router is just a 1gb switch so doubt its more then 2-5watts if that. Not sure what my monitor uses off hand
773 (1.22/day)
Cooling 2 fans
3,739 (0.58/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
I have an old Blueplanet EM100 that seems to work fine. I just use the one in my UPS now.
1,316 (0.92/day)
Tel Fyr
Yesterday I saw one of the Unigine benchmarks eating 580W.
Also these:
Days Gone 160FPS 570W
Age Of Wonders 4 120FPS 560W
Warhammer: Rogue Trader 120FPS 580W
Red Dead Redemption 2 130FPS 520W
Microsoft Flight Simulator 75FPS 575W
Indicates that my GPU OC push the system to a 580W ceiling.
