PCI express riser problems
141 (0.17/day)
Processor i7 7820x
Motherboard Asus Strix x299 XE-Gaming
Cooling Corsair AIO water H115i
Memory 32GB DDR4 Corsair 2400Mhz Quad channel (4x8GB)
Video Card(s) MSi RTX 2080 Ti
Storage SSD 860Evo+ HDD 3TB WD
Display(s) Samsung 48ju6400 +Full HD videoprojector
Case Kandalf VA 9000BWS Full tower modded
Audio Device(s) Azalia
Power Supply 750w Intertech Argus Gold 80+
Mouse cheap one wireless
Keyboard wireless
Software windows 10 pro x64
Cheers to all,
I encounter some weird problem which i never seen in my whole life.Let's sart with begin:
I have an motherboard Asus Strix x299 E-Gaming,and this motherboard doesn't have PCI slot anymore,so i buyed an PCI express RISER card to use an old tv tuner.My tv tuner is called: TT-Budget C1501 DVB-C tuner.
The problem is, i installed carrefuly that riser in pci-e slot,i connected auxiliar molex power,and in Device Manager it say: This device is working properly,and tv tuner is installed perfectly without error and problems.But when i scan for cable post, cannot find any channel,PAT is on RED.0 channel found and i don;t understand why and what happen.I verify tv cable on another TV, and signal is ok,the cable doesn't have problem
It is possible this riser card doesn't like my tv tuner or have HIDDEN PROBLEM?Is very weird because in Device Manager telling me: This device is working properly !!
My tv tuner technotrend is working properly too,because i tested on another PC with PCI slot, and is working without problem
I never seen such weird problem in my entire life.Someone can help me with a hint? I am in a total FOG ☹️
I tested full version of DVB and demo version free of DVB and teh result is the same...
I will never understand why new motherboard doesn't have at least one PCI slot,i hate so much this thing
I don't want to change actual tv tuner with another new product on pci-e,because this tuner c1501 is awesome and is making excellent HD captures,is a german tv tuner,and germans are very good at tv tuners......
Riser card is new and have 2 years warranty.What do u advise me? To return this riser card back?I don t know what to do...and I don't know how to prove that the riser has problems, since the device manager sees it without problems.Even if i return to warranty they will come back,they will return it to me, without changing it......
I have only bad luck
i hope i posted on a corect section,if not, i beg an moderrator to move on right section
thanks,
10,817 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
Did you try the riser card in the old motherboard?
It's hard to pin down because it could be any one of 3 things:
1. It's a software setting or lock somewhere that is preventing the channels from returning
2. It's a compatibility issue with the riser card itself.
3. It's BIOS or firmware limitation with the motherboard.
Realistically you have options --
Option 1) return the riser card and sell the tuner card, and then use the money to buy a USB or PCI-E tuner since PCI is dead for the future.
Option 2) Try one of the Miner solutions using USB interface PCI-E Express X1 to Dual PCI Riser Extend Adapter Card USB 3.0 PCI-E 1x to 16x | eBay --something like that and try using a different card.
Option 3) Find someone with that riser card who is also using a tv tuner and ask them, or call their support -- but that's a pretty niche setup.
1,011 (0.15/day)
Processor 2500K @ 4.5GHz 1.28V
Motherboard ASUS P8P67 Deluxe
Cooling Corsair A70
Memory 8GB (2x4GB) Corsair Vengeance 1600 9-9-9-24 1T
Video Card(s) eVGA GTX 470
Storage Crucial m4 128GB + Seagate RAID 1 (1TB x 2)
Display(s) Dell 22" 1680x1050 nothing special
Case Antec 300
Power Supply PC Power & Cooling 750W
Software Windows 7 64bit Pro
I'm wondering if the card was using the bracket connection to the case to help with grounding. Maybe worth looking into.
1,006 (0.29/day)
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Those adapters can be hit or miss with functionality especially on new boards. Try a different pcie slot maybe? One connected to the cpu rather than the chipset.
7,584 (1.48/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
PCI bridges are not all equal. They lack full feature set. I have a feeling, that PCI Bus Mastering is the thing it lacks with proper DMA access.
I would recommend to quit the fooling around and leave one vintage PC with native PCI. Let it go.
807 (0.70/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
As you can see, that riser was meant for low profile PCI cards. You can tell because there's a .45 impact hole in the case.
For full width cards use a ribbon riser.
I use TV tuner cards, is the signal going through the cable DVB-C (digitally compressed) or is it analogue? if it's analogue you won't get anything because the card expects a digital signal.
If the cable signal is analogue you have to convert it before it reaches the card, you can do that with a digital STB in the middle. If it comes from an antenna then you need the converter as well.
Insert a frequency range manually, it has to match that of the cable, you should also enable in-depth search.
141 (0.17/day)
Processor i7 7820x
Keyboard wireless
0 channel found in depth search too....PAT is still red...
807 (0.70/day)
Storage A lot
Case Corsair 760T
Keyboard IBM F122
Software 10 LTSC
Play with the other settings, see what Reception type does. Find out the frequency your provider or antenna uses.
The input of the card doesn't seems F-type but the cable is coax.
Make sure it's the right cable and that the card is compatible with that TV system. For example, my TV cable has an impedance of 300 Ohm, but the tuners are made for a 75 Ohm system, so I have to transform that impedance using a balancing unit or balun (a coil inside a bigger connector). Though this is only valid for analogue signals.
141 (0.17/day)
Processor i7 7820x
Keyboard wireless
Riser is working.Problem solved.I love germans :roll: :D
141 (0.17/day)
Processor i7 7820x
Keyboard wireless
when i removed the card from slot,i saw the yellow cable was broken,i don't know how...i glued it back,and now is working.Yellow cable is +12V
Anyway all 4 wires are very weak.they are glued badly from the factory....
China product...;)
95Viper
Super Moderator
13,018 (2.20/day)
i glued it back
Do you mean soldered it back onto the card? Gluing is not very electrically conductive.
Also, is the spot, for the yellow lead, under that piece of black tape?
Just trying to get it correct for posterity's sake.
Frick
Fishfaced Nincompoop
19,643 (2.86/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
On this very forum people has been adviced to glue wires into place, so I can totally believe the OP used glue.
807 (0.70/day)
Storage A lot
Case Corsair 760T
Keyboard IBM F122
Software 10 LTSC
Design fault. The connector should be soldered directly to the PCB without the use of wires, like in graphics cards of old.
141 (0.17/day)
Processor i7 7820x
Keyboard wireless
when i say glue i mean i use this pistol with fludor cositor 1mm :roll:
Anyway i hate so much that molex,i don't like it...The riser card would be so nice without that molex...but ,if manufacturer decide to have it...c'est la vie
p.s in foto is just a isolating black tape :roll:
yes,true.But is the cheapest solution i found on the market.I agreed with you: The connector should be soldered directly to the PCB without the use of wire
